Old 07-25-2023, 08:12 AM   #1
ChevyRed97
63 C10 w/ TH350 Shift Linkage
Looking for any tips on setting up shift linkage on my project. Tried the Lokar universal kit but I am having issues with alignment allowing a smooth shift and I can't access all the gears. Best adjustment I can get allows me to shift to D but I cant grab 1st or 2nd. Running a 283 with a TH350 and factory column. Any help is appreciated
1963 C10 2WD SB-Currently under restoration
ChevyRed97 is offline   Reply With Quote
Old 07-27-2023, 09:43 AM   #2
72Mountaineer
72Mountaineer's Avatar
Re: 63 C10 w/ TH350 Shift Linkage
What column are you using?
72Mountaineer is offline   Reply With Quote
Old 07-27-2023, 09:56 AM   #3
ChevyRed97
I am using a factory auto column
Old 07-27-2023, 10:13 AM   #4
ChevyRed97
Trying to look online and all the setups I see seem to be newer and don't have a crossmember coming across below the front of the trans. This wont allow me to rotate the shift arm on the transmission so it has to start about the 10-11 o'clock position and can only travel to 6-7 which doesn't give me enough travel to let the linkage move freely and is in also causing it to be in a bind. I could always bend the linkage rod to free it up some but lack of travel seems to be my biggest problem.
Old 07-27-2023, 11:20 AM   #5
geezer#99
geezer#99's Avatar
Did this column come originally on your truck?
Was your truck originally a 3 on the tree or 4 on the floor?
Old 07-27-2023, 02:43 PM   #6
ChevyRed97
Well I inherited it from my grandfather so it's hard to tell exactly. The story is that it was 3 on the tree originally and he pulled the column from an automatic but I can't swear to it, long before my time.
Old 07-27-2023, 02:53 PM   #7
geezer#99
geezer#99's Avatar
Usually when you swap in a turbo 350, you need to remove the bellhousing crossmember and install a trans tailshaft crossmember.
Two reasons for that.
One is your linkage as you’ve found out.
Second is angle your motor sits at. If you view the engine centreline it needs to slope downward towards the tailshaft about 4 degrees. That allows minimal u-joint angles and keeps your carb level.
To get the tailshaft down to the right spot the bellhousing crossmember needs to be removed.
Old 07-30-2023, 08:15 PM   #8
ChevyRed97
Ok, I appreciate the help. I will check that out. I did end up installing a tail shaft crossmember to mount the trans properly so the bellhousing crossmember isn't serving a purpose. I assumed I needed to leave it in there for structural reasons
Old 07-30-2023, 08:52 PM   #9
geezer#99
geezer#99's Avatar
Your tailshaft crossmember will act as structural support.
Old 07-30-2023, 09:15 PM   #10
72Mountaineer
On my 64 I used a setup from an early 80s S10, rod down to a pivot that bolts to the frame, small arm from there to the trans, U-shaped piece on the trans.
Old 07-31-2023, 12:20 PM   #11
ChevyRed97
Thanks to you both for the info, between the two ideas I think I might be able to get it handled now.
