Old 07-29-2023, 08:33 AM   #126
zicc1835
zicc1835's Avatar
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Originally Posted by derotoreut View Post
Drilled some holes in the firewall for my master cylinder and steering column. If you notice there's only two holes for the master and they're not studs. I drilled the stock pedal mount and installed rivet nuts in two holes for the master. This way I can use button head screws for a cleaner mount. The other holes have studs on the back of the firewall for mounting into the bracket.
Attachment 2280281
Attachment 2280282
Attachment 2280283
That’s clean….real nice look
zicc1835 is offline   Reply With Quote
Old 07-30-2023, 09:53 PM   #127
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
So I didn't really like the Plain Jane strikers that came with the Altman Easy Latches. A friend offered to machine me some new striker plates to go with the latches. Could probably get in trouble for using the Chevrolet logo on them.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-30-2023, 10:01 PM   #128
derotoreut
derotoreut's Avatar
Some of the body work is finishing up nicely.
Shaved the dash and test fit new defroster vents.
Shaved the cowl.
Removed and smoothed out the drip rails
~ Dan
Old 08-01-2023, 08:54 AM   #129
zicc1835
zicc1835's Avatar
Attachment 2281142
Attachment 2281143
Shaved the cowl.
Attachment 2281144
Attachment 2281145
absolutely stunning.......
Old 08-01-2023, 05:25 PM   #130
nicklear36
nicklear36's Avatar
What are your tips on tipping the cab upright like this? Did you put anything underneath it?
nicklear36 is offline   Reply With Quote
Old 08-02-2023, 09:50 PM   #131
derotoreut
derotoreut's Avatar
Thanks a lot!
~ Dan
Old 08-02-2023, 09:53 PM   #132
derotoreut
derotoreut's Avatar
The trick is having a lot of help. Yes setting on some blocks.
~ Dan
Old 08-02-2023, 10:24 PM   #133
derotoreut
derotoreut's Avatar
Decided to use a custom aluminum core support from AutoRad. It came with core support, radiator, condenser and overflow catch.
~ Dan
Old 08-23-2023, 03:10 PM   #134
derotoreut
derotoreut's Avatar
So I really like the Sean Provost 1970 Mafia C10 truck and what they did to the engine bay. My goal is to try to duplicate the inner fenders. In order to do that I first have to modify the fenders and then make some inner fenders. Come along for the ride.
Name:  01 South City Rod & Custom 1970 Mafia C10.jpeg
Name:  04 South City Rod & Custom-inner fender.jpeg
Name:  07 South City Rod & Custom-inner fender.jpeg
Name:  07 South City Rod & Custom-inner fender (1).jpeg
~ Dan
Old 08-23-2023, 03:22 PM   #135
derotoreut
derotoreut's Avatar
So here is what my stock fender looks like. I'm going to have to modify this on both fenders back to the hinges.
I'll have to cut away the fender back to the hinge mount and then weld in some material to mount custom inner fenders to.
~ Dan
Old 08-23-2023, 03:26 PM   #136
derotoreut
derotoreut's Avatar
Passenger side fender is cut back to the hinge mount.
~ Dan
Old 08-23-2023, 03:31 PM   #137
derotoreut
derotoreut's Avatar
3-inch material was cut and welded in place to box the hinge mount. Same needs to be done on driver side.
~ Dan
Old 08-23-2023, 03:40 PM   #138
derotoreut
derotoreut's Avatar
Now that the fender modification is complete. I moved the truck back to the cleaner part of my shop to set the engine back in for some fit up.
This is the look that I was trying to achieve.
~ Dan
Old 08-23-2023, 03:46 PM   #139
derotoreut
derotoreut's Avatar
With the engine back in, I moved the truck back over to the "dirty" part of my shop to try to lay out some inner fenders. This is a challenge and probably over my head, but I want to give it a try.
~ Dan
Old 08-23-2023, 03:59 PM   #140
derotoreut
derotoreut's Avatar
I quickly found out where my limitations are. Bead rolling is not one of my strong points, so I had some inner fenders made.
These are the Mafia C10 inners that I was trying to replicate.
Name:  03 South City Rod & Custom-inner fender.jpeg
The following pictures are mine. They look pretty good.
~ Dan
Old 08-23-2023, 04:07 PM   #141
derotoreut
derotoreut's Avatar
So with inner fenders made for each side, it's time to test fit them into the truck...
Driver side
Passenger side
A major set back is reached because they don't fit. I guess that's what I get for trying to make inner fenders without the truck being there. This is a big problem.
~ Dan
Old 08-23-2023, 04:30 PM   #142
derotoreut
derotoreut's Avatar
Well this is how the fender modifications turned out. It was a lot of work only to find out that the fabricated inners don't fit. I guess it's back to the drawing board.
~ Dan
Old 08-23-2023, 06:26 PM   #143
72 tigger
72 tigger's Avatar
That stinks!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 08-24-2023, 06:30 PM   #144
nicklear36
nicklear36's Avatar
What's the trick to tipping the cab back like that? Did you put blocks under the back wall?
Old 08-25-2023, 09:52 AM   #145
cornerstone
cornerstone's Avatar
Have you tried installing the inner fenders to the fender while it is not mounted to the truck, and then install the fenders to the truck, then the core support last? I think that might work.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 08-25-2023, 10:38 AM   #146
coldrider
Junior Member
coldrider's Avatar
Ugh, that sucks man, those are beautiful pieces. And not much you can do to modify them and still have them look good after all the bead rolling. Using them as templates for round 2?
My build thread
67 SWB M122 LS2 4L80E
coldrider is offline   Reply With Quote
Old 08-25-2023, 06:37 PM   #147
derotoreut
derotoreut's Avatar
No trick really. Just a few people and yes tipped up on blocks.
~ Dan
Old 08-25-2023, 06:41 PM   #148
derotoreut
derotoreut's Avatar
No I didn't try that because they were not even close. They were just way too long. Good thought, but there was no way they were going to fit. I'm pretty sure the OL length measurement was just flat out wrong.
~ Dan
Old 08-25-2023, 06:42 PM   #149
derotoreut
derotoreut's Avatar
Yeah I really thought about trying to modify them by cutting them and re-welding, but the bead rolls would not match up. Back to the drawing board.
~ Dan
Old 08-25-2023, 07:19 PM   #150
derotoreut
derotoreut's Avatar
Time to move away from the inner fender issue for a while. I wanted to dig out my suspension parts and get them fit up again. My plan is to get the suspension and brakes installed so I can eventually make this thing a roller. It's been on frame jacks for too long.
A-arms ready to go on.
Front suspension back together
All the parts were powder coated ahead of time
~ Dan
