Old 09-05-2023, 03:31 PM   #1
ViatminC10
63 w/14 gal Mustang Tank
Hey guys, I picked up a 14 gall Mustang tank the other day.
I have just the cab sitting in the frame with suspension and rear differential installed.
I know I will need to trim the frame rails , but how far forward from the rear of frame rails does the tank get mounted?
Thanks in advance for any input
ViatminC10 is offline   Reply With Quote
Old 09-06-2023, 01:56 PM   #2
ViatminC10
Re: 63 w/14 gal Mustang Tank
Anyone?
Old 09-06-2023, 10:43 PM   #3
bigmoe
bigmoe's Avatar
I didn't use the Mustang tank. I used a Tanks Inc one and I put it as far forward as I could.
bigmoe is offline   Reply With Quote
Old 09-08-2023, 01:27 AM   #4
62bagger
62bagger's Avatar
I mounted that same tank in my truck up to the cross brace. on the short bed there is just enough room. I don't have a good picture to show.
62bagger is offline   Reply With Quote
Old 09-08-2023, 08:18 AM   #5
ViatminC10
What I’m hearing is mount it as far forward as possible?
Old 09-08-2023, 03:38 PM   #6
62bagger
62bagger's Avatar
It took up all the space on mine. I don't think you will have a choice.
Old 09-13-2023, 03:29 PM   #7
pdxhall
pdxhall's Avatar
I'm running the Mustang tank I bought from Tanks Inc. I tucked it in under the top of the frame.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 09-13-2023, 05:10 PM   #8
ViatminC10
Thanks! I try that too. Did you figure out what to do about the sending unit to make it work with our factory fuel gauge?
Old 09-20-2023, 01:05 PM   #9
pdxhall
pdxhall's Avatar
I can't help you there. I've got aftermarket gauges so I just ordered a gauge to match the Mustang sender.
Sanity'66
Old 09-21-2023, 01:25 PM   #10
sirJim
You just need to add a resistor. There is a thread on here some where I used when I put my tank in, Maybe do a search. I think it is this one a 47 ohm resistor.
https://67-72chevytrucks.com/vboard/...d.php?t=447185
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 09-24-2023, 01:17 AM   #11
62bagger
62bagger's Avatar
I got mine from tanks Inc. it works with stock gauges.
Old 09-24-2023, 05:48 PM   #12
ViatminC10
Thanks, did you have to cut any material from the frame rails to get the tank up there?
Old 10-01-2023, 11:14 AM   #13
pdxhall
pdxhall's Avatar
I did cut the top frame rail back about 1/2 inch on each side.
Sanity'66
