03-16-2019, 05:48 PM | #51 |
Re: Work begins on the 1962 C10 4WD
More
03-16-2019, 05:50 PM | #52 |
Few more
03-20-2019, 09:29 AM | #53 |
Another pic
Not sure what were gonna work on next (after the alignment) so much to do |
06-09-2019, 07:55 PM | #54 |
New front shackles pins and bushings going in at the rear of the front spring. It was a little bit of a pain getting the bushing in the frame out but not as bad as I have read on here. Hopefully the other side is the same.
06-09-2019, 08:00 PM | #55 |
Does anybody know where I can get the front greasable bolt for the front leafsprings?
LMC has them for 109.00 each. They dont seem to be a normal size greasable bolt? |
06-12-2019, 09:28 AM | #56 |
Help Please. I HATE to have to spend 200 dollars for 2 bolts!!
Has anybody come up with a solution or substitute for this bolt? It's the front leaf spring, front eye bolt. I found a place that has them for 90.00 dollars each. LMC wants 109 each plus 27 dollars shipping for 2 bolts ( WTH?) They don't seem to be a normal size greasable bolt and have to fit the bronze bushing. Thanks , Jeff |
06-12-2019, 12:17 PM | #57 |
You may want to check to see if the front pin for the rear spring is the same as the one for the front spring. They are much less expensive. I know Classic Parts of America sells these parts and also try Rare Parts Inc.
I got lucky and was able to re-use my front pins.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
06-12-2019, 01:36 PM | #58 |
63-66 are different than 60-62.
1961 chevy K10 my build is------------61K10 build |
03-02-2021, 12:06 PM | #59 |
Some more pics of a very slow progress. The floor is done and its running. New core support and body mount bushings. The engine is 100% rebuilt /zero miles. We have 4 doors but none of them are in good shape. Gonna have someone else weld on new, lower inner and outer door skins. I did all the other welding myself so far.
03-02-2021, 12:11 PM | #60 |
03-02-2021, 12:17 PM | #61 |
03-02-2021, 12:19 PM | #62 |
Some .
10-12-2023, 12:21 PM | #63 |
OK been a while. A lot of work has been done. Now searching for shifter boots and trim rings. I can find the original shifter boot and trim ring but nothing for the transfer case. I see some people are using 67-72 transmission boots and trim rings and 71-72 x-fer case boots but I cant find any trim ring for this either. what is everybody doing? I do not care if its original. I would like each boot to atleast resemble each other. Trim rings also. Used is ok also.
I have searched all over the forums and internet for answers. |
10-12-2023, 01:41 PM | #64 |
Few quick pics
10-12-2023, 01:45 PM | #65 |
front
10-12-2023, 01:47 PM | #66 |
1 more
10-17-2023, 10:04 AM | #67 |
Love your truck, great build - thanks for sharing!
10-23-2023, 01:28 AM | #68 |
Another orange truck being built! sweet. I am ashamed to say that I haven't gotten anything done on mine in years but plan on going orange and black vs the orange and white but there for awhile you never saw any orange trucks around. I love the skinny tires on newer OEM wheels, I have a set of those myself but think I might go for the base truck steel wheels from a ram I also have laying around. Good work man I can't wait to see it together out in sunlight.
