04-06-2021, 11:48 AM | #26 | |
Re: Heater core shut off valve
The unit I've seen is a billet piece. Very clean unit. I'll post up the info as soon as I can access it but it's basically just a higher-end (and more expensive) version of the early variations in your provided link/s.
04-06-2021, 12:51 PM | #27 | |
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
04-06-2021, 01:52 PM | #28 | |
I had a primitive bypass set-up (as in using what I had available for free vs spending money for something that may not impact my issue) for my 74swb @ one point. I was struggling w/heat soak on the a/c & wanted to see if blocking the hot-water flow to the heater core helped. I built a similar, simple hand valve set-up as it's what I had available for testing. I knew there were early OE versions of a vacuum/temp actuated bypass valve (from GM) available but wasn't going to spend the money for one just to find out it didn't make a difference for my needs.
04-06-2021, 02:06 PM | #29 |
wait... what?? there's a valve that does this?
I started out with nothing - and I still have most of it |
04-06-2021, 02:21 PM | #30 |
I believe the two types of vacuum operated valves for 67-72 trucks are different. If I recall correctly the early one without bracket is normally closed and later one with bracket is normally open. Both could be used together to create a bypass.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-06-2021, 08:09 PM | #31 |
Old member
I had a hard time getting mine to burb when I installed it. I finally had the front end jacked up and took the 2 small steam ports loose on the front of the engine. That seemed to do it. Haven't had any more issues since. That was back in 2014. That I know of any way the truck runs cool even with the AC on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-09-2023, 01:26 AM | #32 |
My 70 K10 is non a/c so I installed valve like Grumpy showed pic of. There is a vacuum operated valve for a/c trucks, but cant find a valve for mine, they dont make one? Or does heat lever control something other than a valve? thanks!
11-09-2023, 02:19 PM | #33 |
Heat lever only controls a blend door on non-a/c trucks.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-09-2023, 05:03 PM | #34 |
If I paint my vise-grips silver, does that count as billet?
11-09-2023, 05:07 PM | #35 |
Thanks, I wont pull box off firewall just to see whats there. The other problem is keeping fan switch adjusted, will get it right, but in a few hundred miles it gets finicky again, blue loctite on screws? Thanks again for reply!
11-09-2023, 08:15 PM | #36 |
I screwed a stainless steel body, teflon seat ball valve into the intake manifold, and run the hose from it, with an elbow.
1968 SWB Step Side, Big Block, 4L80E , Running! |
11-09-2023, 08:36 PM | #37 |
Anytime you can replace a gate valve with a ball, good idea.
Tags |
heater core |
