Old 11-08-2023, 09:44 PM   #4326
Speedracer39
Speedracer39's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by Extended Power View Post
Making headway on more wiring.
Electric fans, Lokar kick down, MSD-6AL2, Vintage Air, and MSD HVC II coil all wired up.
Sorry, no idea how to flip picture.
I was curious what you are using for a fan set up. I just installed a vintage air front runner and a new Dewitt alum radiator and it seems the fans are going to be tight
Speedracer39 is offline   Reply With Quote
Old 11-09-2023, 01:43 AM   #4327
'68OrangeSunshine
'68OrangeSunshine's Avatar
I'd love to shoot you some pix of the 20 and 30 year-old flex fans on my two trucks, but I gotta work tomorrow.
Old 11-09-2023, 10:50 AM   #4328
Speedracer39
Thanks but I was referring to Extended power he has a bbc with same serpentine kit as I just installed and was wondering what electric fans he is using.
Old 11-09-2023, 03:23 PM   #4329
'68OrangeSunshine
Originally Posted by speedracer39 View Post
thanks but i was referring to extended power he has a bbc with same serpentine kit as i just installed and was wondering what electric fans he is using.
ok/ nm
Old 11-09-2023, 03:38 PM   #4330
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by CAMAROBOY68SS View Post
Got the 350 out today and cleaned a few things up and now moving onto swapping stuff over to the 327 and doing some measurements for the new TKX 5 speed.
I sure like that garage. Nice.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-09-2023, 09:03 PM   #4331
72c20customcamper
72c20customcamper's Avatar
Got the new starter in wasn’t a very pleasant experience. I had to have the mounting block milled down . It was at almost .60 gab without any shims I think the machines milled down .10 ,it brought it to close but one shim brought it to exactly.30 .I also had to remove the Shaft shim to get the depth right too.
The isn’t charged in the picture so it’s slightly retracted when I power the solenoid it goes to proper depth on the Flexplate
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-10-2023, 10:21 AM   #4332
Extended Power
Extended Power's Avatar
I had to also move the new engine forward another inch, just to have a sliver of clearance on the passenger side valve cover.
On the old 402 BB, I was able to run two 16” Syclone electric fans. (Which were 4” deep”)
Now there is no room at all for them, and I had to find the slimmest 14” electric fans that still moved a lot of air. (Especially now with the added AC condenser, and power steering cooler added to the front, in addition to the already installed transmission cooler.)
There is 1/8” clearance between the electric fans wire cover sleeve, and the belt tensioner on the passenger side of the engine.
I just hope the fans move enough air to keep the engine cool. Don’t have too many more options.
I can post a picture of just how close everything is in a bit.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 11-10-2023, 10:37 AM   #4333
Extended Power
Here are some pictures of the 14" fans I bought from Evil Energy, and their specifications.
It was to hard to see the gap between the fan and the pulley system, so I placed a white sheet of paper underneath for better results.
I didn’t use any of the thermostat stuff. I went with a Derale 16759 adjustable fan controller with manual over ride.
Old 11-10-2023, 08:38 PM   #4334
Speedracer39
Thanks for the info. I was looking at this it measures 3.5 thick and I have contacted them and was told that I could safely trim 3/8 off the shroud I have a alum radiator coming from Dewitt and will have a better idea how much after it arrives.
Old 11-10-2023, 08:51 PM   #4335
Speedracer39
Pic added
Old 11-10-2023, 09:02 PM   #4336
Speedracer39
Pic added
Specs of fans
Old 11-10-2023, 09:03 PM   #4337
mr.mud1
mr.mud1's Avatar
Nothing too exciting with my truck other than put it on my trailer and backed into it's hiding spot til spring.2 cars,1 truck and my trailer all snoozing,1 more truck to hide,maybe tomorrow and then back to working on my old car.spring will be along eventually.
mr.mud1 is offline   Reply With Quote
Old 11-10-2023, 09:15 PM   #4338
71CHEVYSHORTBED402
Nice CLEAN truck. It's worth babying.
Tony
Old 11-10-2023, 09:44 PM   #4339
mr.mud1
mr.mud1's Avatar
thank you sir.her working days are over.she'll be living a life of luxury now.all the best.Greg
Old 11-10-2023, 10:29 PM   #4340
JamesRKing72
JamesRKing72's Avatar
Today I finally fixed that broken button in the door handle. Happy I finally got that fixed! Also started applying boiled linseed oil to the body, much easier than clear spray paint. Then messed with the EVR because it keeps buzzing and making so much noise. I need to chase down that diode in the brown wire to make sure it’s good. But also, I have HEI distributor and need to make sure I wired it correctly. Pretty sure I did but that was 7 years ago. If I can’t figure that out I’ll have to upgrade my alternator. Why does something always break when you fix something else non related?
1971 Cheyenne, The Blue Jay.
The Blue Jay build thread-
http://67-72chevytrucks.com/vboard/s...d.php?t=516989
JamesRKing72 is offline   Reply With Quote
Old 11-11-2023, 10:21 AM   #4341
allchevy58
allchevy58's Avatar
Originally Posted by Jiggers72-GMC View Post
Nice job on the Line-ex, great work truckers
Originally Posted by 3757chevy View Post
Very nice . Good job on color match.
Thank you, I'm real happy the way it turned out.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 11-12-2023, 11:42 AM   #4342
Chevys4life
Nice shop you have!!!
Chevys4life is offline   Reply With Quote
Old 11-12-2023, 05:28 PM   #4343
mr.mud1
mr.mud1's Avatar
thank you sir.i got one more truck stowed away yesterday so everything that has to be away,is.i am very fortunate with this new shop.i built it how i wanted after working for years outside,then a shop that was too small and with a broken furnace that never got fixed and poor lighting.i'm officially spoiled rotten with this new 64 x 32 building,it's a very nice place to work although i'm embarrassed to say,i wished i'd built it bigger but i'll shut my mouth and be happy with what i have.take care.Greg
Old 11-13-2023, 04:48 PM   #4344
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Got everything buttoned up on the 327 swap yesterday and was able to get it fired up
http://youtube.com/shorts/Y2wXICz-to...rwgOA7IufepgYR
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 11-14-2023, 01:05 AM   #4345
Rust_never_sleeps
Rust_never_sleeps's Avatar
Got the plug wires swapped. Pre SBC, I'd have thought this would be a 20-45m job, but routing under the ram's horns and over the starter and scraping off road filth at the same time and pulling one of the heat shields, and.......
Rust_never_sleeps is offline   Reply With Quote
Old 11-14-2023, 11:14 AM   #4346
Smitty
Smitty's Avatar
Got my old girl Detailed. Just like the wife going to the beauty shop. Back in the garage covered. Waiting for a sunny day with a purpose or the last show of the season.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 11-14-2023, 02:51 PM   #4347
novaX522
Started wire brushing rust scale from the truck bed of my 72 c10. Gonna wipe it down with Rust Mort, then try the new sprat in liner from rust oleum.
novaX522 is offline   Reply With Quote
Old 11-15-2023, 01:09 PM   #4348
novaX522
Have close to 4 hours wire wheeling the inside of the truck box and tailgate. All the visible rust is gone. Tonight I’ll rust mort it. Depending on dry time, I might be able to apply the bed coating.
Old 11-15-2023, 01:29 PM   #4349
Rust_never_sleeps
Originally Posted by rust_never_sleeps View Post
got the plug wires swapped. Pre sbc, i'd have thought this would be a 20-45m job, but routing under the ram's horns and over the starter and scraping off road filth at the same time and pulling one of the heat shields, and.......
Sadly, I did have to part ways with this OEM cable management system:
Old 11-15-2023, 08:07 PM   #4350
TxGary
TxGary's Avatar
Just getting back from getting exhaust put on the 69 with my little helpers. Hope to hear it run in the near future.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2015 Chevy Tahoe LTZ 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
