Old 11-26-2023, 11:10 PM   #1
stilldreamin6772
cant get the camber out!!
I have a 67 with the Performace Online lowering /disk swap kit. It got the 2.5 in lowering spindles with 1 In drop spring. All new front steering components and gear box. I went and had it aligned and the passenger side upper controll arm is in as far as they can go, no shims left and i still have to much positive camber. Any ideas on a solution? I was thinkin tubular uppers but thought they pushed the top out also.
TIA
stilldreamin6772 is offline   Reply With Quote
Old 11-27-2023, 10:36 AM   #2
Dead Parrot
Re: cant get the camber out!!
Might have the frame checked for straight and true. It might be a bit out due to a past accident or just 50+ years of use.
Dead Parrot is offline   Reply With Quote
Old 11-27-2023, 01:27 PM   #3
Custom 68
Custom 68's Avatar
I sure thought when lowering these then typically the camber is too negative. Since yours is opposite I am not sure what to think.
Good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-27-2023, 03:39 PM   #4
stilldreamin6772
I had asked them if it looked like there may have been damage and they didn't think so. Panel gaps are good everything looks to be original and in order. So maybe lime you said 50 years of use? Not sure but ine summer approximately 5k and my tire is about worn.
Old 11-29-2023, 09:52 AM   #5
SCOTI
SCOTI's Avatar
Good luck
Dave
Correct.
@Dead Parrot, post up some pics & lets see if we can't get this figured out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-29-2023, 11:36 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Did you accidentally install the uppers on the wrong side?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-30-2023, 02:42 PM   #7
CC69Rat
CC69Rat's Avatar
As I read through the post, this is kinda what I was thinking too.
Looking at the truck from the side, do the front wheels look like they're too far back in the wheel wells? For example if you drop a plumb on center of the wheel well opening is the center line of the wheel significantly further back? If I'm thinking clearly (I'm old..) I'm pretty sure it would shift the wheel centerline back (?)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 11-30-2023, 11:08 PM   #8
Custom 68
Custom 68's Avatar
The caster would sure be off in this case but not sure if it also affects the camber.
Dave
Old 12-01-2023, 02:56 AM   #9
SCOTI
SCOTI's Avatar
I don't think so but letting everyone run through their theories while waiting for some images 😎.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
