01-02-2024, 09:05 PM | #11 |
Re: column shifter hard to find shift
The easy way to adjust your NSS/BU light switch assuming the switch itself is good, is put the shifter in the neutral position and connect an Ohm meter to it, then make the adjustment until you get a open or resistance reading. Double checking this reading in reverse and park will confirm all is as it should be.
