New 10K hitch install
Installed a new Curt 14082 10K hitch. The trailer I plan to pull will be in the 5-6k range when loaded. I like to setup for overkill, so a 10k sounded right. I researched on this site what hitch was recommended. I am very happy with it. Very nice quality, simple install, fits perfect. The hardware included thick steel shims to use for spacers between hitch and frame to clear rivets. There weren’t any rivets where I mounted the hitch, so I was able to mount it right to the frame. I did use the thick shims on the top of the frame as reinforcement.
I’ll have my friend that’s a fabricator look at it to see if he thinks the frame area needs any reinforcement. |
#2 | |
Re: New 10K hitch install
![]() Join Date: Nov 2018
Curt makes nice hitches, have used many over the years that fit/work well.
#4 | |
![]() Join Date: Jul 2000
That's one seriously stout hitch!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Did you have to drill holes on both side or was there holes already there to bolt too??
Thanks |
I like your thinking ! Always a pleasure knowing that trailer is secure and not going anywhere…Nice job !
71 C-20 07 Magnum RT AWD |
