Old 01-20-2024, 05:34 PM   #1
Shortnwide4x4
Shortnwide4x4's Avatar
replacement cab corners/best supplier?
Hello all!
I acquired a truck and the PO had started to do some rust repair, they had cut out the cab corners.
I cant tell you how much rust there may have been there originally but the cut-out was for the entire patch panel which did not fit nicely at all, and didn't follow the contours of the cab. I know that no matter which cab corner i decide to use i will have to modify and im ok with that, im just looking for recommendations on a manufacturer from those who have been happy. Both these cab corners have been bought by me from companies that specialize in resto parts. The following pics show the major differences that i have encountered.
In another post about doors someone mentioned keyparts. In visiting their website it looks like they have a well-constructed cab corner, (the bodyline in the cab corner appears to have the proper contour)! BUT they don't sell to the general public...and summit will not have availability until the end of Feb. Anyone know of a supplier that deals with KeyParts? arg!
thanks for any help!
(cleanest cab corner in pics fits best, but is still crap!)
Shortnwide4x4 is offline   Reply With Quote
Old 01-20-2024, 06:43 PM   #2
Jason Banks
Jason Banks's Avatar
Re: replacement cab corners/best supplier?
Key Parts has an eBay store:
https://www.ebay.com/itm/17178143759...4AAOSwAdNixyd5
or
https://www.ebay.com/itm/15156713615...AAAOSwF1BjEie1
They also sell through Jeg's
Jason Banks is offline   Reply With Quote
Old 01-20-2024, 08:16 PM   #3
slikside
slikside's Avatar
sub'd. Good info!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 01-21-2024, 12:56 AM   #4
70c10resto
70c10resto's Avatar
I bought mine from National Parts Depot after reading a review from this site. They both fit great but were a little more expensive.
70c10resto is offline   Reply With Quote
Old 01-21-2024, 12:16 PM   #5
Shortnwide4x4
Thanks! i will check out both those out!
this is one of the things that is giving me the fits: both cab corners have this and its no-where near the contour it has to be.
Old 01-22-2024, 11:16 AM   #6
Jason Banks
Usually the rust doesn't go that high on the cab corner and that part gets cut off.
Try to only use as much of the patch panel as you need to replace the rust.
I got a drivers side floor panel and only used about a 3x5 inch piece of it.
Old 01-22-2024, 01:09 PM   #7
Shortnwide4x4
agreed 100%
cut out only what you need to, avoid major bodylines if you can!
I got this truck this way so i have to deal with it.
update on parts: NPD uses apex not Key parts, they are 18g steel, 21.8x13.3". i may give them a try if i cant source Keyparts cab corner somewhere. The ebay store will not ship to Canada.
key parts from Jegs i think had a wait time of April '24
Old 01-22-2024, 01:58 PM   #8
Jason Banks
Sorry, I didn't notice you were in Canada...
What about these guys in Canada?
https://www.classicchevy.ca/key-part...ide-0849-115-l
You might give Key Parts a call and see who might have them in Canada...
Old 01-22-2024, 02:32 PM   #9
Louisvillekytruck
Originally Posted by slikside View Post
sub'd. Good info!
x2
Louisvillekytruck is offline   Reply With Quote
Old 01-22-2024, 07:58 PM   #10
Shortnwide4x4
Thanks Jason!
got some on order. Will update thread when i get them
Old 02-23-2024, 11:31 AM   #11
hevy_chevy67
hevy_chevy67's Avatar
Thanks Jason!
Not sure where you are in Canada, but Redneck Superstore near Three Hills, Alberta stocks and carries KeyParts.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 02-23-2024, 02:35 PM   #12
kxmotox247
kxmotox247's Avatar
Gmcpauls or Cooper Restorations. I've used a handful of Keyparts cab corners. They aren't perfect either.
kxmotox247 is offline   Reply With Quote
Old 03-23-2024, 12:40 PM   #13
Shortnwide4x4
Well, as mentioned no cab corners are perfect, but at this point i wouldn't even call most suppliers acceptable. Since they are cheap i got 4 different kinds of cab corners just to experiment with and i am now resorting to buying a used piece for the fit I like for the body line 1/4 way up from the bottom of the door/corner and using after-market metal for the very bottom. Because they are cheap i suppose quality suffers too. The best advice is to limit the amount you remove. Im restoring a 69 Firebird with my brother as well and parts quality is much better.
example of one of many issues:
Old 03-23-2024, 01:56 PM   #14
Belsh
Junior Member
What were your thoughts on the Keyparts ones, were they just as bad as the others?
Belsh is offline   Reply With Quote
Old 03-24-2024, 12:22 PM   #15
Shortnwide4x4
Keyparts is one of the better ones. But stay away from the top bodyline,
