Junior Member
![]() Join Date: Apr 2013
Best way to clean crusty parts
My boys and I are doing the entire front end on our 1969 C20. We have it all taken apart, but the control arms I am reusing are extremely crusty. Lots of grease/dirt built up on them from 55 years of farm.
I’ve gotten rid of most of the big stuff with a brush and a hammer/chisel. I planned on soaking them for a few days in a degreaser concoction and then taking them to get blasted and then repaint. Is there a better way to do it? If painting, just use a chassis black enamel after primer? |
Re: Best way to clean crusty parts
Diesel will dissolve all the greasy cruddy stuff. If I have a small area, I use WD40, its about the same stuff. To get any thin residue left on, Simple green.
![]() Join Date: Dec 2009
![]() Join Date: Jun 2022
I've been using Purple Power(since seeing a video demonstrating it working better than Super Clean) for the reasonable stuff.
For the "poor man's undercoating" where the oils and grit have caked up, I've been scraping the worst of it off and using O'Reilly generic engine cleaner. I've stopped using brushes until the sticky crap is gone because it just gunks them up
1970 C10 Custom longbed 350/350 |
I used brake clean for grease and gunk. I used a 4” grinder with a wire wheel to get the crusty stuff off.
Born Psycho
![]() Join Date: Feb 2001
oven cleaner from the local dollar store works well on gunky stuff
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Junior Member
Thanks for the replies. We’ll get to work with a few of the techniques and post the results when complete.
Lots of scrapping first . Then EZ off oven cleaner .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Jun 2002
If they are off I soak them in one of the degreasers listed for a couple days then load them up and take them to the carwash. The guy who owns it is a buddy of mine and he said it doesn't bother him, but he hates the horse guys who clean out their trailers there!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
Moderator
![]() Join Date: May 2007
Bilge cleaner
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() ![]() Join Date: Jul 2002
Dollar Store oven cleaner and my pressure washer is how I do most super greaser things like the frame/suspension. If I don't have the oven cleaner or after it, I use the purple power stuff.
1 to 9 ratio of molasses to water. Don't leave softer metal parts too long, it will eat them.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
![]() Join Date: Sep 2014
#15 |
Molasses has citric acid(as a preservative?) so it can work on rust, but IDK if it's any good on grease.
#16 |
![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
Spray degreeser, let it soak than head over to a self serve car wash and use the high pressure washer.
Or take the parts to a mashing shop to have the parts cleaned. That's what I did when I was restoring my '87 Chevy, I took the parts to a machine shop, had them remove any ball joints or bushings, they soaked the parts overnight, put the parts through a cleaning machine, I took the parts home to get painted, than back to the shop to have any ball joints or bushings pressed back in. Last edited by desert-rat; 01-29-2024 at 07:49 PM. |
