1968 headlight buckets. Pics attached.
Good evening all. Came across a little issue in my build. Looks the the rad support is a newer style. I have a 68. The one I have has buckets already tacked in place. Can I make this work or do I have to change rad support. Thank you.
Re: 1968 headlight buckets. Pics attached.
Is it just a matter of drilling out attached buckets on newer style support
![]() Join Date: Jun 2002
Just remove the later style buckets. Not sure if you will have to drill some square holes after that but I think they are already there. I did the same thing with a GMC support years ago.
If you can post a side view of your truck, I love the old CP200 American Racing wheels. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
Sure. I ended up finding a complete 68 parts truck right close to me. I’ll do the swap. Here’s a picture.
#5 | |
Good luck, Rg
