02-14-2024, 03:57 PM | #1 |
Motor instal
I’ve got a dumb question. I’m definitely in over my head on my blazer, but I’m still attempting to plug away. The trans and transfer case are out being rebuilt. I am attempting to instal a new motor. I have new motor mounts, motor in and tight. It rocks back what seems way too much. Also my drivers side header is touching the frame it wasn’t before. My question is will the motor not sit correctly without the transmission supporting the rear? Any insight would be great. I attached a couple pictures. My goal is to get the motor dressed and start putting the front clip together so hopefully ready to fire when I get the transmission back.
I apologize I do not know how to make pictures show upright! |
02-14-2024, 07:19 PM | #2 |
Re: Motor instal
The motor will droop back without the trans holding it up. It is probably a good idea to support it either with the lift you installed the engine with or a jack from underneath.
02-14-2024, 07:19 PM | #3 |
Re: Motor instal
The motor mounts alone will not hold the engine in the correct orientation.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-15-2024, 11:48 AM | #4 |
Re: Motor instal
Thank you I’ll leave my jack under it for the time being
