Old 08-17-2009, 02:26 PM   #1
vegaschevy
Seat bolt size and thread pitch?
I dont have seat bolts for my truck. What size is the bolt and what thread is it? Also is it a standard bolt or is it special? any pics of them?
vegaschevy is offline   Reply With Quote
Old 08-17-2009, 03:47 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Seat bolt size and thread pitch?
they look similar to the cowl bolts. I believe its the same size as well. Pull a bolt from the side of the windshield cowl and see if it matches
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-17-2009, 03:47 PM   #3
71 super
71 super's Avatar
5/16 coarse thread
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-20-2009, 08:31 PM   #4
vegaschevy
Originally Posted by 71 super View Post
5/16 coarse thread
THank you sir, Ill have to pick some up. ANyone know how long? 3/4"? 1"?
Old 08-20-2009, 10:06 PM   #5
my67chevytruck
Under Construction
i believe 3/4. dont have any infront of me at the moment. the 1" will work as well as there are no stops etc. to keep from sinching down.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 08-20-2009, 10:19 PM   #6
red71c10
The Red Menace
red71c10's Avatar
I bought new bolts for my seat from LMC and they worked perfectly.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 08-20-2009, 11:02 PM   #7
sleepertruck72
sleepertruck72's Avatar
I pulled two and they were 5/16" at the threads, 3/4" long, but I dont have a pitch gauge...
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 08-20-2009, 11:30 PM   #8
vegaschevy
Good enough for me
Old 02-20-2024, 01:14 PM   #9
1969stepside
1969stepside's Avatar
are the bolts for the bucket seats the same as the bench seat bolts?
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-20-2024, 02:05 PM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If you mean the bench seat brackets to seat and floor, (GR 5) 1/2" hex recessed head tapered bolts with spin washers. The bolt threads are 5/16-18 x 7/8" under the spin washer, and the heads are stamped RBM.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-20-2024, 11:09 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ What is a "spin washer"?
~Steven
Simi Valley, CA
Old 02-20-2024, 11:25 PM   #12
71CHEVYSHORTBED402
Here's a whole bunch of them before refinish. Integrated. You know, the washer that spins around under head but won't pull off. Most are flat washers, some star washers, some split washers. Tooth washers for headlight grounds.
Basically my bench seat bolts are 1" long under head, but 7/8" - ish under the spin flat washer. According to my truck, similar bolts are often 3/4" under the spin washers. Those for my bench seat a pinch longer.
Tony
Old 02-21-2024, 09:52 AM   #13
1969stepside
so the bench seat bolts and bucket seat bolts are diffrent? i am asking about the bolts that hold the seat track to the cab floor
Members i Have met
Earl Slick68
Old 02-23-2024, 05:10 PM   #14
71CHEVYSHORTBED402
Just my two cents. GM would have gone out of their way to simplify stuff, so to me that means seats take the same bolts. But I can only speak for a bench. Another way to think about it, I don't have a bracket in front of me to measure, but I don't know, 3/16"ish? Full 1/8" at least, guessing. If the brackets you're working with are the same, yeah, probably the bolts cited above. Note GM had their reasons for installing grade 5 seat bolts.
Tony
Old 02-24-2024, 03:51 PM   #15
54blackhornet
54blackhornet's Avatar
Aren’t the original style bolts pointed to assist in getting them started compared with a regular bolt.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-26-2024, 11:17 AM   #16
1969stepside
do you need to use grade 5 bolts or grade 8 bolts?
Members i Have met
Earl Slick68
