Old 11-08-2015, 08:11 PM   #1
2mas
Duramax swap - Rear axle gear in c10?
Hi,
I'm doing a Duramax swap into my 65 c10.
Now I need to program the ECM to get the speedometer to show the right values.
I've been looking at old threads on gears. My 65 C10 had a V8 auto. Do you know what gear it has in the rear end?
I can read HA0415W on the axle, but I cannot find anything on it.
When turning the drive shaft 2 revolutions the wheel rotates almost one turn (one wheel in the air)
/Thomas
1965 c10 BBW LWB - Duramax
2010 Camaro SS - Whipple (721hp)
2017 Volvo V60 diesel-hybrid (233hp)
2008 volvo XC70 diesel
http://67-72chevytrucks.com/vboard/s...d.php?t=677577
2mas is offline   Reply With Quote
Old 11-08-2015, 08:37 PM   #2
jdl71
jdl71's Avatar
Re: Duramax swap - Rear axle gear in c10?
The ratio is stamped on the ring gear. Remove the cover and have a look if you want to know for sure, but probably 3:73.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 11-09-2015, 12:19 AM   #3
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Do you have any pics of your build?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 11-09-2015, 04:55 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Common gearing for C10's was 3.73.
Old 11-09-2015, 08:04 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
This way is for sure! I found out this way I had a 1967 3:08 gear.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-09-2015, 10:06 PM   #6
2mas
Added link to my build thread in my signature.
/Thomas
Old 03-01-2024, 12:14 PM   #7
Dan Castilleja
What motor mount kit did you use?
Dan Castilleja is offline   Reply With Quote
Old 03-01-2024, 01:12 PM   #8
bigmoe
bigmoe's Avatar
Originally Posted by 2mas View Post
Hi,
/Thomas
Spin the wheel around TWO times and count the driveshaft revolutions.
bigmoe is offline   Reply With Quote
