02-20-2024, 10:30 AM | #526 | |
The Older Generation
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
Thanks Mike. I have sold quite a few parts locally but I wanted to get this last project done so I could make sure I had enough decent parts to finish it. I have a short fleetside truck back in the corner of the shop that my boy wants to finish up. I started it back in 2008 so it has been on the back burner for a while.....
02-21-2024, 12:09 AM | #527 |
Born Psycho
Leon great job on a small budget and a sturdy working truck
that's kind of how i'm building my 69/72 suburban-just stuff i already had or traded for. and according to my homeowners insurance I still have too much "stuff"
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
02-21-2024, 01:23 AM | #528 | |
Thanks Jerry. Luckily my homeowners insurance doesn't care how much stuff I have. When the adjuster came to look at my Derecho damaged barn, I had everything from the barn out in the yard (and it was a LOT of stuff) all he said was (Quote) "You had all of that stuff in the barn?" Yep, every bit of it. He said "WoW".... .
03-04-2024, 07:23 PM | #529 |
I installed the "Real" truck mirrors today.... .
03-04-2024, 08:29 PM | #530 |
now its REALLY a truck LOL...... looks great
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-04-2024, 10:03 PM | #531 |
BlahBlahBlah
Such a neat truck. You really did an awesome job!
03-04-2024, 10:41 PM | #532 |
Looking Good
03-04-2024, 10:50 PM | #533 |
So what’s the first thing you’re going to tow??
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3 lift & 6-speed 02 E320 the insurance total free car 13 Tahoe LTZ |
03-05-2024, 01:34 AM | #534 |
Thanks... I couldn't see too much out of that little round mirror...
I appreciate that Mark. Thanks. It depends on which one of my other vehicles breaks down first... .
03-05-2024, 01:50 AM | #535 |
Leon you built a fine specimen there....If GM would have built it, this is what it would have looked like! Congrats on a well done conversion.
03-05-2024, 03:06 PM | #536 | |
Thanks. That is what I was trying to accomplish and I think it came out pretty close.
03-08-2024, 11:53 AM | #537 |
Took the truck to get the alignment done and deliver an ashtray to a friend of mine. Ended up covering 136 miles overall. Garmin shows 11 MPG. I was hoping for a little more but I have a hard time keeping my foot out of it.... I am going to be removing the instrument cluster in the next day or so to see if I can figure out why the temp gauge isn't working. Anyone know what the OHM reading is on the Chevy 8.1L temp sender? I am also thinking about installing the extra pair of Jeep JK headlights I have.
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-08-2024 at 12:17 PM. |
03-08-2024, 12:18 PM | #538 |
I sure like the ones I put in the Burb.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
03-13-2024, 10:54 PM | #539 |
Thanks. I finally got around to installing my Jeep JK headlights today. When I installed the set in my '67 Panel Truck I didn't have to make any modifications to anything, but with this set I had to make a couple of modifications to the headlight bucket. It must be because of the difference in the way the headlights mount in the core support on the '67 & '68 trucks. I bought these on e-Bay. The headlights I bought were from a private seller that changed his over to something different. They are in excellent condition. You have to be careful because there are a lot of look alikes. They do make exact replacements too but you have to watch, some of them come with bulbs and some don't. The easy way to tell the OEM's are by the back. I think the lights are the same from 2007-2015. The first picture shows the parts and the second picture shows the modifications I had to make to the buckets. Third picture shows the adapter harness. They are available here: https://www.ebay.com/itm/13094045132..._redirect=true Fourth picture shows a closeup of one of the headlights installed, and the fifth shows both headlights. I am still going to install the headlight relay upgrade one of these days. I adjusted them using these instructions. https://67-72chevytrucks.com/vboard/...3&d=1426438429 It worked good..... .
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-14-2024 at 12:09 AM. |
03-14-2024, 01:04 AM | #540 | |
03-14-2024, 10:42 AM | #541 | |
Thanks Mike. They looked like they were going to work after I cut the notch but on closer inspection the units were not seated down all the way against the buckets. It wasn't much, but I had to grind the reliefs to make them sit flush.
03-14-2024, 08:36 PM | #542 |
I had time this afternoon to pull the instrument cluster out of the Dually. (picture 1) I wanted to install an extra cluster I had while I worked on the one I pulled out. I went to install it and noticed that it was from a big truck. The area that the column fits into is different on the big truck bezel. (picture 2) What to do? Get out the coping saw of course.... (Picture 3) That makes a c10-c30 cluster out of it.... (picture 4) It's raining here today so I won't be able to test it out until tomorrow.
03-14-2024, 09:06 PM | #543 |
interesting timing on your headlight install info
I had my truck out tonight and can't see $h.t. I have the old sealed beams in and do have a pair of ( im not sure what they are) I had in my 72 im going to try them first they are sealed with the signal light in the bottom half never did like them but they worked cuzz I used a earlier bumper without the signals in the bumper........... and yes love that Satin Black on your truck
03-14-2024, 09:10 PM | #544 | |
Thanks Doc. I was having the same problem with mine. It was like having no lights at all. The JK headlights made all the difference in the world.... I read somewhere that with the turn signals in the lights you can't see them with the lights on. ?
03-16-2024, 08:36 PM | #545 |
Well, the temp gauge still doesn't work so it has to be something with the sender. Bummer....
03-17-2024, 03:43 PM | #546 |
I Bench tested the temperature gauges this afternoon. They all test good. Here is how I did it. Use a 9 volt battery. Connect a jumper from the Positive terminal on the battery to the Positive post on the gauge. (red wire) Connect the Negative terminal on the battery to the Ground post on the gauge (black wire). Connect the yellow wire to the Sender post on the gauge. When you touch the other end of the yellow wire to the backplate the needle should go all the way over to "hot" side. If the gauge is not mounted to the backplate just touch the free end of the yellow wire to the post on the gauge that the black wire is connected to and it will make the needle go to the "hot" side. This will let you know if the gauge is good. .
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-17-2024 at 03:48 PM. |
03-18-2024, 12:50 AM | #547 |
You're gauges are probably good, but I encountered a temperature gauge once that passed the test you did above, and it was still bad. The needle wouldn't move from C after the engine warmed up. I think there was an internal short in one of the windings that still let it work partially. Because of this, I like to test these gauges by connecting the Sender post to a second 90-Ohm resistor, and then connect the other side of that resistor to ground. In this state, the needle should move to the normal operating temperature position where the needle is approximately 1/8" to the right of the second line.
03-18-2024, 09:19 AM | #548 | |
03-18-2024, 09:46 AM | #549 |
03-18-2024, 10:21 AM | #550 |
Good deal. Thanks. I will re-test the two gauges that way today.
