Old 03-19-2024, 06:11 PM   #1
Belsh
Junior Member
Am I missing something?
Been cutting some of the floor out on my 70 C10 and noticed the 2 holes in the chassis rails (in picture), they line up with the trans crossmember, Looks like there should there be some fixings through them?
Belsh is offline   Reply With Quote
Old 03-19-2024, 10:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Am I missing something?
I'll check the 1/2 ton bare frame I have in the morning and see what is there. I think it should have bolts in it.
Leon
Old 03-19-2024, 10:29 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Am I missing something?
you sir are correct, a lot of times they don't get put back because the cab mounts get smashed down and it's a ***** to put them back in.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-20-2024, 08:39 AM   #4
LockDoc
LockDoc's Avatar
Here is a picture of my 1/2 ton frame.
Leon
Old 03-20-2024, 09:45 AM   #5
Belsh
Junior Member
Thanks as always, I think I will tack weld some nuts on from the top to facilitate fixing the bolts from below as I suspect getting to them is rather tricky as Jerry has alluded to!!
Old 03-20-2024, 02:59 PM   #6
68Gold/white
Wrap a piece of masking tape on the nut. That will allow a box end wrench to hold it while starting the bolt.
68Gold/white is offline   Reply With Quote
Old 03-20-2024, 03:21 PM   #7
Belsh
Junior Member
Do you not recommend tacking the nuts on? I figured it will make life easier if i ever have to remove the bolts
Old 03-20-2024, 04:07 PM   #8
68Gold/white
Nothing wrong with welding....
Old 03-20-2024, 04:25 PM   #9
Accelo
Accelo's Avatar
The early trucks had this end piece riveted onto the cross-member.
The only method to get it out was to hammer one side forward and the other back. This spread the frame slightly and knocked all kinds of dirt and crap loose in the process.
Later ones were bolted.
To get these out easier, I just loosened the bolts, at the cross-member, and removed the ones from the frame. Made it a lot easier to complete the R&R.
The bolts came in from the top and I didn't have to remove them from between the frame and cab to get the cross-member out.
I never did determine exactly when this change was made.
Nothing wrong with welding to nuts to the top of the frame. Typically one doesn't have access to pull this off like you do.
Accelo is offline   Reply With Quote
Old 03-21-2024, 06:43 PM   #10
dmjlambert
dmjlambert's Avatar
Was this truck working without the crossmember attached? Trying to figure that part out.
Old 03-21-2024, 08:57 PM   #11
Casper42
Casper42's Avatar
Yes - a proper heading on your post
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 03-22-2024, 02:40 AM   #12
Belsh
Junior Member
Ive only done about 50 miles in it since purchase but seemed to drive ok for a 53 year old truck, there are fixings on the bottom of of the crossmember too which are in place which was why I wasnt sure if top ones were supposed to be there or not.
Old 03-22-2024, 02:42 AM   #13
Belsh
Junior Member
Please accept my sincere apologies, in future I shall run any posts past your good self for approval before posting......
Old 03-25-2024, 01:25 PM   #14
70STOVEBOLT
70STOVEBOLT's Avatar
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-25-2024, 02:42 PM   #15
MySons68C20
MySons68C20's Avatar
Most polite way to say.......you know!!
MySons68C20 is offline   Reply With Quote
