Old 03-20-2024, 03:31 PM   #1
1969LTX
Pro-Touring rear axle widht ??
Guys,
I would need to order new rear axle for 69 C10. I have DSE quadra link with bolt on brackets and plan to use 13 x 19" rear wheels in future. But before I can order wheels, I need the rear axle. What is the recomend rear axle widht ?
1969LTX is offline   Reply With Quote
Old 03-20-2024, 06:03 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Pro-Touring rear axle widht ??
Originally Posted by 1969LTX View Post
Guys,
I will have to ask my friend what the custom rear end width is on his build.
Here is a thread that I posted about it:
http://67-72chevytrucks.com/vboard/s...d.php?t=851312
Leon
Old 03-21-2024, 12:49 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Guys,
I recommend getting the wheel/tire combo and then ordering a rear axle to place them exactly where you want them under the truck.
Keith
Convert to disc brakes.
Old 03-21-2024, 01:55 AM   #4
Richard
This is custom stuff. The axle width would be determined by the amount of backspace of the wheel with needed clearance in fender well. Many like the look of a wide "lip" on the rear wheels which would require a narrower axle. The 13" wheels with a 6" backspace would look good. You are also maybe creating more issues by needing temporary wheels to use for a time. If wheel reveal is not important just make axle stock width and have wheels made to fit.
Richard
Old 03-21-2024, 07:27 AM   #5
Joyridin
My 8.8" out of an Explorer is 56.5" wide from WMS to WMS. I have a 13" wide rim with 2.75" BS. The smallest they will make the backspace is 2.5". They are 20" wheels and 28" overall height.
Joyridin is offline   Reply With Quote
Old 03-21-2024, 04:06 PM   #6
HO455
HO455's Avatar
X2! There are too many wheels out there with limited backspace options to make the axle width decision based on a different combination. Not to mention the different brake options and axle bearing selection that can alter the width of the axle.
Get the tires mounted on the wheels and mock them up in your truck, at ride height, then you can determine the clearance on both sides of the tire and when your satisfied measure your width between the wheel mounting surfaces for your axle width.
RIP Bob Parks.
