Old 03-19-2024, 10:10 AM   #1
popeyestruck
Radiator shroud fit
Bought this shroud from LMC and cant figure out how to attach it. Doesnt come down far enough. Looks like the flange is about an inch short. Do they make a bracket to make it fit? I was thinking some spacers made from a piece of 1 inch pvc pipe
popeyestruck is offline   Reply With Quote
Old 03-20-2024, 06:56 PM   #2
Hcb3200
Re: Radiator shroud fit
Your just going to have to make some bracket that fit the holes for the radiator mount. then bend them to match the shroud mount with another set of holes in the bracket. Or return it for something else.
Hcb3200 is offline   Reply With Quote
Old 03-21-2024, 03:15 AM   #3
popeyestruck
I figured it out
Old 03-21-2024, 11:27 AM   #4
dsraven
I suggest to place some foam tape on the back side if it touches the rad anywhere. that will keep and vibration rattles down.
post up some pics of your fix, we'd all like to see how you got it rigged up.
Old 03-21-2024, 02:18 PM   #5
popeyestruck
Just used some 3/4 inch pvc pipe cut into 1 inch spacers. Got another question while I got you here. What do I use to plug the 2 holes in the lower radiator for transmission coolant lines?
Old 03-21-2024, 03:43 PM   #6
leegreen
probably it is 1/2-20 threads, designed for 5/16 tubing size inverted flare connection
so look for '5/16 sae plug'
leegreen is offline   Reply With Quote
Old 03-21-2024, 04:54 PM   #7
popeyestruck
