Old 03-25-2024, 04:44 PM   #1
425HP409
425hp409
425HP409's Avatar
68 accelerator pedal
Is it possible to install a swinging accelerator pedal and go with the accelerator cable instead of the factory accelerator rod in y 68?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 03-25-2024, 05:03 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: 68 accelerator pedal
I did it on my 69 suburban - i cut out the firewall area from a 72 and welded it into my firewall, it was pretty simple-BUT- i had the front clip off and the engine was out of the truck so there was lots of room.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-25-2024, 07:37 PM   #3
raggedjim
raggedjim's Avatar
Yes, there are adapter plates that make it pretty easy.
Or if you are feeling crafty http://67-72chevytrucks.com/vboard/s...00#post1383300
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
