04-08-2024, 10:50 AM | #1 |
Trim / Mounting Holes....What should I do?
Hey everyone.
I am trying to figure out what I should do with the trim mounting holes in the fenders, doors, cab, and bed. I want to replace the trim on my '67 K20 with factory trim, but should I leave the holes in place and try to work with new factory clips, or should I weld all the holes up and try to use adhesive tape to attach the trim? I was thinking that the holes would be a natural point to let water in. I believe that nowadays cars all use adhesive to attach the trim and molding. Any advice or ideas? My reasoning for welding up the holes in the first place is because when the holes were originally punched in, it made the sheet metal wavy. I was thinking that if I just welded them up, I could skim coat the panel with filler to make it dead level and then just "glue" on the trim pieces. Thanks, Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
04-08-2024, 01:39 PM | #2 |
Re: Trim / Mounting Holes....What should I do?
I will be replacing mine on my 72 C10 after paint. I purchased the wood grain lower and upper molding from Mar K. When I removed the old molding none of the adhesive spots were still adhered to the metal. Understandable with 50 year old adhesive. I think the 3M adhesives are pretty good stuff. What I'm going to do is use both the push ins and adhesive like original. I saved the old adhesive clips and wire wheeled off the old dried adhesive. Came off like powder. I'll do the same to the Mar K stuff as it's been in the carton for 10 plus years. (I'm slow) I'll then apply the 3M emblem adhesive to the plastic clips. I'll probably use extra adhesive clips down the bed sides in case of an adhesive failure. Don't know about yours, but the short bed uses adhesive strips on the upper molding except for the two end connections. I'm sure someone on the forum has some ideas. Keep everyone posted.
OOPS! Sorry, after looking at your truck we're talking two different animals. Oh well someone will help you. |
04-08-2024, 03:03 PM | #3 | |
Shame the holes messed up the sheet metal. Perhaps you can use the holes to straighten it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-08-2024 at 03:10 PM. |
04-08-2024, 04:22 PM | #4 |
The metal is not super bad on my truck. There is a slight dimple / waviness that would be hidden by the trim. I was only able to see it when I blocked down the epoxy and it showed up as low spots around each of the holes in the door.
You can kind of see it here with this hole:
04-08-2024, 07:44 PM | #5 |
In my past painting projects I have always welded up the holes.. Reason being is when you take all the molding off there is always a ton of dirt behind them. As far as badging, I have the painter paint in the same spot the designation of the truck
04-08-2024, 08:48 PM | #6 |
I leave the holes and use the clips. The trim is designed to work well with the clips. If you were to tape the 67/68 trim on, it would be a PITA and you would need to build the tape up on the back of the trim to make it work and look factory. If you didn't build it up and just taped along the (really)thin edge of the trim, you wouldn't have much taping surface and the trim would be spaced off the truck the thickness of the tape.(which they sell in different thicknesses)
As far as water getting in, make sure the drains in the bottom of your doors are clear and functional and put some rope caulk on the holes in the cab corner and you should be good to go. All of the 67/68's that I have seen are dimpled like that when they have the factory trim holes. I have historically made sure the dimpling won't show, or if I think it might, I'll body work up to within 1/2 inch of the hole and not have the build up at the edges of the holes. Most won't show. Have you ordered your trim yet? I ordered a set of shortbed trim from Mar-K back in December and I'm still waiting, but I don't need it yet either. It should ship soon and maybe they'll be good on stock again. |
04-08-2024, 09:31 PM | #7 | |
Thanks Jason! That definitely makes sense. I have not yet ordered any trim. I am still in the body working phase of the project. I am just about done with the driver side door and fender. Then I have to repeat the process on the passenger side. The hood and grill are in pretty good shape, so it will be onto the bed after that. That is a whole different story....the bed is going to take a lot of work or total replacement. Clay
04-09-2024, 09:39 AM | #8 |
This guy used the 3M tape on 67-68 trim, you might drop him a pm and ask how it is holding up.
LARGE pic in post! https://www.67-72chevytrucks.com/vbo...45&postcount=7 And here's a good thread about trim installation. It's tailgate trim but some good suggestions in there. http://67-72chevytrucks.com/vboard/s...d.php?t=705912 Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd Last edited by raggedjim; 04-09-2024 at 09:51 AM. |
04-09-2024, 01:59 PM | #9 |
That tailgate trim thread is great. That's how I have done it, but the VHB tape beneath the clips to keep from making outie dents in the trim. I think I used 2 layers of VHB tape under the clips.
That's some trim I would consider using only the tape to hold it on. I never got mine to be perfect with the clips. |
04-10-2024, 05:17 PM | #10 |
I would keep all the holes. I used nothing by the metal clips to attach my moldings. Years ago I was able to ALL the factory trim from GM before it was discontinued. I think I got all the moldings in the late 90's.
With summer temps here in Arizona typically over 115° I didn't want to worry about adhesive coming loose.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
04-10-2024, 05:22 PM | #11 | |
Thanks everyone! Clay
04-10-2024, 05:28 PM | #12 |
Do u have pictures of the whole truck thanks
04-10-2024, 05:54 PM | #13 | |
FWW, here's a write-up on the subject. https://67-72chevytrucks.com/vboard/...d.php?t=844873
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-10-2024 at 06:19 PM. |
04-10-2024, 09:52 PM | #14 |
subd
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
