Old 04-12-2024, 02:02 AM   #1
profe56
Flowmaster question
Hi folks good evening.
Long time not visiting the forum.
I'd like flowmasters for my C10 69 350 Engine 700 transmission
I don't want them too loudy especially for inside, can you give suggestions please.
thank you.
profe56 is offline   Reply With Quote
Old 04-12-2024, 02:16 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Flowmaster question
My truck had 40 series mufflers on it, and they were way too loud for me (and my neighbors). I ended up going with 50 series Delta Flow. They're fairly mellow at idle, but they make decent noise when accelerating hard. The aggressiveness of your camshaft will have a big impact on how the exhaust sounds.
Here's a good comparison video of the various types of Flowmaster mufflers.
https://youtu.be/JcqJmwaDfYE?feature=shared
pjmoreland is offline   Reply With Quote
Old 04-12-2024, 04:14 AM   #3
Richard
Have a single 3" 70 series big block muffler on my 94. I like it and get compliments on the truck often. Sound is not loud and does not pop./crackle. I hate that. Leaning towards using two of them in a 3" with an x pipe in my 72 build. Just trying to justify the cost. May use some high flow cats to get the sound lower as well.
Richard
Old 04-12-2024, 12:26 PM   #4
72SB
Look into Flowmasters new FX muffler. Unlike its other mufflers, it is a straight through design like MagnaFlow and Dynomax. Nice sound but quieter than their clasic 40's
72SB is offline   Reply With Quote
Old 04-12-2024, 04:16 PM   #5
HO455
HO455's Avatar
Flowmasters noise estimates are generally loud. Their market is the racer crowd. For the most part the larger the number the quieter they are.
X-pipes will help reduce the noise and if you end up with the classic Flowmaster drone you can add a J-pipe to reduce or remove it. Nowadays there is a lot of information on how to make and install them. They were factory on 1968 Pontiac GTOs so they're nothing new.
https://strikeengine.com/helmholtz-r...j-pipe-length/
Good luck.
RIP Bob Parks.
Old 04-12-2024, 04:19 PM   #6
LS short box
My go to mufflers for my hot rod projects are Dynamax turbos. Typically 2.5" inlet/outlet.
For me Flow Masters are too loud.
Old 04-12-2024, 05:21 PM   #7
Joyridin
Flowmasters for me are too loud. I went with Spintech mufflers. They have a deep throaty sounds without all the resonance that Flowmasters have.
Joyridin is offline   Reply With Quote
Old 04-12-2024, 05:22 PM   #8
chevmn
Is there such a thing as too loud? Kinda like too much money and too much power.
Just kidding of course....I know it all depends, and everyone has their personal preference. I once ran a short bed truck with full exhaust exiting behind the rear wheels with no mufflers. Liked the sound, but it was a daily driver, and longer trips with windows down were too much so I ended up putting on some small turbo mufflers. On my 72 big block truck I have headers, and a pair of the Jegs "flowmaster 44" knockoffs with 2.5 inch pipe turned out just behind the cab. Not sure I like the sound...it is ok when 4 bbl is open, but still it has more of a tin can like sound rather than deep mellow tone. Considering going old school to either small chambered round, or some 12 inch glass packs. I really liked the old round thrush mufflers, but apparently no one reproduces them, and NOS on ebay are out of my price range.
chevmn is offline   Reply With Quote
Old 04-13-2024, 12:27 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Pair of 70 series behind a rowdy sbc 406 and they do a good job of taming the sound
Old 04-13-2024, 12:24 PM   #10
kwmech
Magnaflow mufflers here for my vehicles. flowmasters are too raspy for me. The Magnas seem to have a better tone in my opinion
Old 04-13-2024, 12:43 PM   #11
72SB
In general, chambered mufflers are louder and the straight through perforated tube wrapped in fiberglass are more mellow. Magnaflow and Dynomax as a result are typically quieter than chambered Flowmasters.
However Flowmaster now makes a type like the Magnaflow and Dynomax called their FX line. I assume to compete in that muffler market sector. They are a welded SS case. I bought mine for about $40 each on Amazon. They do have a nice exhaust note and will let you know when you go WOT.
Old 04-13-2024, 01:48 PM   #12
Sheepdip
Sheepdip's Avatar
Flowmaster Super 40's on my 40 Coupe and Magnaflows on Louie my avatar. Both have H pipes to tone it all down... both sound good.
But in the end it's all about individual preference.
Sheepdip is offline   Reply With Quote
Old 04-13-2024, 02:08 PM   #13
Luke87gt
The 40 series is the classic 2-chamber Flowmaster that everyone knows.
As pointed out above, it’s a bit much for some (in term of sound and drone).
If you like want the classic Flowmaster chambered sound but you want to tone it down a bit, try something between 50-70 series.
Also, their “FlowFX” is a straight through muffler like a MagnaFlow. They flow well but don’t expect them to sound like what you expect a Flowmaster to sound like.
Good luck
1969 C10 Shortbed
Wanted (pm me):
- Pair of 275/60/15 tires
Luke87gt is offline   Reply With Quote
Old 04-13-2024, 04:09 PM   #14
truckster
truckster's Avatar
Same here. I put Magnaflows on my Blazer. They're loud enough the dogs know when I get home, but not raspy. It's a nice, smooth sound through the RPM range.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-13-2024, 05:27 PM   #15
BROWN 70
BROWN 70's Avatar
Thumbs up Re: Flowmaster question
agree with post 2. I have delta flows also. just right idling and a bit stronger on the gas. BROWN 70
BROWN 70 is offline   Reply With Quote
Old 04-14-2024, 11:15 PM   #16
profe56
Thank you all of you for the info.
There are 3 different CROWER CAMSHAFTS.
And I have the less strong.
I’ll see the noise.
