04-20-2024, 11:44 AM | #1 |
Hood Springs
Hi, I just installed the hood on my 57 pickup and remembered the springs seemed weak so I installed a set of new reproductions springs. The problem is they don't hold the hood up very well. Was this a common problem on these trucks? Thank You Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
04-20-2024, 01:30 PM | #2 |
Re: Hood Springs
new springs should be more than plenty strong to hold up a hood.
i've seen guys undercoat the underside of the hood and it makes the hood to heavy anything on the underside like bedliner or a gallon of bondo/filler?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-20-2024, 05:15 PM | #3 | |
Re: Hood Springs
? I can't remember where I got the springs but if someone knows which ones they used and worked it would be helpful. Steve
04-20-2024, 08:19 PM | #4 |
Re: Hood Springs
I have new springs and no filler with new paint on both sides and mine stays up fine on my 59 GMC.
Did you install new hinges or lubricate? I may have gotten mine from LMC or classic industries.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 04-20-2024 at 08:28 PM. Reason: pics |
04-21-2024, 08:57 AM | #5 |
Re: Hood Springs
Hi, These are original hinges I bead blasted and painted. When I got the truck the hood barely stayed up on its own. I bought a set of springs and it seemed the same. I just ordered another set of springs OER brand and will see if it makes a difference. Thank You for the information. Steve
04-21-2024, 09:26 AM | #6 |
Re: Hood Springs
My hood does the same thing. I replaced the springs as well, with new ones, and it will not stay open. I gave up and use a wood prop to hold it open.
04-21-2024, 01:28 PM | #7 |
Re: Hood Springs
paint and a little filler shouldn't be a problem. dennislbrooks and my 58 TRUK both have different hinges and springs than the 55-57 trucks, maybe you have the 58-9 springs? call LMC and ask about their hood springs, buy and install within the return window
04-26-2024, 08:19 PM | #8 |
Re: Hood Springs
Update on this thread. I received the OER brand hood springs today. Got them installed and the hood stays up fine now. I don't remember what springs I bought originally. The OER brand worked so I am happy. Steve
04-28-2024, 06:49 PM | #9 |
Junior Member
Re: Hood Springs
Not sure if this helps, but the 55 and 56 Chev cars are the same hinge, however the spring is heavier on the 56 because of the extra weight added to the hood because of chrome pieces. I wonder if that's true of the trucks. The hinges maybe the same but you could get a heavier spring. Just a thought
04-30-2024, 09:29 AM | #10 |
Re: Hood Springs
one more thing off the list, awesome.
good info sarblade, funny the little things you learn as you go through the threads |
04-30-2024, 11:44 AM | #11 |
Junior Member
Re: Hood Springs
I know eh!
