Old 04-22-2024, 10:20 AM   #101
loudchevy
Active Member
loudchevy's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
I wasn't gonna do anything with the bed for a while, but I needed a change of scenery from bodywork. It's only going to get warmer from here out in Phx (90*ish in the garage already) so I decided to break down the bed so I can get it cleaned up and shortened. I only got (4) carriage bolts to come off cleanly. The rest took a combination of drilling, grinding, punches, and a BFH. The best approach was cutting a slot in the top to use a flathead screwdriver to hold the bolt and impact the nut off from the bottom, but that didn't always work out as some the bolts couldn't get a cutoff wheel on them. Overall, it took around 5 hours to break the whole bed down. If anyone needs the fiberglass toolbox insert that comes with the LWB toolbox option, hit me. The one I removed is in good shape.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 04-22-2024, 10:27 AM   #102
loudchevy
Active Member
loudchevy's Avatar
Couple more pics....I also removed the stake pockets from the driver's side panel. I was going to cover the openings on the top rails anyways. The passenger side panel is banged up around the wheel well and it has the giant opening from the toolbox, so I'm not going to cut that side down. I'll be looking for a LWB or even better SWB panel to use in its place. The crud pile from the bottom of the bed was smaller than I thought it would be. At least it's a dry heat, right?
Scott
2003 Tahoe Stock
Old 04-22-2024, 10:44 AM   #103
raggedjim
raggedjim's Avatar
Nice work, it always amazes me how much crap can be hiding in the nooks and crannys!
In western KY it's 55 with 43% humidity!
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-23-2024, 08:12 AM   #104
Chaparralman1974
Chaparralman1974's Avatar
Great work Scott! Tearing down the bed is more work than it looks. It took me all day to do mine doing the same thing you did.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 04-23-2024, 10:45 AM   #105
loudchevy
Active Member
loudchevy's Avatar
Rg
Clay
Thanks Gents.
Scott
2003 Tahoe Stock
Old 05-20-2024, 09:48 AM   #106
loudchevy
Active Member
loudchevy's Avatar
Life gets in the way and truck projects get moved to the back burner just like everyone else here knows. The boy and I finally got around to taking apart the cab, fenders, hood, and doors into their individual pieces for what I hope is the last time. I spent all day Saturday prepping the garage for sealing and high build primer on the doors and fenders to be ready to spray on Sunday. I wanted to be able to spray both sides of the doors at the same time, so I built up some redneck panel holders out of my sawhorses with some long 2x4's lol.
First coat was a reduced epoxy primer layer to seal up the exposed metal and filler. I waited 30 mins and then sprayed the 1st coat of the Eastwood 2K Urethane with a little bit of reducer on all 4 pieces, waited another 15 mins, and did the same mixture for the 2nd coat. The final coat of Urethane was straight 4:1 with no reducer. It was super nice spraying the high build primer on the panels. I had zero issues using my cheap Amazon A610 gun with the 1.7 tip. It's super rewarding to see the panels with their final primer sprayed on. Are they 100% prefect and show quality, no, but I did all the work myself and learned a **** ton in the process for which I'm very happy about.
My hood and cab still need some attention. When taking apart the truck I noticed a couple of places on the hood that I missed putting filler on. The cab still needs to be seam sealed on the drip rail and the other joints around the door frames, and front windshield. I'm going to try and get the hood and cab sanded and ready for the same sealing/Urethane spraying this weekend.
Scott
2003 Tahoe Stock
Old 05-20-2024, 11:31 AM   #107
Chaparralman1974
That thing is looking great Scott! I am going to go ahead and order the same gun from Amazon. My HF purple gun is ok, but I want something just a little bit better. When do you think you will lay down the color?
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 05-20-2024, 01:26 PM   #108
loudchevy
Active Member
loudchevy's Avatar
Clay
Thanks Clay, Not sure when color is gonna get sprayed. We still need to pick a color . After this long 3 day weekend, my next couple of weeks are busy so it might be a little bit longer than I would like to get back working on the truck.
Scott
2003 Tahoe Stock
Old 05-20-2024, 03:29 PM   #109
rodstored-72
chevy truck fan
rodstored-72's Avatar
scott, progress is looking really nice & moving along, thanks for keeping us posted i think you and chaprralman are moving nicely along...
rodstored-72 is offline   Reply With Quote
Old 05-20-2024, 10:07 PM   #110
zicc1835
zicc1835's Avatar
well good to hear your back in it.... lookin good
zicc1835 is offline   Reply With Quote
Old Yesterday, 12:20 PM   #111
loudchevy
Active Member
loudchevy's Avatar
Thanks! Chaparralman1974 and I like to text each other about how much we enjoy doing bodywork
Scott
2003 Tahoe Stock
Old Yesterday, 12:21 PM   #112
loudchevy
Active Member
loudchevy's Avatar
Thank you, Sir
Scott
2003 Tahoe Stock
