Old 03-10-2024, 11:22 AM   #1
bry593
Thumbs up 1967-72 Chevy Axle Swap to 9.5", 14-Bolt w/ Disc Brakes
How I installed a 90's, 14-bolt, semi-float axle in my 1971 C20 pickup. This swap maintains the original axle width (65 1/4") and adds 13" disc brakes. All parts are GM so it will be reliable and work great.
Axle = 1989 - 2000 Chevy & GMC light duty 3/4 ton with drum brakes. 2WD and 4WD are same width if 13" drum brakes.
Disc Brakes = Early 2000's Chevy & GMC light duty 3/4 ton. Calipers mounted on back side so parking brake cable routes correctly.
Other necessary parts:
1. Axle perches cut for 3 3/8" axle tube
2. Laser cut brake mounting flanges (1/2" thick)
3. Laser cut backing plate concentric rings (3/16" thick)
4. 3/16" custom brake line kit and 3/16 to 1/4 adapters at distribution block
5. 2X LH brake hose from 2001 C2500
6. 2X LH parking brake cable from 2001 C2500
7. 9/16" wheel studs for 80's 9.5" axle
https://www.youtube.com/watch?v=e-AF0CLiAQA&t=638s
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 03-10-2024, 12:05 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 1967-72 Chevy Axle Swap to 9.5", 14-Bolt w/ Disc Brakes
Great Video of the swap.
That was a very clean install.
Which Auxiliary tank is in your truck?
84 Chevy K-20
Old 03-11-2024, 10:24 PM   #3
bry593
That was a very clean install. Thanks! I spent way too much time on it.
I don't know. I'd guess a dealer installed addition. Poorly done. I never use it. Will be removed soon enough.
Old 03-11-2024, 10:53 PM   #4
Getter-Done
There is a Thread about NL2 options.
This is what Sparked my interest.
Does your Glovebox list this tank on the SPID?
84 Chevy K-20
Old 03-20-2024, 01:29 PM   #5
bry593
No, no option code on the glovebox decal.
It is poorly mounted. You can't even get a gas cap onto the filler neck because it is too close to the bed wall.
No sending unit, just a hose going to a tee valve. I stripped all that stuff out soon after I bought the truck. Just haven't gotten around to removing the tank.
Old 03-20-2024, 01:33 PM   #6
bry593
I should mention that I had to run 1/4" spacers to fit my old school 16x6.5 GM wheels. The calipers hit on the side of the center drop of the rim. I also used 1/4" longer wheel studs from the front hub of 80's model Chevy 1 ton to provide sufficient thread engagement to lug nuts.
After trying a Ford 16x7 (90's issue), I found the same problem. Later model GM wheels are designed differently in this area and would not require spacers. For example the 16x6.5 2500HD aluminum wheels should bolt right on.
Old 03-20-2024, 01:42 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
I did something semi similar a few years ago and mounted the late model disks to an old school 80’s 14 bolt FF from a K30.
Nice work on your swap!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-23-2024, 12:25 PM   #8
bry593
Thanks!
I've got about 500 miles on it so far and I'm very pleased with the results!
It is very quiet and smooth compared to the HO52. I think shimming the carrier bearing also helped with the NVH. I've got the trans and first shaft at 4 degrees down, the axle pinion at 4 degrees up. Haven't checked to see what the second shaft angle is, but it is clearly very slight. For those who say you shouldn't have the first shaft and trans in-line, it's really not an issue. It isn't perfectly in-line and only a 1/2 degree or so is needed to keep the U-joint needles spinning.
Handling is improved, likely due to the track bar rebuild.
It certainly takes the bumps better with the lighter axle. Used to be a bump at 80 mph would really kick the tail end up in rebound.
The brakes are bedded in and seem to work better than the drums as far as being able to modulate. There's a fine line between on and locked up with drums since they are self energizing.
Happy to report my wheel spacers are not causing any issues, no vibration. I did buy some PYO wheels (2500HD) at the swap meet last weekend and these would eliminate the need for spacers altogether. But, not sure I want to give up the awesome look of the classic steelies and caps.
Gas mileage is improved although I'm not sure what I'll peak at. Still messing with the transmission programming to get the shift points, tcc disengage and lockup right where I want it. Should have that sorted this week.
