Old 03-29-2024, 11:39 AM   #1301
SCOTI
SCOTI's Avatar
Re: SkinnyG's '61 Apache
So much yes.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-29-2024, 02:27 PM   #1302
Braunschweiger
Beautiful.
The weather is also good.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 03-31-2024, 11:36 AM   #1303
SkinnyG
SkinnyG's Avatar
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 03-31-2024, 11:59 AM   #1304
Braunschweiger
There is room for a lot of stuff, the trailer is quite large.
Greetings Harald
My 62 build thread
Old 03-31-2024, 09:53 PM   #1305
SkinnyG
SkinnyG's Avatar
Something went "BANG."
Old 04-01-2024, 12:21 AM   #1306
SkinnyG
SkinnyG's Avatar
Some poop came out.
Turns out the engine sucked apart the Edelbrock air filter, the metal cap inside went into the turbo, and I'm hoping didn't do too much damage....
Off to LordCo tomorrow to see if I can get a K&N that DOES NOT have a suckoffable cap inside.
Old 04-01-2024, 06:34 AM   #1307
350TacoZilla
Wow that could have been bad. I think you got lucky by the looks of it but I would probably still take compressor apart and clean it out and either sand the impeller or replace so no loose bits come off. I always worried about those suckoffable caps since they look to just be glued in but since thats how all the pleats are held in with the metal base air filters I try to grab the ones that are all molded silicone\rubber style material.
350TacoZilla is offline   Reply With Quote
Old 04-06-2024, 10:32 AM   #1308
SkinnyG
SkinnyG's Avatar
Old 04-06-2024, 10:36 AM   #1309
SkinnyG
SkinnyG's Avatar
Odd. My videos are not embedding...
Old 04-06-2024, 11:19 AM   #1310
Braunschweiger
You've been very lucky with that.
Greetings Harald
My 62 build thread
Old 04-14-2024, 10:03 PM   #1311
SkinnyG
SkinnyG's Avatar
Chasing an increasingly noisy Hydroboost pump.
I've bled it every which way under the sun, but cannot get it to stay quiet for more than 40 minutes of driving. I ordered a new pump.
RockAuto wholesaler closeout, got the pump for $58CDN (about $40US). Two days of anger management issues and profanity, and it's in and bled, and appears to be working great.
At one point I had to turn the "Blues" off on the stereo, as the songs were just too dang "happy." Black Sabbath to the rescue.
And had a visit from a friend today:
Old 04-17-2024, 09:45 AM   #1312
SkinnyG
SkinnyG's Avatar
I seem to be losing spark, more and more - especially worse the hotter it gets / the more I drive. Definitely missfire.
I've checked plugs. I've changed wires. I'm thinking coils.
Old 04-18-2024, 07:21 AM   #1313
joesscamaro
I'm curious, what spark plugs, wires and coils are you running?
joesscamaro is online now   Reply With Quote
Old 04-18-2024, 09:33 AM   #1314
caseyjones
Maybe it’s a cam or crank position sensor?
caseyjones is offline   Reply With Quote
Old 04-18-2024, 10:39 AM   #1315
SkinnyG
SkinnyG's Avatar
Stock 585 coils (round with heat sink), used Delco wires, after running new "Fast" brand wires. NGK TR6 plugs.
A cam or crank sensor should have a code, and will _not_ produce a STFT +15% on bank 2 only (lean misfire).
Old 04-28-2024, 10:57 PM   #1316
SkinnyG
SkinnyG's Avatar
Found two COOKED plug wires on the passenger side. I definitely need to source some LONG wires to route them around the flipped exhaust manifold rather than under them.
I went back to the "Fast" wires I had made (they were longer on the passenger side, but I pulled them thinking they were causing an issue - I'm not sure they were....). Runs MUCH better now. We'll see how long they last.
Old 05-02-2024, 10:22 PM   #1317
SkinnyG
SkinnyG's Avatar
Five. Five! FIVE!! glorious commuting days in a ROW, with not a single "Oh what the hell is wrong with it now?!"
I'm going to have to buy a lottery ticket.
Old 05-03-2024, 08:03 AM   #1318
Braunschweiger
It's the little things that make us happy.
Greetings Harald
My 62 build thread
Old 05-04-2024, 01:15 PM   #1319
SkinnyG
SkinnyG's Avatar
Speaking of joy....
Posted the video of taking my son out to buy a '68 Catalina:
Old 05-19-2024, 12:36 AM   #1320
SkinnyG
SkinnyG's Avatar
My son and I at the local hill climb car show:
Old 05-19-2024, 07:21 PM   #1321
SkinnyG
SkinnyG's Avatar
This just in: 13.7mpg if I stay under 10inHg vacuum and never accelerate.
Old 05-19-2024, 09:21 PM   #1322
SkinnyG
SkinnyG's Avatar
I fueled up with Chevron 94 yesterday. I tune on 91, but run 94 for a bit more safety. We have no E85 here. 94 was $2.049/L. $7.76CDN a gallon, or $5.72US a gallon.
You can see why I daily a Hyundai Accent now, eh?
This is an LQ4, pushing a brick. A brick in the shape of a parachute. A 2003 Silverado with a 6.0 is rated at 10mpg city, 11mpg highway.
I'm doing REALLY good, now that I see that.
Old 05-21-2024, 02:30 PM   #1323
350TacoZilla
I mean considering the extra Hp you have vs a stock silverado I'd say your winning but I'm not sure the weight difference and brickness difference lol. I have an LS swap that I had started gathering parts for years ago that I hope actually increases MPG but I dunno when I'll ever get on it again. 4.8 and 5spd into a 97 reg cab toyota tacoma in place of its 2.7L that was somehow managing 13mpg last time it ran.
Old 06-01-2024, 04:13 PM   #1324
SkinnyG
SkinnyG's Avatar
Old 06-09-2024, 12:33 AM   #1325
SkinnyG
SkinnyG's Avatar
I finally got around to doing a video on "decapping" injectors.
This is a process of removing a "diffuser" on the end of most LS injectors, and turns your 24lb injector into roughly a 75lb injector. ECU tuning required.
I'm running decapped injectors in my '61, and they work fine.
