Old 03-18-2024, 03:07 PM   #551
LockDoc
The Older Generation
LockDoc's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
I re-tested the gauges again using Patrick's suggestion. I meant to post a close up of the labeled gauge yesterday but forgot to. (picture 1)
Picture 2 is the overall view of the connections.
Picture 3 is a close up of the connections with the extra, stock 90 OHM resistor added.
Picture 4 is the readout on an old gauge I have
Picture 5 is of the gauge in my good cluster.
Instructions are the same as before, just with the extra resistor added.....
Leon
Old 03-18-2024, 03:26 PM   #552
pjmoreland
pjmoreland's Avatar
Looks good!
pjmoreland is offline   Reply With Quote
Old 03-18-2024, 09:40 PM   #553
Getter-Done
Getter-Done's Avatar
Great Information.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 03-18-2024, 10:27 PM   #554
LockDoc
LockDoc's Avatar
Originally Posted by pjmoreland View Post
Looks good!
Originally Posted by Getter-Done View Post
Great Information.
Thanks guys.
Leon
Old 03-20-2024, 08:21 PM   #555
LockDoc
LockDoc's Avatar
Installed the headlight relays today. Pretty straight forward if you follow the instructions on the board. You can buy the kits from almost every truck parts supplier or put your own kit together from junk yard parts.
Below are the diagrams. First one is Chevy, second one is GMC
Leon
Old 05-16-2024, 09:58 PM   #556
LockDoc
LockDoc's Avatar
Picked up a 4.10 gear for the Dually HO72, to replace the 5.14. It should drop the RPM and help the mileage some. I need to get a new pinion seal for it.
Leon
Old 05-16-2024, 10:43 PM   #557
3757chevy
3757chevy's Avatar
Nice , good info. Thanks
Very nice , should help a bunch.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-17-2024, 12:08 PM   #558
LockDoc
LockDoc's Avatar
Thanks. I will know in a few days....
Leon
Old 05-17-2024, 01:01 PM   #559
Getter-Done
The 4:10 will be a nice addition.
I am guessing 2200 RPM at 70MPH.
84 Chevy K-20
Old 05-17-2024, 04:07 PM   #560
LockDoc
LockDoc's Avatar
Thanks, I hope so.
Leon
Old 06-01-2024, 11:30 PM   #561
LockDoc
LockDoc's Avatar
I've been working on the replacement 4.10 center section for the rear end. I not only had to replace the pinion seal but I also had to install a pinion seal repair sleeve. I could tell when I looked at it that the seal was going to need replaced. The yoke had a pretty good groove in it when I disassembled it. I filled it with JB Weld and installed the repair sleeve while the epoxy was still wet.
I only had to pull the axles out far enough to clear the center section when I removed it..
I had to figure out how to get the center section up in the air far enough to get the transmission jack under it so I put a piece of steel pipe across two of the frame cross members and put a rachet strap over the pipe and around the bottom of the center section. I just tightened the rachet strap up until the center section was high enough to get the jack under it. I cut the heads off of 2 bolts and screwed them into the housing to use as guide pins to locate the center section. (you can see one of them in the 8th picture) When I got it high enough I just slid it onto the pins and put the bolts in. Before I slid it all the way back I put some "Right Stuff" sealant on the gasket.
The rest of the pictures are the gasket, and specs on the gasket, seal, and repair sleeve.
Leon
Old 06-01-2024, 11:32 PM   #562
LockDoc
LockDoc's Avatar
Pictures.
Leon
Old 06-01-2024, 11:34 PM   #563
LockDoc
LockDoc's Avatar
More pictures.
The pinion seal and pinion repair sleeve were ordered from Rock Auto.
Leon
Old 06-02-2024, 10:22 AM   #564
Getter-Done
Nice work on the Rachet strap lifter device.
30 years ago, you would have done that differently?
84 Chevy K-20
Old 06-02-2024, 11:59 PM   #565
LockDoc
LockDoc's Avatar
You got that right. Now I have to use my brain more and my muscles (that I don't have) less....
I haven't checked my mileage yet but it dropped my RPM to about 1950 RPM @ 60 mph.
Leon
