Old 06-16-2002, 11:18 PM   #1
68 with 350 TPI
68 with 350 TPI's Avatar
Question Anyone have any ideas for a shorter steering column?
I was thinking about how my truck feels vs my camaro and I like how in the camaro I can stretch my arm out a bit to reach the steering wheel.
In my truck it seems that the wheel is almost in my lap and I would like it to sit back a bit further.
I was thinking about using a tilt but now I think I would just like the factory one shorter.
Any ideas?
Can you cut it out a bit and do some welding etc?
I was thinking if I could just get it down to where the column starts to tapper just behind the turn signal that would be great
and it would put the wheel alot closer to the dash.
Thanks for any input.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 06-17-2002, 01:15 AM   #2
Bowtie468
Bowtie468's Avatar
68 with 350 TPI Take a look at Big Orange's '71 Surburban. It's running a column from an "89 Cavalier. Looks a little shorter to me. Looks like the steering wheel doesn't have as much "standoff" as the factory wheel. Hope this helps ! Click on " Bad Burban" and scroll down to photos.
www.classictruckworld.com
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 06-17-2002, 01:25 AM   #3
68 Suburban
68 Suburban's Avatar
I felt the same way and put a steering wheel out of a 92 Chevy truck n my truck. It made a big difference in comfort.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-17-2002, 09:54 AM   #4
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
Ok, here's what I did. Remove the column. Drill the rivets in steering shaft out. Stand steering column on end and pound the shaft down to shorten to desired length. I shortened mine 5", now the wheel is a full arm's length away.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 06-17-2002, 11:17 PM   #5
68 with 350 TPI
NSANE 68,
Do you have any pics of this???
I was thinking about doing something like that but I wasent sure it would work.
Old 06-18-2002, 12:32 AM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
Sounds like you should get youself a van tilt. They look close enough like the truck tilts for a lot less money, and you can install them closer to the dash. Look at Chevy/GMC vans up to the late 70's with ignition on the dash.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-18-2002, 03:47 AM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I think the van is a little longer than the truck, but you can move the columns down until the neutral switch hits the floor...and the van neutral switch is higher on the column. The wires/connectors are different from van to truck...so cut & splice is called for. Might work after you collapse the intermediate shaft.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 06-18-2002, 05:27 AM   #8
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Virtually all GM columns will collapse by shearing off the nylon 'rivets' that hold the collapsing portion of the column together. The main difficulty in getting a 'farther away steering wheel' is what to do with te shifter cylinder, it will not clear the dash without chewing up the dash panel.
Either enlarge the dash panel to accept pushing the column foreward, get a wheel with a different 'dish' (backspacing), or go floorshifter, and get rid of column shifter,.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 06-18-2002, 10:59 AM   #9
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
Sorry I don't have any pics. But that is exactly what I did. B&M Truck Megashifter on the floor, and smooth column, drilled the rivets and colapse till you are satisfied. Even the van tilts will need colapsed a little. I saw the van tilt done in Classic truck tech article 2-3 yrs ago. That's how I got the idea to colapse the steering. Good luck
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 06-18-2002, 12:58 PM   #10
68 with 350 TPI
Thaks guys
Im gona give it a try.
Old 06-18-2002, 01:50 PM   #11
Desert Rat
Desert Rat's Avatar
think id get a tilt,and shear off pins oush to firewall till safety swith hits,can always relocate upwards on column,might affect dangle of shift linkage think id put in a tilt and flop it up
Desert Rat is offline   Reply With Quote
Old 06-18-2002, 04:31 PM   #12
68 with 350 TPI
Shift linkage is no problem as Im going to put in a floor shifter
But thanks for the advise.
Old 06-18-2002, 05:33 PM   #13
Desert Rat
Desert Rat's Avatar
How about a Cadillac tilt telescoping wheel,or vette column,caddy be cheaper.i lowered my column a little,a buddy of mine is like way up in the chest,mine i can kick back,drop an arm out the window,rollin on my 15x8 Rallys pimpin through the hood.
Old 06-19-2002, 01:06 PM   #14
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
You can add telescope to any gm tilt column by getting everything from the u-joint up. There were 2 different length telescope options. I have tilt/telescope column shift in my 66 panel, but used mazda controls on the column so I'd have wiper and light controls handy. Use the cruize set button to kill tail lights, handy for flashing big rigs, and cruize on/off to toggle fog lights, never have to lean to dash.
but on the 68 c20, tilt adds just too much top length, and I undid that and used flat disk 'eurosport' wheel out of chevy station wagon
here is the 66 setup
Nevada City, CA
Everett, Washington
