Old 06-22-2002, 02:11 PM   #1
bluzman2004
Talking Bed Cover Info
I just finished installing my new bed cover. I read on here where someone else had one of these, so I looked into it. I ordered a CheckMate FX soft cover. I order a custom color other than the standard black one, so that added $10 to the cost. Shipping was fast and costed $22. Total to the door was $191.75. No holes to drill either. Just incase someone wanted to know about these.
69 Chevy ProStreet, Low and wild.
78 Corvette
rturnpaugh@compcams.com
bluzman2004 is offline   Reply With Quote
Old 06-22-2002, 02:22 PM   #2
colohusker
That looks great! I like the low profile, don't really care for the ones that stick up.
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 06-22-2002, 02:41 PM   #3
bluzman2004
This only sticks up about 1/4" if that. It has bows inside to keep is flat too. NO SAGGING or FLAPPING!
Hey Husker, we're not too far apart. I'm down here in Colorado Springs. Cool.
78 Corvette
Old 06-22-2002, 06:58 PM   #4
Slick71
Slick71's Avatar
I like the idea of no holes to drill. How exactly does it fasten in?
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 06-22-2002, 07:01 PM   #5
Chevyc10!
Chevyc10!'s Avatar
Ya how about some tech tips on the install...
For the price, It looks like a bargain.
68 SWB
The Surgeon General doesn't say anything about smoking a Ford!!!
Would rather be ran over repeatedly by a Chevy than drive a Ford!!!
Paralyzed from the neck up and confined to a hat!
Kathleen, Georgia USA
Chevyc10! is offline   Reply With Quote
Old 06-22-2002, 10:29 PM   #6
colohusker
Yep, only a couple of hours away. Maybe I can make down some time to check out your truck, looks great with that cover!
Longmont, CO
Old 06-22-2002, 11:20 PM   #7
bluzman2004
The cover only took about 2 hours to install. Basically, you just just put together four aluminum frame pieces. Then lay it on top of the vinyl and fold the vinyl over the frame. You install an long "L" strip over the vinyl, pull it tight and screw in the screws. There are extendable aluminum tubes called bows that help tighten the vinyl that you insert in side the frame. Lastly, you install a foam adhesive tape to the frame set it inside the bed.
It uses a "C" camp type of device to hold it to the bed frame rails. You do have slide into the bed to tighten the clamps. (A real pain with my wheel tubs!!)
Over all, it is really a nice piece.
Here's another pic of it.
78 Corvette
Old 06-23-2002, 03:05 AM   #8
OhioDan
OhioDan's Avatar
Could ya still use something like that if you had relocated your tailgate latch to the inside of the tailgate. Just wondering if it would work on mine?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 06-23-2002, 06:28 PM   #9
72chevyLWB
Got 20's????
72chevyLWB's Avatar
does it roll up? I like it because its flush is all. other than that i have the access cover. Does it seal up? I also have shaved the tailgate handle so can I still get in?
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 06-23-2002, 09:29 PM   #10
bluzman2004
With my particular cover, if you don't have an outside tailgate latch, you can't open it. Sorry. They do make one that has latches, hinges, and shocks that will let you open it. You would have to check with them on the exact operation feature of that one.
These do seal. They have a foam, single sided tape that you install around the cover. It seals to the bed and tailgate, but doesn't actually stick to the bed.
I don't use my bed that much except for things that would fit behind the wheel tubs. It is kinda like a trunk.
I drove it on the highway today and had no problems and no flapping.
78 Corvette
Old 06-23-2002, 09:59 PM   #11
Benrs86
Benrs86's Avatar
so you cant open it unless you take the whole thing out? i was lookin into the hinged one, but i didnt htink it came over the bedrails at all. and pics of the frame of it? thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-23-2002, 11:21 PM   #12
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
Those clear tail lights look cool.Makes the rear look diferent.
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
