Old 10-27-2008, 11:46 PM   #251
56chevy1300
56chevy1300's Avatar
Re: My Project 56Chevy1300
Finally work starts on the 4 link.
56chevy1300 is offline   Reply With Quote
Old 10-27-2008, 11:48 PM   #252
56chevy1300
Ride height.
Old 10-28-2008, 12:29 AM   #253
Kim57
Kim57's Avatar
I've reading this thread for a while now and your truck is looking really good. The ride height looks nice.
Kim
Kim57 is offline   Reply With Quote
Old 10-29-2008, 01:27 PM   #254
rockdogg
rockdogg's Avatar
very awesome step by step write-up with pics. I'm currently working on a like project. we have only owned our 56 since may of this year. already picked up a camaro subframe and looking into motors and rear axle upgrades. will definately keep an eye on this posting and post up some of my own upgrades as well. our truck is in the avatar.
rockdogg is offline   Reply With Quote
Old 10-30-2008, 11:25 AM   #255
56chevy1300
Thanks for the comments Kim and Rock...I enjoy sharing my project with you guys...good luck with your own projects. This is a great site to get advice from when needed. Rock, there is a truck in my town here that is almost identical to yours...I'll see if I have a pic when I get home.
Old 10-30-2008, 11:32 AM   #256
CAL 58 GMC
CAL 58 GMC's Avatar
Originally Posted by 56chevy1300 View Post
Hey Dave, hope these help. There's about 3/4 to 1" clearance. I added a 1/8" spacer between the crossmember mounting bracket and the frame. I also welded the driver's side bracket to the crossmember as I cut a little notch out of it. I'm not sure if I can weld the other side...don't know if I could take it off if it was welded since its on the inside of the frame.
Thanks 56Chevy! This winter I'm going to re-work my cross member like yours. Right now mine hangs down way to low and bottoms out unless I have the bag aired up most of the way, then it rides like a 3 ton truck.
CAL 58 GMC is offline   Reply With Quote
Old 10-30-2008, 12:18 PM   #257
56chevy1300
Hey Dave I'm just about to order some headers...I know you said you have camaro shorties...any other advice for me in choosing a set? What collector size should I go...2.5" or 3.0"? Did you have any clearance issues? Thanks!
Old 10-30-2008, 07:34 PM   #258
56chevy1300
I couldn't wait for Dave's response...I bought a set of Hooker 2466's but as you can see I have some clearance issues...there's only 1/4" between the ps pump bracket and 1/4" between the steering shaft and the collector is making contact with the tranny housing...any thoughts?
Old 10-31-2008, 12:02 AM   #259
OrrieG
OrrieG's Avatar
It looks like the PS pump bracket hole lines up with the header hole like it should, longer bolt and shim between the header and bracket is required. Once bolted down the PS pump and bracket will move relative to the engine and header.
At the steering shaft the engine, if it moves very much, will move away from the steering, perhaps a mount on the other side to limit return rotation so it does not hit the shaft. It seems I have seen other applications where they dimpled the header (not recommending that).
At the trans ear, does the flange rotate so a skinner section misses the trans ear? It looks in the photo like it need to move down the exhaust flange?? Once installed the header, exhaust pipe and trans should move at the same rate too.
Just my thoughts..
OrrieG is offline   Reply With Quote
Old 10-31-2008, 03:44 AM   #260
watahyahknow
watahyahknow's Avatar
cant you just cut off or remodel that lip on the tranny , doesnt seem to attach to anything
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-31-2008, 10:26 AM   #261
rockdogg
rockdogg's Avatar
looks to me, that is where the trans-cover goes to cover the bell-housing and torque converter at the trans to engine mount-up.
Old 10-31-2008, 01:51 PM   #262
56chevy1300
OrrieG, yes the flange rotates, thanks! Wata, that is the mount for the inspection cover.
I am most concerned with the steering shaft. I only have about 4" between the shaft and the block at the exhaust port.
I think I'm going to return these and order the huggers, 2100HKR.
Thanks again for the help.
Old 11-01-2008, 01:19 PM   #263
rockdogg
rockdogg's Avatar
Hi 56chevy1300, love your write up going to be looking for those tapes on the sub-frame install.
here's a full size photo of our truck.
the worst part is that it still has the original suspension with a 500 ci eldorado motor. makes for some interesting driving.
Old 11-01-2008, 07:19 PM   #264
56chevy1300
Nice ride Rockdogg! Here is a pic of a similar ride in my home town, pretty close, eh?
Old 11-02-2008, 09:23 AM   #265
55dude
55dude's Avatar
if you go with the blockhuggers you will need a late model starter as the early hi-torque ones are about 1/4" too long. ask me how i know.
55dude is offline   Reply With Quote
Old 11-02-2008, 04:23 PM   #266
rockdogg
rockdogg's Avatar
yeah, pretty close. at first I was alittle confused with the bumper, then I realized it's a GMC.
it actually has a Dodge box on it, looks OK, might look into changing it back to original style.
Old 01-01-2009, 05:59 PM   #267
56chevy1300
Upgraded to 7" Slam Specialties bags up front...had to rework the cups because these bags are much bigger than the 6" Firestones I previously had.
Old 02-01-2009, 06:59 PM   #268
56chevy1300
I decided to hire out some help with the brake lines, wiring harness, air ride system, fuel lines, steering etc. from a licensed mechanic I met through the local hot rod association. This guy does some awesome work.
Old 02-01-2009, 07:07 PM   #269
56chevy1300
Pic 1 - check out these slick hose clamps
Pic 2 - powdercoated headers
Pic 3 - front shocks
Old 02-01-2009, 07:13 PM   #270
56chevy1300
Pic 1 - modified air bag crossmember
Pic 2 - brake lines, fuel lines, air lines, emergency cables installed
Pic 3 - (right of booster) cruise control controller
Old 02-01-2009, 07:17 PM   #271
56chevy1300
wiring harness install started
Old 02-01-2009, 07:19 PM   #272
56chevy1300
Changed to tilt steering; you can also see the air ride controls.
Old 02-01-2009, 07:38 PM   #273
JML55
JML55's Avatar
Cool work, looks great.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 02-02-2009, 01:02 AM   #274
nuke1
nuke1's Avatar
looking good, you just may hear her soon
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-12-2009, 09:32 PM   #275
56chevy1300
done
