Old 12-21-2006, 01:50 PM   #1
56chevy1300
56chevy1300's Avatar
My Project 56Chevy1300
It all started when I bought my first Truckin’ Magazine when I was 13. That was 20 years ago.
I’ve always liked the styling of the 55-59 Chevys and GMC’s and wanted to build something my way, but not from stratch. So I found this 56 Chevy pickup in October 2005 that was restored back to stock by the previous owner.
My plans include updating the drivetrain and suspension by dropping in a 350 V8 with automatic, Camaro IFS, Camaro rear axle, 17” wheels, power steering and power brakes in an attempt to build a reliable daily driver.
I’m already into my project 14 months, so I have lots of progress made.
I will be looking for advice and input as I go along.
Enough babble.
Enjoy the pics!
Ross
Here are pics of the back-to-stock restoration done by the previous owner:
56chevy1300 is offline   Reply With Quote
Old 12-21-2006, 03:33 PM   #2
67-72chevyman
Re: My Project 56Chevy1300
Thats a good lookin truck, I always liked the "task force" style trucks, especially the 55-57s.
67-72chevyman is offline   Reply With Quote
Old 12-21-2006, 04:11 PM   #3
Jebb1978
Jebb1978's Avatar
Beautiful truck! Can't wait to see what she looks like when your done.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 12-21-2006, 04:41 PM   #4
texascowboy593
texascowboy593's Avatar
I like it!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 12-21-2006, 04:50 PM   #5
56chevy1300
Thanks guys. Jebb, you are one of the guys that inspired me to start my own thread!
Here are pics a few weeks after I brought her home.
The color is called "Medium Juniper", an GM color of the 50's (from what I'm told).
This was the previous owner's retirement project. I told him what my plans were for the truck and he was okay with it!
Old 12-21-2006, 06:00 PM   #6
56chevy1300
I hate to separate the original motor from its home but its gotta go!
Old 12-21-2006, 06:17 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Nice work!!
dwcsr is offline   Reply With Quote
Old 12-21-2006, 06:18 PM   #8
56chevy1300
First I tacked a 34" length of 1" ID square tubing across the frame at a specific point (22" from the axle centerline) to help stabilize the truck frame and act as a reference point for all measurements; then sliced off the front frame section (10" from the reference point -- square tubing) to make way for the Camaro subframe; now I'm officially beyond the point of no return! Part of the front frame section will be used as boxing plates and the front 12" or so will be welded onto the front of the Camaro subframe.
Old 12-21-2006, 08:09 PM   #9
56chevy1300
This subframe is from a Trans Am. I don't know the exact year, I bought it from a wrecker. It features a quick ratio steering box and a huge 1 1/4" sway bar.
Old 12-21-2006, 09:46 PM   #10
texascowboy593
Nice! Keep those pics coming!!!
1977 Silverado K10
Old 12-21-2006, 10:07 PM   #11
56chevy1300
After completely disassembling the subframe, I sent it out for acid dipping and sandblasting...best $90 I ever spent! I pre-cut the frame at both ends before dipping.
Old 12-21-2006, 10:14 PM   #12
56chevy1300
As soon as the subframe returned home, I sprayed it with epoxy primer/sealer.
Old 12-21-2006, 11:01 PM   #13
56chevy1300
The next step was to take out 1 1/2" out of the rear frame ends so that the subframe will fit inside the truck framerails; fit like a glove the first time (the truck framerails have been widened 1/2" on each side).
Old 12-22-2006, 10:31 AM   #14
Jebb1978
Jebb1978's Avatar
Wow, dejavoo? Looks like mine just a few months back. Looks like a nice clean job so far. Keep em comming. That swaybar is rediculous! I love it!
Thanks for the props, it's funny to me that my thread is anyone's inspiration to start one because Cal58GMC was my inspiration to get started.
1959 GMC project
Old 12-22-2006, 01:57 PM   #15
56chevy1300
I know Jebb, it gotta weigh between 25 and 30 lbs! Here are pics of the trans crossmember and spring perches being removed...probably the toughest task so far.
Old 12-22-2006, 06:21 PM   #16
56chevy1300
So tell me if I'm posting too many pics (I probably have a thousand!).
Okay, before the subframe went it, I smooth the firewall (there were about 30 holes to fill!). I triple checked to make sure the truck frame & subframe were level and laid the welds.
Old 12-22-2006, 06:55 PM   #17
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job on the install of your Camaro subframe! Keep those progress pictures coming.
CAL 58 GMC is offline   Reply With Quote
Old 12-22-2006, 07:17 PM   #18
entourageguy
Yellow truck club
entourageguy's Avatar
Never too many pictures ....................
Brian ....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-22-2006, 08:31 PM   #19
poncho_villa
poncho_villa's Avatar
You make it look so easy. Your good planning is what does it. You gonna leave the battery tray in place? Are you going to have the power brake booster on the other side to balance the appearance?
poncho_villa is offline   Reply With Quote
Old 12-22-2006, 11:18 PM   #20
56chevy1300
Hi Guys! Thanks for the comments. I really like the clean firewall look but don't want to put the battery on the frame; if I move it, it will be going in the bed...any suggestions? The brake booster & master cylinder will be mounted on the frame in the stock location.
Here are pics of the front framerails. I cut 12" off the front and 11" off the rear. The front frame ends will be mounted to the front of the Camaro subframe and the rear ends will be used as boxing plates (I've already prepped them in the photo); they fit perfectly!
Old 12-22-2006, 11:37 PM   #21
56chevy1300
I tacked in a reference bar to help locate the front frame horns. The bar was welded in so that its level with the top of the stock truck framerails.
This pretty much brings you up to speed with my subframe install. Much of my Christmas break will be spent welding in the frame horns and test fitting the front sheetmetal.
Old 12-23-2006, 12:28 AM   #22
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Real nice looking work. We love pictures, keep them coming.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-23-2006, 04:20 AM   #23
Daniel U
Daniel U's Avatar
^What he said
l
l
l
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 12-23-2006, 12:56 PM   #24
55 on bags
55 on bags's Avatar
looking really good keep up the good work
55 on bags is offline   Reply With Quote
Old 12-23-2006, 01:09 PM   #25
56chevy1300
Okay, time for some parts pics...this is my order from CPP: polyurethane suspension components (everything but the center link), motor mounts, axle kit, frame-mount power brake booster kit & trans mount.
