Old 08-20-2016, 11:58 AM   #276
toyplumbertrucks
toyplumbertrucks's Avatar
Re: 1972 C10 Parting
Is this tread dead? I keep checking for a response to my question with no answer.
toyplumbertrucks is offline   Reply With Quote
Old 08-20-2016, 06:30 PM   #277
toyplumbertrucks
Another member stepped up and sold me the parts I needed. Thanks anyway.
Old 10-03-2016, 10:10 PM   #278
Keller30
Originally Posted by DLTruck1973 View Post
We are now selling parts removed from a 1972 Chevy C10 pick up with a 350/SM465. This truck was a 127 inch wheel base truck with factory leaf springs.
If you do not see what you are looking for in the thread, please ask as we have a huge inventory of parts for these trucks.
Please post your interest and questions in the thread. "I'll take it" holds your item for 24 hrs to allow time for payment.
We accept paypal, money orders or credit card over the phone for payment.
All prices are plus shipping.
As always, we thank you for looking,
Thomas
Photo 1:
small block fan shroud, non AC, nice...$ 45.00
air cleaner housing, correct for 69-72 small and big block...$ 35.00
air cleaner housing spacer with hose...$ 22.50
brake/clutch pedal assembly...$ 45.00
speedometer cable for 2wd 350 4 speed (SM465)...$ 15.00
gas pedal assembly without cable...$ 30.00
gas pedal cable...$ 15.00
2wd 4 speed (SM465) floor hump...$ 35.00
4 speed (SM465) shift handle with boot and ring and handle, very minor tear in boot, under fold...$ 40.00
complete clutch pedal linkage from clutch pedal to throw out fork, including the frame bracket and return spring...$65.00
front bumper brackets...$ 15.00 each
left and right wiper transmissions, nice...$ 15.00 each
door latches, left and right...$ 30.00 LH 25.00 RH
air diverter??? for exhaust...$ 12.50
clutch/brake pedal stop bracket...$ 10.00
steering column, black for 4 speed, decent driver condition...$ 85.00
steering wheel, black, good project for a restoration, horn cap not included but available ...$ 40.00
sun visors, decent drivers with some clip marks...$ 20.00 each
RH vent window, decent chrome, clear glass, need rubber, rust on the frame...$ 30.00
left inner fender brace...$ 7.50
Photo2:
Complete drive line with center bearing bracket for 127 inch wheel base, small block with SM465 trans. Comes with bracket for cross member...$ 75.00
Complete disc brake conversion, includes, cross member, coils, upper and lower control arms, spindles, rotors with bearings, dust shields, calipers, idler arm, inner and outer tie rods. Center link not in the photo but will make one available with the sale...$ 250.00
(2) small block 4 speed transmission cross members (same as 3 speed manual trans) nice and clean...$ 65.00 each
Photo3:
Hood hinges, clean and ready for your finish...$ 30.00 each
350 engine stands, nice...$ 30.00
68-down single groove water pump pulley...$ 20.00
single groove crank pulley...$ 12.50
rear spring hangers (forward position)...$ 25.00 each
rear spring hangers (rear position)...$35.00 each
leaf spring shackles...$ 15.00 each
rear upper shock mount brackets...$ 20.00 each
door hinges, left and right, upper and lower, nice set...uppers 12.50 each lowers 10.00 each
park brake pedal assembly...$ 25.00
127" wb 2wd park brake cable set including links and guides. does not include rear cables to backing plates...$40.00
complete under bed spare tire carrier with upper frame brace...$50.00
rag joint...$ 25.00
Photo4:
(4) 15 x 6 5on5 steel wheels, tires will be dismounted for the sale, decent set...$ 85.00
Inside heater box...20.00
dash pad, black. has a split on top, curled ends but overall decent..$ 22.50
parchment door panels, decent driver set, no cracks, typical chalking condition...$ 50.00
Photo5:
Front fender spheres, left/right, very nice...$ 20.00 each
RH and LH Upper door trim, nice...$ 20.00 each
upper cab trim, left/right...5.00 each
door strikers, left/right with shims and correct bolts...$12.50 each
headlight bezels, decent driver set...$ 25.00 or 15.00 each
door edge guards, left/right, typical condition....$ 20.00
wiper arms...$12.50 each
inside rear view, typical deterioration...$10.00
wiper motor...$ 25.00
outside door handles, left/right, Very nice driver quality...$ 65.00 pair
park light housings...$12.50 each
park light lenses, one has a chip on the edge and one has a rub mark...$10.00 each. I may have better ones, priced depending on condition.
reverse light housings, left/right...$ 5.00 each
tail light housings, left/right...$ 10.00 each
tail light lenses, left/right not perfect but nice...$ 15.00 each
reverse light lens, passenger side, decent driver...$ 8.00
center grill brace with hood latch...$ 25.00
hood latch striker...$ 10.00
oil fill tube with nice cap...$ 20.00
heater control, nice, tight with good arms...$ 50.00
front amber side markers, decent driver condition...$ 12.50 each
rear red side markers, decent driver condition...$ 12.50 each
ash tray with bracket...$ 15.00
head light switch...8.00
head light switch knob, deluxe...$3.00
wiper switch...8.00
wiper switch knob, deluxe...3.00
parchment visor hooks...4.00 each
cargo light assembly chrome pitted driver quality complete with wiring and switch...$ 25.00
interior dome light, average condition with cover (cracked)...$ 8.00
cig lighter with housing...$ 15.00
cig lighter wiring harness...$ 6.00
radio power wire...$ 6.00
tail gate straps...$ 15.00 each
custom 10 emblems, pair...$ 12.50 each
8-350 emblems, pair...$ 5.00 each
deluxe fender emblems, pair...$ 5.00 each
upper radiator supports for 3 core tank...$ 7.50 each
inside door handles, decent drivers...$ 7.50 each
window cranks, decent drivers...$ 7.50 each
right door relay, nice condition...$ 10.00
under steering column cover...$ 5.00
air cleaner adapter...$ 7.50
washer bottle with bracket...$ 10.00
front light harness, nice, no splices...$ 60.00
engine harness, (4 speed) needs yellow coil wire repair on both ends. perfect for HEI converted truck...$ 40.00
under dash harness for gauges, nice...$ 65.00
double groove water pump pulley...$ 15.00
tripod mount mirrors, aftermarket heads and elbows, original brackets. nice glass...$ 40.00
very nice pair of exhaust manifolds, no cracks or heat check. these have been glass beaded...$ 125.00 pair
Do you still have gas pedal
Keller30 is offline   Reply With Quote
Old 10-03-2016, 10:27 PM   #279
In The Ten Ring
Do you still have the cigarette lighter wiring harness?
In The Ten Ring is offline   Reply With Quote
Old 10-04-2016, 10:06 AM   #280
jlampka
I don't see the front fenders? Please send photo
jlampka is offline   Reply With Quote
Old 10-17-2016, 12:28 PM   #281
In The Ten Ring
Do you still have the grill bracket, (it holds the grill to the core support and also the hood latch attaches to it)?
Old 10-17-2016, 11:17 PM   #282
Cheyenne1970
Do you still have the steering wheel?
Cheyenne1970 is offline   Reply With Quote
Old 10-18-2016, 01:53 AM   #283
kda2000
kda2000's Avatar
There has been no reply from Tom (originator) since 1/16/2016 (#260). You should consider this thread closed -- maybe the moderator should lock it -- so people don't continue to request parts.
kda2000 is offline   Reply With Quote
Old 10-22-2016, 11:57 AM   #284
Cam1968rsss
Pair of Hood Hinges?
Cam1968rsss is offline   Reply With Quote
