Old 05-14-2015, 04:46 PM   #1
DLTruck1973
1972 C10 Parting
We are now selling parts removed from a 1972 Chevy C10 pick up with a 350/SM465. This truck was a 127 inch wheel base truck with factory leaf springs.
If you do not see what you are looking for in the thread, please ask as we have a huge inventory of parts for these trucks.
Please post your interest and questions in the thread. "I'll take it" holds your item for 24 hrs to allow time for payment.
We accept paypal, money orders or credit card over the phone for payment.
All prices are plus shipping.
As always, we thank you for looking,
Thomas
Photo 1:
small block fan shroud, non AC, nice...$ 45.00
air cleaner housing, correct for 69-72 small and big block...$ 35.00
air cleaner housing spacer with hose...$ 22.50
brake/clutch pedal assembly...$ 45.00
speedometer cable for 2wd 350 4 speed (SM465)...$ 15.00
gas pedal assembly without cable...$ 30.00
gas pedal cable...$ 15.00
2wd 4 speed (SM465) floor hump...$ 35.00
4 speed (SM465) shift handle with boot and ring and handle, very minor tear in boot, under fold...$ 40.00
complete clutch pedal linkage from clutch pedal to throw out fork, including the frame bracket and return spring...$65.00
front bumper brackets...$ 15.00 each
left and right wiper transmissions, nice...$ 15.00 each
door latches, left and right...$ 30.00 LH 25.00 RH
air diverter??? for exhaust...$ 12.50
clutch/brake pedal stop bracket...$ 10.00
steering column, black for 4 speed, decent driver condition...$ 85.00
steering wheel, black, good project for a restoration, horn cap not included but available ...$ 40.00
sun visors, decent drivers with some clip marks...$ 20.00 each
RH vent window, decent chrome, clear glass, need rubber, rust on the frame...$ 30.00
left inner fender brace...$ 7.50
Photo2:
Complete drive line with center bearing bracket for 127 inch wheel base, small block with SM465 trans. Comes with bracket for cross member...$ 75.00
Complete disc brake conversion, includes, cross member, coils, upper and lower control arms, spindles, rotors with bearings, dust shields, calipers, idler arm, inner and outer tie rods. Center link not in the photo but will make one available with the sale...$ 250.00
(2) small block 4 speed transmission cross members (same as 3 speed manual trans) nice and clean...$ 65.00 each
Photo3:
Hood hinges, clean and ready for your finish...$ 30.00 each
350 engine stands, nice...$ 30.00
68-down single groove water pump pulley...$ 20.00
single groove crank pulley...$ 12.50
rear spring hangers (forward position)...$ 25.00 each
rear spring hangers (rear position)...$35.00 each
leaf spring shackles...$ 15.00 each
rear upper shock mount brackets...$ 20.00 each
door hinges, left and right, upper and lower, nice set...uppers 12.50 each lowers 10.00 each
park brake pedal assembly...$ 25.00
127" wb 2wd park brake cable set including links and guides. does not include rear cables to backing plates...$40.00
complete under bed spare tire carrier with upper frame brace...$50.00
rag joint...$ 25.00
Photo4:
(4) 15 x 6 5on5 steel wheels, tires will be dismounted for the sale, decent set...$ 85.00
Inside heater box...20.00
dash pad, black. has a split on top, curled ends but overall decent..$ 22.50
parchment door panels, decent driver set, no cracks, typical chalking condition...$ 50.00
Photo5:
Front fender spheres, left/right, very nice...$ 20.00 each
RH and LH Upper door trim, nice...$ 20.00 each
upper cab trim, left/right...5.00 each
door strikers, left/right with shims and correct bolts...$12.50 each
headlight bezels, decent driver set...$ 25.00 or 15.00 each
door edge guards, left/right, typical condition....$ 20.00
wiper arms...$12.50 each
inside rear view, typical deterioration...$10.00
wiper motor...$ 25.00
outside door handles, left/right, Very nice driver quality...$ 65.00 pair
park light housings...$12.50 each
park light lenses, one has a chip on the edge and one has a rub mark...$10.00 each. I may have better ones, priced depending on condition.
reverse light housings, left/right...$ 5.00 each
tail light housings, left/right...$ 10.00 each
tail light lenses, left/right not perfect but nice...$ 15.00 each
reverse light lens, passenger side, decent driver...$ 8.00
center grill brace with hood latch...$ 25.00
hood latch striker...$ 10.00
oil fill tube with nice cap...$ 20.00
heater control, nice, tight with good arms...$ 50.00
front amber side markers, decent driver condition...$ 12.50 each
rear red side markers, decent driver condition...$ 12.50 each
ash tray with bracket...$ 15.00
head light switch...8.00
head light switch knob, deluxe...$3.00
wiper switch...8.00
wiper switch knob, deluxe...3.00
parchment visor hooks...4.00 each
cargo light assembly chrome pitted driver quality complete with wiring and switch...$ 25.00
interior dome light, average condition with cover (cracked)...$ 8.00
cig lighter with housing...$ 15.00
cig lighter wiring harness...$ 6.00
radio power wire...$ 6.00
tail gate straps...$ 15.00 each
custom 10 emblems, pair...$ 12.50 each
8-350 emblems, pair...$ 5.00 each
deluxe fender emblems, pair...$ 5.00 each
upper radiator supports for 3 core tank...$ 7.50 each
inside door handles, decent drivers...$ 7.50 each
window cranks, decent drivers...$ 7.50 each
right door relay, nice condition...$ 10.00
under steering column cover...$ 5.00
air cleaner adapter...$ 7.50
washer bottle with bracket...$ 10.00
front light harness, nice, no splices...$ 60.00
engine harness, (4 speed) needs yellow coil wire repair on both ends. perfect for HEI converted truck...$ 40.00
under dash harness for gauges, nice...$ 65.00
double groove water pump pulley...$ 15.00
tripod mount mirrors, aftermarket heads and elbows, original brackets. nice glass...$ 40.00
very nice pair of exhaust manifolds, no cracks or heat check. these have been glass beaded...$ 125.00 pair
DLTruck1973 is offline   Reply With Quote
Old 05-14-2015, 05:17 PM   #2
t korinek
Truckin' Krazy
t korinek's Avatar
Re: 1972 C10 Parting
How much on the door panels thomas?
I see now, I'll take those when I'm up there>
Thanks,
Tom
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 05-14-2015, 05:22 PM   #3
DLTruck1973
Thanks,
Tom
I will put your name on them T.
See you soon. Safe travels,
Thomas
Old 05-14-2015, 05:28 PM   #4
DLTruck1973
Photos of trim for kcsa75
This trim is super nice with only very minor blemishes. I good paint and polish and it would look very nice.
Thank you,
Thomas
Old 05-14-2015, 06:35 PM   #5
chastain90
chastain90's Avatar
can I get better pics of door handles inside and out and window rollers? Also pics of 8 350 emblems Thanks
chastain90 is offline   Reply With Quote
Old 05-14-2015, 07:03 PM   #6
Mr Handy
Mr Handy's Avatar
I'm interested in the high hump, brake cluch assembly, colum, shift handle and boot, and the stop bracket.
Basically all the parts to swap in the Muncie
Let me know what the package price shipped to 34606 would be, I can do a commercial address if it helps as well.
Andy
Mr Handy is offline   Reply With Quote
Old 05-14-2015, 07:04 PM   #7
DLTruck1973
When you say "window rollers" are you referring to the window regulators?
I will get photos posted of the other items you ask about.
Thank you,
Thomas
Old 05-14-2015, 07:14 PM   #8
hdff
hdff's Avatar
i'll take the air cleaner and air cleaner housing spacer in pic 1. let me know shipping to 77504.
also what are you askin for the grill bow tie in the last pic?
thanks keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 05-14-2015, 07:22 PM   #9
DLTruck1973
Here are some photos for you.
Thank you,
Thomas
Old 05-14-2015, 07:22 PM   #10
uaengineer
I'll take the sun visors and please put me in line for the door panels. I'm sure t korinik's going to take them but just in case.
72 GMC Ochre and White
72 GMC Ol' Blue
uaengineer is offline   Reply With Quote
Old 05-14-2015, 07:24 PM   #11
Userone
Userone's Avatar
Are the left and right grill support brackets available?
Userone is offline   Reply With Quote
Old 05-14-2015, 07:29 PM   #12
chastain90
chastain90's Avatar
Thank you,
Thomas
Sorry I meant window handles
Old 05-14-2015, 07:35 PM   #13
DLTruck1973
Andy
Hi Andy,
Are you installing a Muncie or the Saginaw SM465 trans in your truck? The shift handle I have is for a SM465 trans. Also, do you need the clutch linkage from the pedal to the throw out fork?
Let me know.
I can work on a shipping quote for everything tomorrow for you.
Thank you for the interest,
Thomas
Old 05-14-2015, 07:37 PM   #14
DLTruck1973
thanks keith
Keith,
grill bow tie is $35.00. I can get you a shipping quote tomorrow morning if that is OK.
Old 05-14-2015, 07:40 PM   #15
hdff
hdff's Avatar
Keith,
tomorrow will be fine, what is the condition of the bow tie?
"Wanda"
Old 05-14-2015, 07:41 PM   #16
DLTruck1973
Here are photos of the window cranks. Some good polish and these would be real nice. The knobs are nice and tight as well.
Thank you,
Thomas
Old 05-14-2015, 07:45 PM   #17
DLTruck1973
Here are some photos. Nice for a driver in my opinion. Some pitting. It is not perfect but not bad.
Thank you,
Thomas
Old 05-14-2015, 07:49 PM   #18
DLTruck1973
I do have them from another 72 grill. $25.00 for a nice pair plus shipping.
Let me know.
Thomas
Old 05-14-2015, 07:55 PM   #19
hdff
hdff's Avatar
Thank you,
Thomas
i'll pass on the bow tie but if chastain90 passed on the window cranks put me next in line please
"Wanda"
Old 05-14-2015, 07:59 PM   #20
DLTruck1973
Sun visors are yours. I will get you a shipping quote tomorrow. I may have another set of 72 Parchment door panels for you but the price will be based on condition.
Thomas
Old 05-14-2015, 08:01 PM   #21
DLTruck1973
I could do $30.00 on the bow tie if you want it. I may also have another set of window cranks in equal condition. I will let you know tomorrow.
Thank you again,
Thomas
Old 05-14-2015, 08:01 PM   #22
hdff
hdff's Avatar
Thank you,
Thomas
is this trim spoken for? if not what are you askin for it.
"Wanda"
Old 05-14-2015, 08:01 PM   #23
chastain90
chastain90's Avatar
Can you get me shipping quote on inside door handles and window cranks and grill bowtie? 30705 Thanks
Old 05-14-2015, 08:02 PM   #24
hdff
hdff's Avatar
Thank you again,
Thomas
is the bow tie genuine gm or after mkt?
and what are you getting for the cranks?
"Wanda"
Old 05-14-2015, 08:47 PM   #25
uaengineer
Thomas
That's good. I'm interested in the other set of door panels. Just send me a price and pic when you get time. I also posted on the heat stove post if you want to combine.
72 GMC Ol' Blue
