05-29-2023, 01:38 PM | #3851 |
Re: What did you do to your truck today.The 3rd chapter
Expensive way to mask but I have three rolls that were given to me . 3M welding and spark deflection paper . Nice it has a little adhesive to hold it in place
05-30-2023, 07:05 AM | #3852 |
Mark, it looks like your starter is too far away from the flex plate, if you have a starter shim in there, take it out ........ replace the Bendix as well .
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
05-30-2023, 07:39 AM | #3853 |
No shim ,it’s a Powermaster had a good gab when I installed it a few years ago . Think the damage was before my ownership and it got worse over time . I should have inspected the flex plate more thoroughly.
05-30-2023, 07:43 PM | #3854 |
I removed the bed wood to refinish it. My bed wood planks are Birch wood. I finished them many moons ago with polyurethane, that has not held up well. I plan on stripping that off and using an oil instead of a surface coating. I also replace the sending unit because the fuel level float floated away on the last one. I used a plastic float instead of the brass one this time around.
06-01-2023, 03:55 PM | #3855 |
Gearing up for a 4/5 drop and disc brake conversion up front this month -
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
06-01-2023, 05:43 PM | #3856 |
68 C10 Longbed
Installed new CCP rear sway bar on the 68.
06-01-2023, 06:05 PM | #3857 |
I hooked my trailer up and helped my son move from one storage place to another
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
06-01-2023, 07:14 PM | #3858 |
nice
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-01-2023, 07:16 PM | #3859 |
06-02-2023, 08:10 AM | #3860 |
68 C10 Longbed
Here’s some pics of the new CCP rear sway bar installed yesterday. |
06-02-2023, 08:14 AM | #3861 |
68 C10 Longbed
https://www.67-72chevytrucks.com/vbo...1&d=1685707942 Here’s pics of the front sway bar installed on my 68 C10 last weekend. I used an original C10 bar with CCP mounting brackets and poly bushings. |
06-02-2023, 08:58 AM | #3862 |
Nice thanks for posting my front is done and need to do the back have what I need just haven’t got there yet but this is a motivator
06-02-2023, 10:51 AM | #3863 |
68 C10 Longbed
Yep, understand. Just so you know for the rear bar I installed you will need to drill (6) holes (at least for a 67-72 c10). Good luck👍
06-02-2023, 11:48 AM | #3864 |
Rear bearings and shoes
06-02-2023, 09:08 PM | #3865 |
06-02-2023, 10:22 PM | #3866 |
I installed a rear bar many years ago on a long bed truck that already had a front bar. The rear bar really made a difference in steering response and how flat the truck stays in corners. I mean, we're not talking Camaro, but it was a major improvement!
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
06-02-2023, 10:31 PM | #3867 |
I re-installed my windshield wiper motor with a new washer pump. Kind of a PITA to get the three bolts started, but it all works great. BTW, Rock Auto had the lowest washer pump price by a large margin.
I used cowl-to-motor and shaft seals from GMC Pauls. They are first rate. And this is a great tool for removing and re-installing the wiper arms. Lisle 65750, Dorman 49023
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 06-03-2023 at 09:54 PM. |
06-03-2023, 12:14 AM | #3868 |
Threw this together today, it's been a long time coming. The outer has been wall decor the last 7 years. Inner was shot, sanded, shot again and a clear coat, needless to say it's much heavier now. Took longer than I thought of course, nylon clips have to be sanded just right. Anyway, we install it tomorrow. Edit, installed. My assistant, really vise versa, he's body and paint guy dropped these off today. Tires due "in a month", bumpers due "call back in two weeks", and upholstery & flooring is supposed to call, someday. Other than that done.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-03-2023 at 06:38 PM. |
06-03-2023, 11:21 AM | #3869 |
Grill came out great .
All of the bearings and 2 of the races came today just waiting on the outer races and grease seals . At least there are no Chinese parts going on the truck . USA and Japan
06-03-2023, 11:29 AM | #3870 |
68 C10 Longbed
06-03-2023, 11:32 AM | #3871 |
68 C10 Longbed
Thx Mike, yes I can feel the difference.
06-03-2023, 03:13 PM | #3872 |
Nothing actually done to the truck, because it's 30 miles away at my dad's shop for now, but parts boxes are arriving New master cylinder, soft brake lines, wheel cylinders, brake parts for all the drums, new period correct carburetor has arrived, the rebuilt one that was on it was a pre 68.
Still waiting on the shipment from Cliff's High Performance for the throttle shaft bushing kit and rebuild kit to make the carb as perfect as I can make it. Pic just because Last edited by wrangler94; 06-03-2023 at 03:18 PM. |
06-03-2023, 04:45 PM | #3873 |
Uhh oh I wasn’t happy with the color of the passenger fender and the cowl , I didn’t understand why it was darker than the rest of the truck . When I painted the ammo box a few weeks ago I figured out why . I inadvertently had grabbed the wrong paint I used the 68 Golden anniversary paint . Both cans were open and I just saw gold on the outside . Was a stupid mistake .
06-03-2023, 05:46 PM | #3874 |
Thanks, I installed one back in the mid-90's on my 72 C20 that was 7/8" diameter. I been wanting to go to this larger bar. Looks like I will be talking to CPP for sure.
06-03-2023, 09:59 PM | #3875 | |
My dad had a gold 67 Impala 2dr hardtop with gold vinyl interior. Probably a different gold, but it was super cool!
