Old 11-09-2010, 02:25 AM   #426
SCOTI
SCOTI's Avatar
Re: Project: Recycle
Just got home from the shop.
Both the main rails are void of gouges, rust-pits, & production scars. Everything has a nice consistent 60 grit finish so the rails should look fairly smooth after blasting & color.
Tomorrow morning, I'll hook up the trailer & head back to the shop to load them up (I already have all the other parts & x-members @ the house). After everything is in the same place, I'll take an inventory to make sure nothing was over-looked. If the parts match my 'list', I'll stop by 2 different PC shops for quotes. Price pending, I'll leave the parts @ one of them.
I would put up some pics but my computer crashed & I'm using a borrowed laptop. Hopefully by the time the parts are done, I'll be able to start loading up some pics again.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-09-2010, 10:27 AM   #427
67cheby
67cheby
67cheby's Avatar
cant wait to see it , i am hopefully about 1 month away from doing this myself, all of my rear suspension is done already, so it will just be the main frame rails and the front suspension, anyway i am excited for you !!
67cheby is offline   Reply With Quote
Old 11-09-2010, 08:10 PM   #428
SCOTI
SCOTI's Avatar
And, poof . . .... It's all gone!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-09-2010, 08:46 PM   #429
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks like it is all there. What about the front spindles and the rear end housing? What color are you going to use?
I forgot to ask, are you going to bolt the complete assembly back together and not have any welded/rivet'd cross members? Are you going to use grade 8 fasteners?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-09-2010, 08:48 PM   #430
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Never seen one taken down that far. Very interesting.
Alan's Classic is offline   Reply With Quote
Old 11-09-2010, 10:23 PM   #431
SCOTI
SCOTI's Avatar
I guess the 'usual' is the front splash pan, shock x-member, & Panhard bar x-members remain in place even when stripped down for PC-ing.
Since I had to re-work each of the rear x-members & the front splash pan was in the way of some frame tweaks, everything had to come out. I thought about the re-assembly process & the 'pros/cons' of just using nuts/bolts or if welding would be necessary. I haven't decided one way or another but I'm always open to others experiences.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-10-2010, 01:38 AM   #432
Captainfab
60-66 Nut
Bolting it back together shouldn't be a problem. Of course I'm sure you would be using grade 8 hardware and squaring it up. You wouldn't want to be welding on it after powder coating anyway
Old 11-10-2010, 01:55 AM   #433
SCOTI
SCOTI's Avatar
I did bolt everything back together to verify it all worked together. While squaring it up, it was a pretty decent task shifting the main rails to get the dimensions as close as possible (this was w/the hardware semi-tight).
And yes, everything (and I mean everything) is MINIMUM GRADE-8 hardware.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-10-2010, 02:15 AM   #434
SCOTI
SCOTI's Avatar
The rear was in my 68 & will just get a good scrubbing w/a degreaser & some hot-water, then a fresh coat of satin black. Front spindles are undetermined @ this time. I have both drop & OE spindles & will use whichever ones set the ride height @ the optimum (for bag & shock height vs. air pressure).
There's still more to do so there will be a 2nd PC load. The T/A x-member is yet to be finalized (always used 1pc driveshafts & Porter has got me convinced a 2pc is the better way to go this low). Once everthing is reassembled, I'll be able to finish up the trans x-member. After that, both will get coated along w/any other 'forgotten' items.
The spindles, calipers, & a-arms will be epoxied.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-10-2010, 11:24 AM   #435
N2TRUX
Happy to be here
N2TRUX's Avatar
Houston, we have lift off...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-10-2010, 12:39 PM   #436
Hart_Rod
Hart_Rod's Avatar
Originally Posted by SCOTI View Post
Dang, you guys sent me to the 2nd page. Where's the love??
Ok..... I'll make a small update to keep things on track. I got the sbc/700r4 into the spare frame in order to verify the driveline angles & needed some pinion shims so I could accurately set the trans mount height. I got the shims in today so I'll try & get some time on it this weekend.
Baseball (Rangers are in the play-offs) has been occupying some of my spare time so until the 'fat lady sings', I might be going to the home games.
Oh.... the other thing taking up my time (& thoughts) is my new to me dually that I swapped my 74 for. Although not a project, I'm getting a few 'essentials' to make it unmistakenly 'mine' . . . ......
Sweet shims! Where'd ya get'em?
Hart_Rod is offline   Reply With Quote
Old 11-11-2010, 01:59 AM   #437
SCOTI
SCOTI's Avatar
http://www.stockcarproducts.com/
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-11-2010, 10:11 PM   #438
Painter D
Painter D's Avatar
Does that new dually tow that trailer good enough for ya?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-12-2010, 04:04 AM   #439
SCOTI
SCOTI's Avatar
It works pretty darn good.
The current ride height is screwing w/my view when backing (I can't see the end of the trailer @ all) & it's a thirsty SoaB. But, since there's no payment, I'll live w/it until the LS swap.
I just got home from the shop. It's been a long, but productive day .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2010, 05:34 AM   #440
watahyahknow
watahyahknow's Avatar
there these backupcams out there mounted in the numberplatesuround , havent checked prices lately but they where reasonably priced i might be a solution to the backup problem if you can get it either to look underneat the trailer or between the trailer and the car on top of it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-12-2010, 08:57 AM   #441
lakeroadster
Hey Scoti, I attached some fiberglass driveway markers to the back of my trailer so I could see them when backing up. They thread into and out of a nut that is welded to the trailer.... for what it's worth to ya.
Alot more lo-tec than a camera, but that's how I roll
Here is a link to the driveway markers at Home Depot.. they are $2.29 a piece! http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
lakeroadster is offline   Reply With Quote
Old 11-12-2010, 11:24 AM   #442
SCOTI
SCOTI's Avatar
This is what I was going to look for @ my local hardware joint. I figured a couple of fiberglass type 'antennas' that I could just temp attach @ each corner for better line of sight.
In the interim, we dropped the t-gate. I'm always nervous about that decision though....
Thanks for the suggestions guys!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2010, 11:29 AM   #443
Jonboy
Slots go on anything!
LS swap!!
The '64 is coming along great. How long until the parts are back?
1974 Jimmy- 5.3/4L80e/NP241
Old 11-12-2010, 12:43 PM   #444
watahyahknow
good idea those antenna's
Old 11-12-2010, 09:17 PM   #445
SCOTI
SCOTI's Avatar
Originally Posted by Jonboy View Post
LS swap!!
Who said I'm still waiting
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2010, 10:26 PM   #446
jasonhall
jasonhall's Avatar
After the ls swap maybe some bags?
jasonhall is offline   Reply With Quote
Old 11-13-2010, 01:33 AM   #447
SCOTI
SCOTI's Avatar
I'm doing the dually like my other 'tow-trucks' before it. Spindles & cut a coil up front w/flip kit & driveway built AOL set-up. Think budget.... I would love to do Ride Techs Air bar set-up but can't justify the coin for the amount of drop (if I could even find that amount of coin).
I've looked for suspension info on that HHR shop dually but have only found a few pics. Anybody know if any info on specifics are online?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-13-2010, 10:23 AM   #448
67cheby
67cheby
67cheby's Avatar
dont be STINGY with the PICS then.....come on just give us a little pic fix !!
Old 11-13-2010, 11:31 AM   #449
SCOTI
SCOTI's Avatar
I'll get some today. It's basically the same 'ole pics.... now w/a splash of color vs. bare metal (black is a color).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-13-2010, 11:36 AM   #450
67cheby
67cheby
67cheby's Avatar
"basically the same pics with a little color"........we dont care , that is like your girlfriend saying she doesnt want to undress in front of you ..cause she is feeling a little FAT..... WE DONT REALLY CAR WE JUST WANT TO SEE UM !!
