Old 12-07-2007, 04:19 PM   #26
abadsvt
abadsvt's Avatar
Re: Project "Dream Truck"
Originally Posted by pcorriveau951 View Post
any updates? our chassis is sweet.
Actually I have got alot done but I droped my camera and it is being repaired. I got one pic off before the camera droped. So in a week or so i should get it back and will take some pics. I have got most the round pipe roughed in which holds all my suspension parts and braces up the frame. I will have the rear suspension installed tonight (upper and lower a-arms). It took me forever because i kept changing all the brackets and I am hand making all the parts. Hopefully this saturday i can get the transaxle, torque tube and the rear end installed for a mockup and to double check all my meausurements. It is looking SICK!!!! I am hoping by the end of Janurary i will have entire drive train installed and have a finished rolling chassis as long as i don't have to go out of town for work. We will see though. I will post some pics when i get my camera back.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-07-2007, 04:28 PM   #27
jb4short
Damn Yankee
jb4short's Avatar
Nice!
jb4short is offline   Reply With Quote
Old 12-07-2007, 09:46 PM   #28
uno67
uno67's Avatar
unfair... stop working on it till you get your camera back so we can see
uno67 is offline   Reply With Quote
Old 12-11-2007, 04:55 PM   #29
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
i admire people that build there own frames
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 12-13-2007, 11:46 AM   #30
abadsvt
abadsvt's Avatar
Well i finally got my camera back so i took a few pics. Here is a quick recap on what i did and how i got there. Most of the stuff is just tacked together. I have been trying to be very patient and think things through as best as i can. So planing out my attack was a little difficult because there was so many things to plan ahead for. I wanted something that was strong, i needed the tubing to hold the rear end where it needed to be but not get in the way of the control arms and the brackets. I also had to makes sure that the axles where centered with the wheels in both horizontal and vertical. That is why i decided to start fabing up the rear end stuff first. The upper control arm mounts i wanted to do something creative and a bunch of brackets hanging off the side of the 2x4 tube steel wasn't doing it for me. So i took a peice of 1 1/2 round tube so it would match the rest of the tubing and slid a piece of 1 1/4 x 2" long solid pipe in both sides of the 1 1/2. Then i drilled and tapped it so i can bolt the upper control arms to this piece of pipe. I was trying to keep things clean. To find the locations of the upper and lower arms i made a jig which held both the upper and lower a arms in the correct locations both horizontal and vertical. That way i was sure that they were identical to the other side and it was alot easier this way, it just took a few days longer to get done. Also if you look at the rear tubing right at the end you see that is bends outwards and then goes up and ties into the frame. I did it like that trying to maximize the room for my gas tank. Hopefully this weekend i can get the reand, transaxle, and the torque tube installed for mock up to make sure all my measurements were correct and everything clears. I can't wait to mock up my other wheels on the new frame. Anyways sorry for the long essay.
One more thing. I am not finished with the center section of the frame. I wanted to see exactly were the torque tube sits before i finish it. Also if anyone sees something that i missed or forgot or just plan good o'lle constructive critism please let me know. I want this thing to be perfect and won't take it personally. Thanks alot
Josh
(Project truck)
Old 12-13-2007, 11:49 AM   #31
abadsvt
abadsvt's Avatar
My last pic i took. This is the one right before i dropped my camera. I think it is my third time dropping the camera.
Josh
(Project truck)
Old 12-13-2007, 11:55 AM   #32
pcorriveau951
pcorriveau951's Avatar
Great Job!!! well worth the wait to see progress. I'm totally jealous at this point, your putting alot of time and effort into that chassis, and i cant wait to see the thing complete. Keep up the great work.
pcorriveau951 is offline   Reply With Quote
Old 12-13-2007, 02:11 PM   #33
valleycustom
GANGSTER!!! One thing. I would add some kind of gussetts to the rear upper control arm mount. Are you running .120 wall 2x4? I don't think that will provide enough structure for the mounting surfaces. You might get some flex in the box tubing. This thing is gonna be sick. Your shop looked like my first one. NO room and a lot of equipment.
Later
Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 12-13-2007, 09:16 PM   #34
abadsvt
abadsvt's Avatar
Later
Jr
Now since you pointed that out I think i agree. What i think i will do is grind off the welds and then weld a piece of steel to the side of the 2x4 tube steel to reinforce it. Thanks for the heads up. Yeah my garage seems like it gets smaller and smaller everytime i start a new project. Luckly in a month to 2 months i am getting a 5000sq shop. It is for my business but there will definately be room for my projects. Talk to you later
Josh
ps. Any progress on your project?
(Project truck)
Old 12-14-2007, 03:32 AM   #35
ccracin
CCTek
ccracin's Avatar
Josh
Josh,
The chassis is looking great. Since I am building my own chassis as well, I have a great amount of respect for what you are doing. If you don't mind, I will throw my 2 cents into the mix. Instead of welding a doubler plate to the side of the box tube, grind the welds off and extend the mounts through the box tube. Use a hole saw and extend the standoffs so that you hit both walls of the rectangular tubing. Once its welded on the back side make some plugs to finish everything off. JMO. Keep up the great work. Here is what we are doing if your interested.
http://67-72chevytrucks.com/vboard/s...d.php?t=262840
Later,
Chad
Chad
68 swb Project
72 swb Project SOLD
http://67-72chevytrucks.com/vboard/s...=1#post3993641
THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com)
ccracin is offline   Reply With Quote
Old 12-14-2007, 08:11 AM   #36
valleycustom
Josh
Yeah I got the bed mounted. I'm doing some mods to the hood right now then the truck is getting sprayed with black epoxy primer for now. I'm getting it ready for Reso on the 28th, 29th and 30th. I'm towing it down there. Are you gonna go?
Later
Jr
Old 12-14-2007, 08:28 AM   #37
Frizzle Fry
Frizzle Fry's Avatar
Man that is looking great! I agree with the upper arm comments. Good advice. I see that you have the lower arms angled up (front/back) just like the C5 cradle sets them. Did you have a cradle for reference?
Are you still planning on running the rear-mounted transaxle or a traditional IRS diff? Looks like you're leaving room for the transaxle. Keep up the good work!
Frizzle Fry is offline   Reply With Quote
Old 12-14-2007, 06:38 PM   #38
abadsvt
abadsvt's Avatar
Yeah i plan on running the transaxle from the corvette. I only bought the front cradle and it was mainly for the rack and pinion mounts. I am trying to keep all the factory locations but slightly modified for my application and my tire size. Thanks for the complements.
Josh
(Project truck)
Old 12-15-2007, 07:40 PM   #39
brownsville
brownsville's Avatar
that truck is going to be so sweet good job on the frame work...later
brownsville is offline   Reply With Quote
Old 12-16-2007, 08:45 AM   #40
smoky02
Location: Sunny, Florida, some might call it South Alabama
That is gonna be an amazing truck...
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-17-2007, 06:41 PM   #41
abadsvt
abadsvt's Avatar
Well i got a little more done today. I fabbed up a jig to hold the lower control arms for the front suspension exactly where they need to be. Then made the brackets which holds the control arms and got them installed. I didn't get a chance to weld them in fully so right now they are just tack welded. I also got time to remove and install the torque tube, transaxle, and rear end in the new frame to double check all my measurments. I couldn't believe it. Everything came out perfect or atleast all my measurements were right on. Here are a few pics but PLEASE look past my "clean" garage. I think it is time to do a deep clean. Anyways enjoy.
Josh
(Project truck)
Old 12-17-2007, 06:47 PM   #42
gunkis84
gunkis84's Avatar
wow that is very sick!! i just cant believe that someone could do that much fab work.. (inspired me to sign up for a welding class at the local tech) keep it up! BUT FINISH THIS ONE!! both of them are awesome starts
gunkis84 is offline   Reply With Quote
Old 12-20-2007, 06:58 PM   #43
abadsvt
abadsvt's Avatar
Well i have been messing around with the front suspension mainly the upper control arm mount. I have fabbed up something that works and is strong but i am not sure if i like it. I am mainly talking about how long and how tall it is. I think it looks a little funny but I don't see any other way to do it. So i was hoping i could get your opinion. Maybe i am just tripping or maybe i am right and it looks a little funny? The piece is all welded but it is only tacked to the frame. I wanted to think about it before i fully weld it. Here are the pics and please let me know what you think.
Josh
(Project truck)
Old 12-20-2007, 07:14 PM   #44
abadsvt
abadsvt's Avatar
I was just looking at the pics and then i went downstairs when I thought of something. On the outside of the rails where it is a diagonal piece of metal just below the control arm. What if i got rid of the large plate and add 2 gussets like i have in the inside middle part. I think that will help the overall look from being big and bulky? Anyways just thought of that and wanted to through that out there.
Josh
(Project truck)
Old 12-20-2007, 07:27 PM   #45
PBFAB.COM
PBFAB.COM's Avatar
Josh-
Leave it how it currently is. Once you fab your mounts for the shockwave it will tie it all together... and make it "easier on the eyes".
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-20-2007, 07:59 PM   #46
Frizzle Fry
I like it, and I don't see a problem with it. Thing is looking awesome!
Old 12-20-2007, 08:04 PM   #47
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
looks good to me! wish I had the time and equipment to build like that. Gotta say I'm a little green
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 12-21-2007, 03:53 AM   #48
ccracin
CCTek
ccracin's Avatar
Josh,
Nathan is right, it will come together. That mount looks as good as any I've seen for the Corvette uppers. Your probably like me in that the look of Heim Joints and Clevis ends are a bit smaller and cleaner looking. You will be happy in the end. Great work.
Chad
68 swb Project
72 swb Project SOLD
Old 12-21-2007, 06:54 AM   #49
Frizzle Fry
Here's another approach:
Old 12-21-2007, 03:53 PM   #50
abadsvt
abadsvt's Avatar
That isn't a bad idea. I never thought about that. It looks like they cut the mounting brackets and put a steel sleeve in and then bolted it to the round tube. That would match my rear upper control arm brackets. I think i will give that a try. Thanks again for the idea.
Josh
(Project truck)
