10-21-2007, 01:20 PM | #1 |
Project "Dream Truck"
Here i go again starting over. This is what happened. I was looking for an LS1 motor for my other project when i came across a complete rollin drivetrain from a 2002 Corvette (C5) for the basically the same price as a motor and tranny. So I decided to start over. Well kind of. I am using some of the parts (the cab, wheels and tires, shockwaves) from the other build.
This time i wanted to do things a little different. The first frame i built came out great but I think i was kind of lucky that everything ended up level and square so this time i didn't want to test my luck. So i decided to build a frame table and then build a jig on top of that. The frame table is roughly 15' long by roughly 66" wide. After it was built i got it perfectly level all the way around then bolted it to the floor so it can't move. Then i built a "jig" on top of it to hold the frame as i build it. It took a little while to get everything were i needed it to be and be squared and leveled but i finally got it. Building this jig was the best thing i have ever done. It only took me around 2 half days to completely build the new frame and have it fully welded. The best part is i didn't get any movement from welding. I moved around welding in different spots which helped but the jig kept it exactly were it needs to be. I plan on building the entire truck on this frame table. I have to remove a few support pieces after I am done welding on the gussets to allow room for the suspension parts and wheels. Anyways enjoy!
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
10-21-2007, 01:22 PM | #2 |
Re: Project "Dream Truck"
A few more
10-21-2007, 01:25 PM | #3 |
Here is a pic of the rollin chassis how i bought it. Someone tried to build there own frame for a 67 nova but didn't do such a great job.
10-21-2007, 01:35 PM | #4 |
The frame table represents the ground and the jig is setup at ride height which is 8 1/2" to the frame rails off the ground. That was the height to put the front fender just above the tire so i can turn the wheels easy without rubbing.
Josh
10-21-2007, 03:35 PM | #5 |
This project is going to be AWESOME!
10-21-2007, 04:35 PM | #6 |
That's the way to go! BTW I just read about the feature truck in the latest Classic trucks. All C5 including rear transaxle but with a driveshaft instead of a torque tube. Looking into it now
10-21-2007, 09:16 PM | #7 | |
Josh
10-21-2007, 11:25 PM | #8 |
It's the Dec issue with the bare metal pre-55 truck on the cover.
10-21-2007, 11:53 PM | #9 |
Texas Big Wig
I think you should give me your old frame !!!
Sweet, can't wait to see it done this time around !!! |
10-22-2007, 08:39 AM | #10 |
Tot Roddin'
That thing is going to be sweet. Can't wait to see the build on this thing.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-27-2007, 11:58 PM | #11 |
Well i got a little more done today. I got all the frame gussets on and fully welded. It took longer than i originally thought it was going to take. I ended up spending a few hours on it so it wasn't too bad. I like the end result though. Definately stronger which equals safety. Anyways here is a few pics.
Josh
10-28-2007, 12:41 AM | #12 |
Cochino_Racing_909
what are you doing with the old frame? Dibs if possible
10-28-2007, 12:55 AM | #13 |
Well i am not sure. I thought about selling it but there still are a few things that need to be done on it before i could let it go. Plus i have too much money in the frame for most people to be interested in it. If you are really interested send me a pm and we can talk.
Josh
10-28-2007, 07:14 AM | #14 |
Happy to be here
Nice welds...
10-28-2007, 12:29 PM | #15 |
Looking good!
10-28-2007, 02:17 PM | #16 |
Nice project!! can't wait to see more.
10-30-2007, 03:46 PM | #17 |
I got a little more done yesterday. I was able to fab and install the cab supports and remove a few of the frame jig support pieces to allow room for the suspension. They took a few hours but got em done. Then i decided to install the cab on the frame to double check my measurements. I love it. It is looking like a truck again, well sorta. Early next week i am buying a hydraulic tubing bender so i can bend all the tubing that will be going inside the frame rails. I have already made all the front suspension brackets for the lower control arms and the rack and pinion so once i get the tubing bent the front suspension should go real quick. I am hoping by next weekend i can have the front suspension done or close to being done. Anyways here is a few pics
Josh
10-30-2007, 04:55 PM | #18 |
You using the vette cradles?
10-30-2007, 08:34 PM | #19 |
thats awesome, i am in the middle of making a frame table out of i-beams and 1/4" sheets ontop of it, its not gonna really be a jig but everything will atleast be level.....that truck is gonna look freakin awesome when done though!!!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife: 71 cab for sale in parts classifieds! 2004 black chevy 1500 "finish your beer, theres sober kids in india!" |
10-30-2007, 09:00 PM | #20 |
No i am building the suspension instead of using the cradles. I found a suspension program that gave me all the specs on the entire suspension. The only thing it didn't give me was the location of the rack and pinion so I ended up buying a front engine cradle so i can get the exact location of the rack. So far so good!
10-30-2007, 09:01 PM | #21 | |
Josh
11-14-2007, 01:45 PM | #22 | |
11-15-2007, 10:56 AM | #23 | |
A c5 drivetrain would be sick in that tri fives. I would like to build one in the future. Those cars look so nice when done right and they hold there value really well which is a big plus. Are you plan on building it? Anyways talk to you soon. Josh
11-20-2007, 07:32 PM | #24 |
PROJECT 7DEUCE
Thats gonna be killer..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-07-2007, 03:09 AM | #25 |
any updates? our chassis is sweet.
