05-05-2010, 07:19 PM | #26 |
Re: 1948 Chevy Project
Nice Work!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
05-06-2010, 11:27 PM | #27 |
subscribed,
like the work. those ujoints look nice. Where did you get em? They are not cheap new. I picked up some slightly bigger looking ones from conversion van at the junk yard. didn't cost much at all. The lower one mounts right up to my power steering and the upper will be connected with the D shaft and then to the stock column, pretty much what you got.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
05-18-2010, 10:37 PM | #28 |
thanks fellas! the u-joints i think i got from CPP.
more work done on this rig... took for granted that the owner was using the correct S-10 frame only to find its the wrong length frame. so i had to take 3.5" out of it. decided to do it under the rear cab mount cause i could hide the cut from the side and the plate provided in the chassis kit can be welded to the frame making the new connection stronger, plus i box the inside of the frame at said location. i made 4 guides on the top and bottom inside the chassis. welded it to the one side after removing the 3.5" then slid the frame back into place using the guides. then weld the guides to the other frame half, followed my clamping the frame walls and welding those. then install the cab mount on the 2 bolt holes the did not change and weld it all the way around. i later moved the bed mounts back the same amount and welded those to the frame as well. bare frame getting final welds air compressor mounts (there will be 2) and rear of chassis required the same 3.5" only in length to support the rear of the bed flipped the frame upside down, to make welding much much easier trans cross-member tabs (looking at the bottom here) rear chassis boxing and chassis bag bracket (again looking at the bottom here) got the motor back from the machine shop! block is a 327, but its built as a 350 with just about all new internals. basically 0 mile motor now. cant wait to finish assembling the motor! the frame is currently getting sand-blasted and will receive some black paint shorty after. |
05-19-2010, 01:19 AM | #29 |
Registered Chevy Owner
Great work on the frame. You make it look really easy. I didn't notice anywhere in the thread; where did you get the cab and bed mounts from, or did you make them?
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
05-19-2010, 12:28 PM | #30 |
Formerly- 1972SuperCheyenne
Very nice work. Great inspiration.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
05-24-2010, 11:49 AM | #31 |
nick the customer had already purchased and partially installed the "EZ chassis" kit.
frame sandblasted and primered... |
05-25-2010, 11:13 PM | #32 |
plans are to get the frame painted satin black this weekend. in the mean time i finished shaving the firewall and then drilled the firewall for the brake booster kit. also working on getting the dash ready for paint. all the while the motor continues to take shape so that once the frame is painted and plumbed i can set the motor/trans on it.
05-25-2010, 11:29 PM | #33 |
Looking good ... nice progress
Ratty 46 |
05-27-2010, 03:44 PM | #34 |
thanks
getting the cab ready so when the frame is done i can mate the two. undercoated the cab floors: painted cab wells to protect for years to come: painted cab insides that wont be visible, gas tank area, under seat, firewall and floor pans for more protection: this weekend i plan to spray the frame in a satin black in order to plumb the brakes and install the drivetrain as well as order a driveshaft. in the mean time the cab firewall, dash and suspension components will receive factory style green paint and many other small parts are and will be getting painted to make the assembly a little quicker. |
05-28-2010, 10:44 AM | #35 |
Good stuff....
http://67-72chevytrucks.com/vboard/s...d.php?t=385860 |
05-28-2010, 10:53 AM | #36 |
As a Registered user you may NOT post Want to buy ads, want to sell ads, advertise via link, sell trade
06-01-2010, 10:14 PM | #37 |
frame made it to black over the weekend, while today we got some green on some stuff.
soon as i plumb the chassis the motor trans will be mated and installed. then the cab will join while i wrap up the brakes. |
06-02-2010, 10:32 AM | #38 |
I like Green,
Good Work!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-03-2010, 09:02 PM | #39 |
thanks! i would love to one day be able to do a completely nice truck (that is painting the body too, ha)
more progress on the truck. hopefully this weekend i can install some brake hard-lines, air hoses and fuel line so that i can install the motor trans and start consolidating this project. enjoy the pics... here is a 61 Apachie i am doing a quicky on i think it being a Chevy truck you guys wont mind i throw this in here... short list of work involved in this project include; fabricate a bed floor & bed supports, shave a couple things, 2-tone paint job and a few other things here and there: before after (flat pearl orange body w/ gloss white pearl roof, tailgate & grill insert) |
06-03-2010, 09:52 PM | #40 |
6>8 Plugless........
Very nice work! That last one turned out sweet too!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-15-2010, 09:16 PM | #41 |
little progress, motor and trans on as well as some chassis plumbing.
06-15-2010, 10:34 PM | #42 |
I love 60-66 trucks as well. I am saving a 64' from the scrap yard.
I like your work. What air system are you using? Do you usually stick with the same brand and style? also it that running two compressors? I want to bag my 55.1 I think, either that or a 49' I got. Almost done with my 51' but it is not bagged. thanks Henry
06-28-2010, 09:11 PM | #43 |
Great Build. Great pics
07-02-2010, 01:48 PM | #44 |
yesterday i put the cab on the frame. its looking more like a truck now i think...
07-02-2010, 04:58 PM | #45 |
Certified Car Nut
Its looking great.
07-14-2010, 04:44 PM | #46 |
i know progress has been slow on this build, much slower than i would like it to be at least. there are a lot of ducks that havent shown up yet and well, i just gotta pull them together so i can move this along.
some parts arrived for the motor, still missing some parts too... hey at least the steering and shifter is finished... |
07-14-2010, 06:30 PM | #47 |
What type of headers will you be installing and is there any clearance issues?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
07-14-2010, 09:52 PM | #48 |
i prefer stock ram horn exhaust manifolds. personally i like the look, sound and fit. i already had mocked it up with them so there should not be any problems there. also ordered both turned back so the exhaust piping will be easier to route.
07-14-2010, 09:59 PM | #49 |
So how close to the factory green is what you used, and what did you use? Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
07-15-2010, 07:14 PM | #50 |
you couldve made it all work without having to cut the frame. nice work none the less
