Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-10-2014, 07:32 PM   #26
tinydb84
tinydb84's Avatar
Re: Building a true 500hp SBC
How do you all afford this?! I would be happy with the parts you guys throw out lol
David
Instagram: myfabguy
Old 06-10-2014, 07:57 PM   #27
71Dragtruck
71Dragtruck's Avatar
If you have kids, just tell them they won't be going to college.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 06-10-2014, 10:43 PM   #28
Super73
Super73's Avatar
My friend, we never throw something out. We just loose our butts when we sell the used parts that did not make us happy.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-11-2014, 12:25 AM   #29
tinydb84
tinydb84's Avatar
Let me know when your not happy! I'll come pick the parts up!!
David
Instagram: myfabguy
Old 06-11-2014, 08:21 AM   #30
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
^ That should be a sign in every one of our garages. You always think it, but to see it in print makes it... well... worse. Maybe if we have to look at it everyday, it would remind us to research and plan 10 times, buy once kind of thing.
I would say to start a thread on past motor/drivetrain combos that yall are tallying up (Just to put racing into real perspective) but Im afraid that if we did, that would be several badly depressed and angry board members and this place may never be the same
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 06-11-2014, 06:18 PM   #31
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Originally Posted by Marv D View Post
Exactly,, I don't wanna play that game.
all I'll say is I made just a titch under 800 at the flywheel n/a single carburated small block on a SuperFlo engine dyno, with a cam that has just a little more than the 0.050" duration of the Edelbrock 2201,,
Edelbrock: 234/238 @ 0.050",,
the cam in my Nova : 250ish/ 260ish at 0.050"
well except mines .81 lift with a custom set of Jessel 1.7 / 1.8:1 shaft rockers for the Allpro 245 Rased runner heads,,, flowing 370ish
Your cam, my heads and I'm sure you can make your 500 RWHP
as a FYI heads and valve train ran me just over $9k
That's what were getting at C20
If the cam is "just fine" whatever HP number you end up with will have to be 'just fine' also.
Building a combination around an existing component (unless it's the heads) is quite counter productive to the budget. But so be it.
Choose a fuel spec, and choose a budget and then we could offer some realistic help on your combination
Guys I'm going to run this cam first then upgrade and tweak in the future. And I totally agree that most of the money needs to be spent on the heads/valve train.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-11-2014, 06:33 PM   #32
hotrod 80
mini truck racer
hotrod 80's Avatar
I have a similar cam to Marv's now with .745/.748 lift 1.7 rockers with a smaller ( in comparison to 245 Allpros) 220 AFR comp port . Real world calculator shows 566 for this combo to achieve the et at my weight .I still have a dyno session coming up and can give those numbers . Heads=power That is why the LS stuff is so good . Factory heads flow good .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-12-2014, 06:45 PM   #33
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Marv do not forget his stock block. Large jump in hp with a sold ring seal. Only way to get that is a block that is not moving around.. Not being a dick just straight forward to the guy. I only went through two blocks before I bought the dart block ,
Me I would would not worry if the engine only made 450 HP but had a MASSIVE tq curve. But hey I am looking at a new 454 LSX set up already .. ARGGGGG Super I do not want to hear it.. Really I dont... Hey C10 I have a great dart block SBC that makes well over your goal.. tuned running ready to go built with high dollar stuff. I might get 50% return on it.
GMR-PERFORMANCE is offline   Reply With Quote
Old 06-13-2014, 03:04 AM   #34
dubds10
Stalker Nate
The 57 goes in for dyno and tune tomorrow to see its #'s. PO said the 350 was built for 500hp 13 years ago. Guess we'll see how close it is. I don't know internal specs, just external but will have a better idea tomorrow and will post up results. Even 400 would be nice and haul ass though.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 06-13-2014, 05:12 PM   #35
GMR-PERFORMANCE
I had a 355 with old trick flow heads made 473 at the crank. But that was back in 97.. heads have gotten better that is a fact. Good luck post the sheet when you are done
Old 06-13-2014, 05:39 PM   #36
Super73
Super73's Avatar
Old 07-05-2014, 11:21 AM   #37
Bad70sbchevy
Bad70sbchevy's Avatar
Why not throw some aluminum heads on it and boost it? You can run 500hp very easily while running pump gas. That's my 2 cents...
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
