Old 09-28-2021, 05:27 PM   #6751
TKCR
TKCR's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
yes please, I am not sure how hard to yank and pull on the cover and how snug to make it when I hog ring it, much appreciated
I have looked and looked. I can’t seem to find a video that shows how the curved hog ring pliers work. I guess I can make my own video.
Old 09-28-2021, 09:16 PM   #6752
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright we got an update, the right sized stainless steel zip ties arrived today (third try mind you)
Gregski is offline   Reply With Quote
Old 09-28-2021, 09:17 PM   #6753
blazer2007
Re: Restoring Rusty
I started in the center and worked out ,left and right ,sorta like welding a panel. Make sure when you do the other seat bottom or top that the sewing lines match to the the other. I didn,t and had to remove some hog rings and pull and tug to get it to match.
blazer2007 is offline   Reply With Quote
Old 09-28-2021, 09:20 PM   #6754
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so being too excited and not a patient man instead of waiting on the new hog ring pliers to arrive tomorrow I decided to mod ours, so I ground about 1/4 inch off the nubs, I swear these things were completely useless otherwise, see how far back the ring sits in there it needs to be at the very tip
Old 09-28-2021, 09:24 PM   #6755
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so when I bought my new foam I snagged this tarp like backing, I like it cause it keeps the springs from digging in to the foam, so I hog tied it in a few places to the frame first to prevent slipage
Old 09-28-2021, 09:28 PM   #6756
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then I placed the new foam on top of that black backing and boy it fit like a glove
then I had the idea of using the pillow case technique in order to slip on the cover, you know you turn it inside out, align the two corners and fold it over back on itself, but there was no need, there was also no need for the slippery garbage bag trick as the cover is just loose enough to slip right over the foam snug but effortless
Old 09-28-2021, 09:30 PM   #6757
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yes Sir, did just that! Good point.
Old 09-28-2021, 09:32 PM   #6758
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Oh O! TKCR Help, what am I supposed to do with these tails?
Of course the seat in this LMC video does not have these loose ends How to Install a Seat Upholstery Kit | Kevin Tetz with LMC Truck
Old 09-28-2021, 09:34 PM   #6759
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Well other than those silly loose ends I think it looks great!
Old 09-28-2021, 09:46 PM   #6760
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright I think I found what to do with these loose ends in this 1967-72 Chevy & GMC Truck Seat Cover replacement! #5 of 6! video
good thing I left them loose, I was tempted to tuck them under and hog clip those rat tails to the seat back frame, ha ha
Old 09-28-2021, 10:08 PM   #6761
TKCR
TKCR's Avatar
Re: Restoring Rusty
You must have a Non-tilt seat. Thats what those are for, to cover the hinge once the seatback is installed on the bottom.
Old 09-28-2021, 10:22 PM   #6762
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yep, thank you.
Old 09-29-2021, 11:26 PM   #6763
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ha, I knew I shouldn't wait on 'em pliers
Old 09-30-2021, 10:57 PM   #6764
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I had to find some pictures to duplicate and edit, to show how and where these tracks bolt to the bottom of the seat frames. Now had GM had the weld nuts in all these locations, then the frames could have been used with both the 73-76 AND 77-80 tracks.
1st pic is the 73-76 and their bolt locations.
Thanks TKCR do you have a pic of the passenger side rail and spring for the 73-76 please?
Old 09-30-2021, 11:00 PM   #6765
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
how hard can this be?
Old 09-30-2021, 11:03 PM   #6766
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
my goodness these new springs are sturdy you can so tell the difference, I feel like I can pick the seat up by a couple springs in each hand they are that firm and strong
and check out the support spring on the driver side edge, yup that's how us Semi Pros do it!
Old 09-30-2021, 11:06 PM   #6767
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and just like with the back rest, we first throw down that black thingie (actual technical term we Semi Pros like to throw around at the make believe shop)
Old 09-30-2021, 11:08 PM   #6768
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and once again Everybody wanna be Gangstah, unitl it's time to do some Gangstah stuff! am I right fellas?
these be the holes for them roller blades
Old 09-30-2021, 11:12 PM   #6769
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and the foamie foam goes on next
Old 09-30-2021, 11:15 PM   #6770
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
show us the back side, hold on a second, jeez
not too shabby if I do say so myself
Old 09-30-2021, 11:20 PM   #6771
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
next we used our finger to locate the holes for the back rest, then marked them with a silver Sharpie and used our Hole Puncher 3000 to pierce and cauterize 'em
Old 09-30-2021, 11:22 PM   #6772
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and the rails go on
Old 09-30-2021, 11:25 PM   #6773
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here is the finished product, our son was home from college so he helped me bolt on the back, it's really a two person job if you don't want to tear the pleather
Old 09-30-2021, 11:27 PM   #6774
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thanks for the heads up, your comment was in the back of my head as I was doing the bottom, and I checked the lines a couple times to make sure they matched. I think I did alright
Old 09-30-2021, 11:36 PM   #6775
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and our daughter helped me carry the seat to the truck and put it in, also a two person job if you don't want to scratch your newly painted floors
man oh man! what a ride, what a difference, ladies and gentlemen please treat yourselves and move this upgrade to the top of your project list
