Old 07-10-2007, 06:09 PM   #51
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 59 Chevy Build
Who makes the sun visor??
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 07-10-2007, 06:17 PM   #52
prostreeter58
prostreeter58's Avatar
Re: 59 Chevy Build
Brian ...
I ordered the visor from www.lmctruck.com
prostreeter58 is offline   Reply With Quote
Old 07-10-2007, 06:44 PM   #53
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
Re: 59 Chevy Build
thank you santa.....
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-10-2007, 09:36 PM   #54
71'tahoe
71'tahoe's Avatar
Re: 59 Chevy Build
Wow,Killer truck!!!!You are hauling as much hinny as the truck is going to!!!What are the specs on the wheels...back spacing,width,tire size f/r,you know the usuall stuff we need to know...Great build and doing an awsome job posting pics...nevre get enough of those pics...Very cool truck.I really dig the whole tow pig idea..thats what i have planned for my 59'.
71'tahoe is offline   Reply With Quote
Old 07-11-2007, 12:02 AM   #55
Daniel U
Daniel U's Avatar
Re: 59 Chevy Build
Wow, I love the serpintine set up. That'll be something I'll upgrade to someday. My set up is V-belt, and I wish I would've gone serpintine. Keep up the quick work. My wife's just about lost patience with our build. Maybe there should be a forum for our wifes to rant to each other.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 07-11-2007, 12:47 AM   #56
PBFAB.COM
PBFAB.COM's Avatar
Re: 59 Chevy Build
Prostreeter-
The trucks looking great! That thing will definitely move right along with that powerplant.
I noticed one thing that will cause you some problems down the road... You will want to change the upper-rear four-link mounts on your housing. You want the pivots to be in line with the rest of them, or as it goes through its travel it will bind, and eventually fatigue and break the welds. They are currently angled to match the housing, make one tab longer than the other so that the rear pivots are in the same plane as the front ones.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-11-2007, 11:11 AM   #57
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: 59 Chevy Build
it will bind anyway because it is triangulated, but porter is right, those attachment points need to be parallel.
i am not in any way knocking your build, it looks killer, but i HATE triangulated 4 links, unless hiem joints are used there will be a bind when turning. the way ford dealt with that is to use very compliant rubber bushings, that allow the links to move around some, but then the suspension angles change, which is not a good thing. that is why i am designing an offset 3-link with a phb for my truck.
i really like the way that visor looks too...
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 07-11-2007, 04:27 PM   #58
prostreeter58
Re: 59 Chevy Build
I really appreciate the input and constructive pointers that have been shared here. I am taking the advice of others and picking up a piece of chrome molly tubing tomorrow and making a new shock mount point and I ordered new tabs today to re-align the 4 link. The reason that I went with such radical angles on the 4 link is because, on my other truck (pic attached) I did the 4 link as suggested. I works fine, but, I get a little "walking" of the differential at high speeds. I figured that if I increased the angle it would eliminate that. Obviously I didn't think it through completely. Thanks again for the comments and suggestions. That is what makes this board so great.
Old 07-11-2007, 05:00 PM   #59
PBFAB.COM
PBFAB.COM's Avatar
Re: 59 Chevy Build
You were spot-on with moving the pivots closer together to "triangulate" the rear to keep the axle from having lateral movement. Keep them in the same location, just make it so the bolts that go through the tabs are parallel to the ground.
It's going to be pretty mean truck when it's done!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-11-2007, 05:49 PM   #60
prostreeter58
Re: 59 Chevy Build
Again, I appreciate the advice. I will do as suggested and if there is anything else that you see that could be improved upon, please don't hesitate to provide your expertise. Thanks, Bob.
Old 07-11-2007, 06:09 PM   #61
revn67
revn67's Avatar
Re: 59 Chevy Build
this is looking like its gonna be a killer truck when done, ecspecially for a daily driver!!! just one question, i have been looking for a serpentine kit for a bbc that is actually on a motor and i love the way that looks...how much did that set you back from summit? around 1200? again killer build and prostreet truck too!!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 07-11-2007, 07:14 PM   #62
prostreeter58
Re: 59 Chevy Build
Originally Posted by revn67 View Post
this ...how much did that set you back from summit? around 1200? again killer build and prostreet truck too!!
The system that I installed was 721.00 from Summit..........can't beat it. It list for $842.00 on the March Performance web site...........
Old 07-12-2007, 01:37 PM   #63
1-ton of fun
polishing a turd
Re: 59 Chevy Build
the ideal angle for those triangulated links is 45 degrees from center
Old 07-12-2007, 04:39 PM   #64
revn67
revn67's Avatar
Re: 59 Chevy Build
wow, that's awesome!! thanks i just found a belt system for my bbc!!
Old 07-17-2007, 04:19 PM   #65
bondobob
bondobob's Avatar
Re: 59 Chevy Build
Very nice job and I agree with the quality of the FatMan front end. I did add a triangular piece of tubing from the crossmember up the inside of the frame just for what that's worth. I didn't like the idea that it's only the bottom surface of the frame that you weld to.
bondobob is offline   Reply With Quote
Old 07-17-2007, 07:40 PM   #66
prostreeter58
Re: 59 Chevy Build
Very clean job you have done there..........I agree that the "bottom weld" leaves a bit to be desired. It has posed no problems on my other ride, but, what you have done looks so much more finished! Fatman take note!!
Old 07-17-2007, 08:03 PM   #67
low-n-fat
Re: 59 Chevy Build
Your truck looks good
low-n-fat is offline   Reply With Quote
Old 07-20-2007, 07:51 PM   #68
prostreeter58
Re: 59 Chevy Build
Well, tomorrow I am going to start spraying primer on the cab and other parts that I have stripped down so far. I am thinking about possibly going with the Dakota Digital dash. I would love to hear from people that have used this product and let me know if it is as good as portrayed. Here are a couple of pics before the primer, tomorrow I will add the "after" shots............
Old 07-21-2007, 10:28 AM   #69
chevyrestoguy
chevyrestoguy's Avatar
Re: 59 Chevy Build
Man, that thing is looking great! Every time I look at your progress shots, I can't help but notice how solid that truck is. It looks like the long trip to Arizona to go get it was worth every penny. My truck is from Southern California, and it's rust-free, but your floors look like they've never seen water or moisture. Keep posting pictures!
chevyrestoguy is offline   Reply With Quote
Old 07-21-2007, 08:43 PM   #70
prostreeter58
Re: 59 Chevy Build
[QUOTE=chevyrestoguy;2272688] I can't help but notice how solid that truck is. QUOTE]
The amazing thing about it is, not only is it rust free, it is free from any dents!! An almost 50 year old farm truck and no dents. even the bed header panel and the rear wheel wells, no dents. It makes this build so much more enjoyable knowing that I don't have to spend a lot of time filling and sanding.............strip, sand, prime, sand, and paint........gotta love it.
Old 07-22-2007, 11:09 AM   #71
prostreeter58
Re: 59 Chevy Build
Well spent the day doing all those tedious parts. Blasting and spraying them with primer........................The back wheels are supposed to be in tomorrow. This has been the hold up on getting the bed and cab off the frame. I went with 20 X 10 with 6" back-spacing. I am sweating bullets wondering if they will fill the hole as expecting. Beint that they were special order, I doubt if an exchange is an option. Tomorrow will tell the tell.
Old 07-22-2007, 12:39 PM   #72
Igotachevyor2
Apache Club
Re: 59 Chevy Build
lookin good
Old 07-22-2007, 05:28 PM   #73
allen57
Re: 59 Chevy Build
hey i got a question or 2 on ur pic. i want to figure out what they are.
1. in the first pic, what is that bracket right below the the gas filler neck.
2. what are those 2 brackets between the 2 hoodhinges and the topleft of the door hinge cover.
i have all those brackets, but idk what they are
allen57 is offline   Reply With Quote
Old 07-22-2007, 06:42 PM   #74
prostreeter58
Re: 59 Chevy Build
The first bracket that you question is a front bumper bracket........the second is the glove box door brackets...................hope this help you.............
Old 07-22-2007, 08:45 PM   #75
allen57
Re: 59 Chevy Build
cool thanks. what about the the bracket thats below the top hood hinge. it has 3 holes on it and has a rounded over edge. its in the 2nd pic
