#51 |
![]() Join Date: Aug 2006
Re: Project "Dream Truck"
Well i went downstair right after you gave me that idea. I cut off the factory alluminum mounts and then pressed out the rubber and the remaining alluminum. Then i remembered i bought a set of rubber inserts for my old cantilever suspension set and was curious if they were similiar sizes. Turned out that they we almost perfect. I had to lightly sand it a little to make it fit but i couldn't believe it. What luck
![]() Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#52 |
Well i got the other side done. I think it looks much cleaner.
Josh
#53 |
![]() Join Date: Aug 2005
Nice! That sleeve looks like it's more than enough for the job.
#54 |
Well i got a little creative on the upper control. I wanted something clean and not so big like the factory mounts. So i was talking to my father when some how we got on to the conversation of his mill and how i never have used it before and would like to learn. So he gave me a quick run down on how to use it and i went to town. I want to grab all sorts of steel and mill it down now to something cool
![]() Josh
#55 |
a couple more. I was very camera happy.
#56 |
looks way cleaner, nice job.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#57 |
LAIDOUT
Note to self [me]; buy a lathe and a mill and learn how to use them...
Looking great man, love your work! |
#58 |
Well i roughed in the mount for the control arm this morning. I think i like it. I am not sure how to finish the lower part that goes at an angle. I am not sure if i want to blank it off like it did with the other setup or just add another gusset in the middle. Also i didn't add the inner support gusset on the inside of the bracket because i was going to have the shockwave mounts tie into the bracket to reinforce the bracket and give the shockwave a nice solid mounting piece. Next weekend i will hopefully get the shockwaves installed in the front so i get that all finished. Here is a few pics and hope you guys have a MERRY CHRISTMAS!!!!!!!
#59 |
Commander Taco Bello
great work man. some day in the distant future I'll have the room for all of the toys/tools you have.
#60 |
Josh actually does not have a huge shop. He works out of his 2 car garage right now.
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
#61 |
any more progress? great job like the new upper control mounts.
#62 | |
![]() Josh
#63 |
Josh your frame is looking very well thought out and built! Who did your torque tube for you and if I may what kind of $ are they charging for it? I have been toying with some C5 ideas but teh tube is the one area I have not yet looked into.
Kevin LFD Inc. |
#64 | |
Josh
#65 |
Well i got the motor, torque tube, transaxle all put together in the frame. The only that sucks is i am going to have to replace the oil pan. I was hoping i wouldn't have too but the motor needs to drop a little more to make everything level. So right now the motor, torque tube, and the transaxle are at a slight angle until i get a new oil pan. I extended the torque tube yesterday and today which was very time consuming. I made a jig that held the factory torque tube so nothing would get twisted or unlevel. Then i cut the alluminum tube and took it over to my fathers house to use his mill. I used his flycutter to cut the inside of the bellhousings to remove the pressed in and welded alluminum tube. I ended up having to flycutt .050" more so the new tube would fit on both sides. I wanted it to fit in the bellhousing without any slop or play so that took a little while. After all that was done I was able to weld it up. It came out perfect. I am hoping to send off the driveshaft next week to have the new carbon fiber drivshaft built.
I finished the front suspension yesterday also. I wasn't able to use my new designed control arm mount because i couldn't get enough clearance for the shockwaves. I ended up having to use the factory style mount and use 5/16" camber spaces to give me clearance for the bags. I could have used a shorter shockwave but i want all the lift i can get which isn't much. I think i will get right around 5.5-6". I ordered new poly bushings for all the control arms which are supposed to make a big difference in the handling compared to the rubber ones now. Tuesday i get them so hopefully i can get them pressed into the front control arms so i can hook up the passanger side upper control arm. I still have to finish bracing up the front rails but wanted to see if how the new oil pan sits so i don't have to change anything. Also since the torque tube is installed i can modify the main rails tomorrow and get those finished. Josh
#66 |
A few more pics
#67 |
Nice progress. Finally someone with some info on extending a torque tube!!! You know we need more pics and details on that!
#68 | |
Josh
#69 |
Well i got a little more done today. I finished bracing out the center section of the rails. It is nice and strong now
#70 |
Dang josh, looks killer. cant wait tell my frame gets that far.. also cant wait to see it on the ground...
#71 |
Looks great, love the wheels!
Kevin LFD Inc. |
#72 |
What are the specs on the tube itself and who did you order the shaft through?
#73 | |
![]() Josh
#74 |
Tonight was a great night. I finished up the motor mounts so FINALLY the drivetrain is self supported. I know i have alot to do still but i really feel like i will be finished with the frame soon. I also got the new poly bushings for all of the control arms so i was able to put back the passenger side upper control arm and put my wheels on. Anyways here is the only pics that came out of the new motor mounts.
Josh
#75 |
I new around here big on a couple other forums, but I couldn't leave without saying how amazing this project is, keep up the good work.
