Old 02-27-2010, 08:48 AM   #51
eventytoo
Re: Project 54 short
Originally Posted by Dan Bowles View Post
I've got a local guy that swears by the glass fenders. He drives his truck year round here in MI so it's a must. Salt sux.
True!
eventytoo is offline   Reply With Quote
Old 02-27-2010, 08:52 AM   #52
eventytoo
Did a little priming last weekend. Little b4 and after.
Old 02-27-2010, 09:05 AM   #53
eventytoo
I pulled the motor and pulled it apart. The block looked good small ridge on top so its getting bored .030. The crank and bearings looked great. Took the block and heads in for machine work. Having him clean, check for cracks new cam barrings put in and new frost plugs. The heads cleaned, new seals, and inlarge the spring area for larger springs.
http://www.hotrod.com/techarticles/e...ild/index.html
Kinda copyin what Hot Rod did except not as wild. More on the mild side.
Old 02-27-2010, 10:07 AM   #54
53GMC
53GMC's Avatar
I love this project and the 72 Chevy Custom for sure!! You have great talent! Keep the pics and updates comin!!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 02-27-2010, 03:35 PM   #55
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Looks good!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 02-27-2010, 07:22 PM   #56
99 to Life
99 to Life's Avatar
Subscribed.
I am diggin the work. I am doing the same with my fenders, only
the outsides will look weathered and beat up.
Lots of space, must be nice.
I just picked up a 55.1, I love those grills too.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-13-2010, 03:05 PM   #57
eventytoo
Plinted the back side of the hood last weekend. I got the motor back from the machine shop.
I layed down 3m rocker pannel spray on the back side to reduse noise. Dont know if it will be any quiter but it looks nice in my opinion. Sanded and prmed some other things not to exciting. What im doing this weekend filling sanding blocking prining sanding. Tons of fun.
Old 03-13-2010, 03:14 PM   #58
eventytoo
I noticed the stock hood latch is crap compaired to the technolgy today. So I put some parts together and made my own.
Old 03-13-2010, 04:09 PM   #59
nickp51chevy
Nice! I like that green color. What is the name of the green? What did you use for the hood latch?
Keep the pictures comin.
Had;
Old 03-13-2010, 06:11 PM   #60
eventytoo
96 GM color all I can say the rest is a chinese secret .
latch is a pont. latch off a sunfire
Old 05-01-2010, 10:34 PM   #61
eventytoo
Motors done and back in. Iv got a list of parts to finish it completely.
Old 05-01-2010, 10:41 PM   #62
eventytoo
I've got the same question here! I pushed my rad WAY out at the bottom to clear when I used the stock one. I trimmed back the bottom air dam from the grill. I'm starting another AD/S10 now and am looking for options.
Looks good on a short box frame, by the way.
Some pictures of the core support. Built kinda heavy, but it will do.
Old 05-01-2010, 10:50 PM   #63
eventytoo
Worked on the trans hump today. The shift tower is huge on this trans. Im letting part of it go into the shift boot so its not to high in the center of the floor.
Old 07-17-2010, 10:52 AM   #64
MarKist
MarKist's Avatar
Thumbs up Re: Project 54 short
any updates on your build?
Markist
oh well,..you'll have that!!
MarKist is offline   Reply With Quote
Old 07-28-2010, 10:25 AM   #65
eventytoo
All metal work is done to the cab. I repalced..... the drivers side inner an outer cab corner, inner cowl and lower outer cowl on the drivers side also. The lower outer cowl panel on the passenger side. The passenger side cab corner looked ok so i left it alone.
The inner cowl pannel did not fit worth a hoot. I had it cut-sectioned in 6 pcs. and welded back together in order to make it work.
The doors are both fited and open and close nice. I left the stock latches and am also keepin the door handles. I had a hard time gettin the doors to fit. I found that heating the hinge in bending in works. But had to elongate the mounting holes.
I replaced the drip rails glued them on using Fusor 108b.
I have been working on smothing the firewall filling and sanding filler. But that has been going slow with lack of anbition an other things going on.
Old 08-03-2010, 07:19 PM   #66
shane o
Man love the trucks, I'm working on 1947 and drive an 87.
Do you live in UT ?
shane o is offline   Reply With Quote
Old 08-13-2010, 12:48 PM   #67
eventytoo
Do you live in UT ?
No
Old 12-18-2010, 07:01 AM   #68
eventytoo
painted cab and doors...
Old 12-18-2010, 10:05 AM   #69
Fat Mike
Fat Mike's Avatar
Very nice paint job. Love that color!
Fat Mike is offline   Reply With Quote
Old 12-18-2010, 11:48 AM   #70
99 to Life
99 to Life's Avatar
Diggin the build and that color. I am a Patina fan, but I really do like that green. I have a question. Where did you get your adjustable alternator shaft (don't know what the actual name would be) but the chrome one you got that allows you to adjust your alt to tighten your belt.
My alternator's shaft is too short, to run with my pulleys. I use a cog belt and couldn't seem to find one shorter. So I needed to make my own alternator adjuster shaft. Mine is 1.5" and I needed a 3". Made one, but it would be nice to have a chrome one and or a back up one in case it broke or something?
anyway, thanks and looking forward to seeing this one done.
Old 12-18-2010, 07:21 PM   #71
eventytoo
http://marchperf.com/pg51.html#rods
I bought the kit from summit racing. Rod was to long had to shorten it. Note.. one side is LHT the other is RHT. So be careful when shoting or you will need to buy a LHT tap. They make nice stuff all stainless and billet.
Old 12-18-2010, 07:34 PM   #72
thirdstreettito
Resident of Here
thirdstreettito's Avatar
What color is that? It looks like a 07-09 Tahoe color.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-19-2010, 03:53 AM   #73
BC Toy chest
BC Toy chest's Avatar
Lookin' good bro, like your toys and love the toy box you keep them in even more.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 12-19-2010, 07:27 PM   #74
99 to Life
99 to Life's Avatar
thanks for that link.
Yeah I already made one, bought the tap and everything. I was going
to make another, but I would rather have a chrome or billet one.
Old 04-15-2011, 04:58 PM   #75
eventytoo
Well its been a while. Ill have pics soon. . . .
