Old 03-22-2009, 05:08 PM   #1
eventytoo
Project 54 short
I figure its time to start a build thread. Feel like crap today would rather be working on the truck than on here but when your sick your sick.
Anyways the truck im workin on is a 54 3600 3 window. Bought it for a 1000 bucks from a farmer a little over a year ago. The plan is to make it a driver sence the other two trucks iv built sit more than i want them to. I searched around found out that an s-10 swap is the rute i wanted to go. Looking back now im a few thousand bucks ahead going the s-10 rute but id never go that rute again. Time for some pics.
eventytoo is offline   Reply With Quote
Old 03-22-2009, 05:19 PM   #2
eventytoo
Re: Project 54 short
reason it was parked.... broken fuel line... The hich came in handy to pull it outside to wash it...
Old 03-22-2009, 05:35 PM   #3
eventytoo
87 s-10 short box reg cab.... it was cheep and drivable.... 95 c10 rearend 343 gears went threw it all barings seals ect. ... 95 c10 4.3 v6 with an nv4500 trans higher 1st ratio pored gas in the throtle body one turn and it ran.
Old 03-22-2009, 05:50 PM   #4
eventytoo
air ride 3 link ..... joke went to a trianglated 4....mar-k bed shortened...17 gal tci fuel cell between the rails marine fuel cap...
Old 03-22-2009, 06:00 PM   #5
eventytoo
All mocked up... tail lights and roll pan...
Old 03-23-2009, 11:19 AM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Looks good!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-23-2009, 11:43 AM   #7
Houston54
Looks like a great start.
Let me know if you are not planning to re-use that radio delete plate.
Houston54 is offline   Reply With Quote
Old 03-23-2009, 12:08 PM   #8
65panelrat
65panelrat's Avatar
Awesome Truck! Nice Work!!!
Bowties For Life!🇺🇸
65panelrat is offline   Reply With Quote
Old 03-23-2009, 12:20 PM   #9
b00sted
b00sted's Avatar
Are you sure on the NV being a 4500? I would think more along the lines of a 3000 with a little motor like that.. My Cummins has a 4500 behind it...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-23-2009, 08:22 PM   #10
Daniel U
Daniel U's Avatar
Very cool to see another '54 out there. Mine started out as a 3600 long bed as well.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 03-24-2009, 01:45 AM   #11
eventytoo
cast centre section, pto plate. rpo codes in glove box all lead to prof of a 4500. Wanted a heavy trany that I could rebuild without hassle. Nv 3500 are great but only once can you rebuild it an would be worth the time. A t-56 is what I would of liked but heck thats out of my price range.....Yes im holding on the the delete plate a factory raido would be nice but again price is high on those to just gonna paint it with the raido openings in it. If I find a radio or put the delete plate back in place...?... Time will tell...
Old 03-24-2009, 07:27 AM   #12
63 & 64 Bowties
and a few others
Wow, looking good. Nice shop too.
Any info you'd like to share about the body mounts?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 03-24-2009, 07:55 AM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What a great build, nice work so far!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-24-2009, 07:13 PM   #14
b00sted
b00sted's Avatar
well you wil lnever need another transmission.... I cannot see a gas motor breaking that thing. Weld the 5th gear nut on as they have an issue vibrating loose and you loseing 5th gear..
Old 03-25-2009, 01:48 AM   #15
eventytoo
The body mounts I made myself. 5 inches off the frame. IF I went 3" the boards would be on the ground. Used 6 rear cab rubber mounts off of an s 10. Got the front rear of the cab and the core support all on those mounts. The radiator im using is out of a caprice 4 core cross flow with a spall fan 26" wide 19" high, had to widen the core suport a bit to make it work.
Thanks for the pointer on the tranny.
Old 06-02-2009, 04:36 AM   #16
eventytoo
got a new hood from dynacorn fot the grill blasted and in epoxy
Old 06-02-2009, 04:44 AM   #17
eventytoo
all what got blasted and primed
Old 06-02-2009, 04:55 AM   #18
eventytoo
How meny of you all that are doing the s10 frame swap are running power steering. The truck came with manual box but the bearings are out of it. I priced a new one to replace the oe unit and it was over $200. I have several pumps off of other projects just laying around. And was thinking that a power box would be the way to go but im not sure if its all that needed.
Any input on the power steering would be great.
Old 06-02-2009, 07:46 AM   #19
my67chevytruck
Under Construction
my67chevytruck's Avatar
good looking project.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-02-2009, 08:46 AM   #20
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
Nice project. I dig your shop space too! Cant beat that in the winter!
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 06-02-2009, 08:51 AM   #21
bensimmons_05
bensimmons_05's Avatar
Great looking project so far, Keep us updated!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 06-02-2009, 03:02 PM   #22
Kabwe
Certified Car Nut
Kabwe's Avatar
Nice project, I'm so lucky I don't have that kind of space. I would be devorced.lol Man I can see it filled with projects.
Kabwe is offline   Reply With Quote
Old 01-14-2010, 11:53 AM   #23
eventytoo
Lots of canges have pics soon.
Dii hood not used went with a stock one. Dii hood for sale.
Frame is blasted an painted. Rear suspension moved back 3 inches.
Superior glass fenders and running boards. 2 inch wider
All new front end componets.
Cab is blasted and in primer.
Im shotining the rumming boards right now.
Old 01-14-2010, 12:16 PM   #24
bjcaldwe
bjcaldwe's Avatar
Another nice project to keep up with. Looks good.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 01-14-2010, 05:42 PM   #25
BlueJeep
BlueJeep's Avatar
Can you post pictures of how you did the radiator support?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
