Old 10-03-2013, 01:13 AM   #51
likaroc13
Rollin' Old Skool
Re: LT1 Burbs 65 Stock SW Build
Subscribed! Saw some of your posts about the build previously, but now I can follow along. I like what you're doing, & it's looking great. Keep up the good work.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-03-2013, 01:17 AM   #52
pimpston65
pimpston65's Avatar
awesome build, kudos for keeping it factory stock, got a question im asking this cuz I noticed ur PG case apart and ur perty painted finish with the same auto selector levers as I have, so I finally got a roller and noticed my powerglide kickdown lever, the one on the case is in a odd position when I manually put it in park it will bind with the lever/rod thingy, is it a simply fix to remove the kickdown lever from the case a just move its position and slide it back into the case? pics of my to follow
pimpston65 is offline   Reply With Quote
Old 10-03-2013, 01:22 AM   #53
pimpston65
pimpston65's Avatar
here's my issue, any help would be great
Old 10-03-2013, 01:42 AM   #54
LT1 Burb
LT1 Burb's Avatar
Thanks guys, will your PG linkage not rotate up anymore. If it won't you may have to drop the pan and pull it out and reposition it. I think the kickdown linkage won't be long enough where its at , but I am not a powerslide expert.
LT1 Burb is offline   Reply With Quote
Old 10-03-2013, 02:31 AM   #55
pimpston65
pimpston65's Avatar
thks for the responds, it was rebuilt by a friend of a friend, when I sent it out it wasn't in that spot so when I got it back I didn't think twice bout it, and it sat for a few months til I installed it last month. the rod is long enough but when the rod is attached, the automatic gear lever part will hit the rod and wont fully engage into park, I was thinking I needed to go into the trans, I got a PG rebuild video online. ps wish me luck im not afraid,just don't wanna spend good cash after such a crazy long build having someone fix my messup. thks again...
Old 10-06-2013, 12:55 PM   #56
LT1 Burb
LT1 Burb's Avatar
With my neighbor's help we flipped the cab back upright. I spent a few more hours on a grinder, hung a door to make sure everything would fit for final rocker panel welding. I just have to POR15 all the inner rocker stuff and weld them up.
Old 10-06-2013, 01:11 PM   #57
LT1 Burb
LT1 Burb's Avatar
Originally Posted by pdxhall View Post
Nice work man! The frame looks great. I'm in the process of installing my brake lines and I was wondering if you would mind showing some pictures of how the lines are routed from the back to the front and across the frame at the front. It would help me a lot. Thanks.
Sorry , I keep forgetting but these were inline tube brake lines, I hope this is what you needed.
Old 10-06-2013, 03:43 PM   #58
Bomp
Bomp's Avatar
Nice to see the clean work that you do.
Looks great.
Bomp is offline   Reply With Quote
Old 10-06-2013, 06:19 PM   #59
pdxhall
pdxhall's Avatar
Thanks, man. That's exactly what I needed. I have inline tube, also.
By the way,the patching looks great.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 10-06-2013, 09:16 PM   #60
LT1 Burb
LT1 Burb's Avatar
Thanks guys, found a use for the 33.00 rocker that didn't fit worth a crap.
Old 10-26-2013, 06:19 PM   #61
LT1 Burb
LT1 Burb's Avatar
Cleaned up the holes in the floor that someone hacked in for seatbelts. Had to use a 1/2" knock out cutter to clean up the holes and then cut some plugs and welded them up.
Old 10-26-2013, 06:22 PM   #62
LT1 Burb
LT1 Burb's Avatar
60-66 only shop.
Old 10-26-2013, 10:19 PM   #63
pimpston65
pimpston65's Avatar
wish my garage was as clean, glad ur making progress. I have another question I would like some help on. The larger hole on the firewall next to where the speedo and e-brake goes through the firewall is that for a clutch rod? I have an auto so if you know, does a rubber grommet cover that or what?
Old 10-26-2013, 11:00 PM   #64
LT1 Burb
LT1 Burb's Avatar
There should be a rubber grommet, this was an auto truck also.
Old 10-26-2013, 11:19 PM   #65
NEWFISHER
NEWFISHER's Avatar
Pull the sheets!
NEWFISHER is offline   Reply With Quote
Old 10-27-2013, 12:35 AM   #66
Slammed66
Needs a Big Block
Slammed66's Avatar
Wow great build!!
Your attention to detail is outstanding!!
I met you in Portland this spring at the swap meet. , regardless. Keep it up!!!!
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 10-27-2013, 02:20 AM   #67
LT1 Burb
LT1 Burb's Avatar
Thanks slammed, I had to put it away John, it was getting covered in dust.
Old 10-27-2013, 10:10 PM   #68
LT1 Burb
LT1 Burb's Avatar
Woohoo, after probably 200 hours of labor my floors are finally finished and ready for paint.
Old 10-27-2013, 10:16 PM   #69
LT1 Burb
LT1 Burb's Avatar
Now onto the next hack job, I wonder if people realize how many hours it will take to fix stuff like this in the future.
Old 10-27-2013, 10:23 PM   #70
likaroc13
Rollin' Old Skool
Woohoo! Nice work. When will the paint fly?
If you're referring to those who hacked, I'm sure they could care less! Glad mine wasn't hacked much, but I do have at least one questionable "modification."
Phillip
My Build threads:
Pics:
Previous Rides:
Old 10-28-2013, 01:14 AM   #71
LT1 Burb
LT1 Burb's Avatar
Paint won't fly until the speaker holes are fixed, then block out back panel and prime.
Old 10-28-2013, 01:24 AM   #72
NEWFISHER
NEWFISHER's Avatar
Its looking good! One small area at a time, at least there aren't any 6x9s cut into the doors too!
Old 10-28-2013, 01:42 AM   #73
1966burb
1966burb's Avatar
WOW. Great job. Any chance of a picture of the rear power steering pump bracket that goes from the rear of the pump to the motor mount?
1966burb is offline   Reply With Quote
Old 10-28-2013, 07:49 PM   #74
LT1 Burb
LT1 Burb's Avatar
Here ya go.
Old 10-28-2013, 09:31 PM   #75
LT1 Burb
LT1 Burb's Avatar
Had a half hour before dinner so knocked this out, Cut the hole, templated it and got it welded in.
