LT1 Burbs 65 Stock SW Build
Well, see how this goes, I have never done a frame off so lets give this a shot. It is going to be a 65 short fleet BBW Custom Cab, factory air, PS, PB, 283 auto with tach and clock.
Re: LT1 Burbs 65 Stock SW Build
Got the rear end back and picked up more parts from the powder coater's.
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Welcome aboard!
It looks like you got a great start. I'm doin a similar build! |
![]() Join Date: Sep 2011
I'm in for this build. Looking great so far, LT!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
![]() Join Date: Mar 2012
Looks awesome. I'm sure you'll do a great job like your Suburban. Thanks for your help on my build.
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
LT1 Bulb, I see you live South of Eugene. I work in Eugene alot. I should come by and say hi.
You don't work for Trane in Pueblo do you?
No I don't. I work for Union Pacific Railroad. I manage bridge construction projects for the western states and work in Oregon lots. I have a bridge project in Shedd, Tangent and .
Darn mobile phone. And Jefferson, Oregon.
Put the front end almost back together but with no motor or weight I had no luck with the coil springs. Did get the rear end bolted back in with the springs and shocks mounted. Anyone know if there is a left and right spindle, I say no as they look identical to me.
#12 | |
#13 |
LT1, build looks great, I have a 66 bbw, 283, powerglide, p.s, also just have not started it yet.....Your build looks great.....good luck on the hunt for all the pieces.............Kieth
ps I pm's you off forum for some LT1 engine help. Thanks in advance Kieth ![]() |
#14 |
Just got the front end put together, should be a roller by the weekend, rebuilt the steering box and the power assist valve along with the ram.
#15 |
One rolling chassis done. Now I get to dig into the motor and trans.
#16 |
Working on the motor and trans now. Had to send the trans through a parts washer, that crap on there would not come off. I stood in one spot with a 4000 PSI pressure washer and it didn't do anything. Motor is bored 30 over with new everything so should be good for the life of this truck now.
#17 | |
#18 |
Nice job so far, tuned in for the rest of the build!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#19 |
i'm in, man your flying on this thing and it looks great. are you going back with a complete original format?
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#20 |
#21 |
Im in too.
#22 |
Just catching up on my thread, restored my AC oil cap, although I believe the decal is the wrong one. I believe the right one is blue/white , anyone weigh in.Hopefully this weekend I will mate the motor trans with the frame to give me some room in the shop.
#23 |
Rebuilt my AC delco starter with cheap american starter guts. I had two here and thought I would try it and it works great so I get to keep my numbers matching original starter.
#24 |
Awesome Build LT1. Can't wait to get started on mine but have to get the garage finished first. I have question what paint did you use for the engine? I'm not going back stock but love the engine color!
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#25 |
It was a grey I got Industrial finishes to mix up from one of the original valve covers I had.
