Old 07-28-2012, 01:23 PM   #76
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: My 4wd to 2wd Conversion
Originally Posted by Ford Assassin View Post
430 to the wheels, not the crank.
It actually dead hooks, gets alittle squirmy on the 1-2 though (usually blows the tires away for a sec).
To be honest, with my luck on blowing 8.5" 10 Bolts to pieces, I am a bit cautious to start power braking just for the fun of it.
I just upgraded my ten bolt with 3:73 gears and 30spline axles from a 90's truck and a true track diff and a t/a stud girdle/cover. With some moser axles and strange c clip eliminators the 8.5 and car 12bolt are close in comparison
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-28-2012, 02:05 PM   #77
Ford Assassin
Ford Assassin's Avatar
Although I agree with those upgrades a 8.5" can be built very stout, I don't have that much faith in my stock '87 28 spline unit and I am tapped on 'toy' funds for the time being.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-29-2012, 06:21 PM   #78
68Timber
I know the pieces fit
68Timber's Avatar
I know its to the wheels, I meant personally I'd be happy with numbers like that at the crank. That's actually the power level I'm shooting for with my 383. I hear you on skipping unnecessary driveline abuse. I'm hoping I didn't "over tire" mine. Anyway, if you ever make a rolling vid I'd like to see it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-31-2012, 02:56 AM   #79
Ford Assassin
Wink Re: My 4wd to 2wd Conversion
I misunderstood your meaning, sorry about that.
I'll see about getting some video shot from another car while driving.
Cable
Old 09-23-2012, 07:39 PM   #80
K6.0
What kind of MPGs are you geting? Awesome build. I hope to start on my 91phone 4x4 2wd ls conversion soon
K6.0 is offline   Reply With Quote
Old 09-23-2012, 07:51 PM   #81
K6.0
I ment blazer
Old 09-24-2012, 12:34 AM   #82
Ford Assassin
I get about 14 in town and 18 on the highway, but I tend to drive pretty aggressively.
Cable
Old 09-24-2012, 02:00 AM   #83
INSIDIOUS '86
Well when you do get the driveshaft dynamically balanced and some 1350 u joints and the ten bolt built and your good for 600 to the wheels
Old 10-19-2014, 10:30 PM   #84
bdiamond
Truck looks awesome.I know this is an old thread, but did you ever sell the rollbar? Is it aftermarket?
bdiamond is offline   Reply With Quote
Old 10-21-2014, 03:15 PM   #85
Ford Assassin
Thumbs up Re: My 4wd to 2wd Conversion
Sold years ago....
It was built from a kit from Competition Engineering.
Cable
Old 10-28-2014, 12:04 PM   #86
dman1982
dman1982's Avatar
not sure if you did this already or not, but with my short bed k10 and 4l60 i was able to use the drive shaft out of a 2000 camaro/trans am, pretty much the same length u joints, but weighs a lot less....not sure if it'll work with the 4l80 or not but just a thought
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 11-04-2014, 04:22 PM   #87
Ford Assassin
The conversion has been finished and driving for over 2 years. The 4L60e and the TH350 share the same transmission slip yoke, but the 4L80e uses the same as a TH400.
Cable
Old 03-14-2016, 09:24 AM   #88
70blackfish
how is the blazer 2 years later?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 03-14-2016, 09:38 PM   #89
Ford Assassin
4 years later since the conversion....
6.0 turbo setup made 690 to the wheels, hauls ass.
Cable
Old 03-14-2016, 10:18 PM   #90
Ford Assassin
I also ditched the 8.5" 10 bolt for a 9.5" 14 bolt, custom 5x5 axles, Detroit Locker, 4.11 gears, etc.
Cable
Old 03-15-2016, 09:33 PM   #91
dragonball98312
dragonball98312's Avatar
One of my favs on here, will be using the pics when I get around to my full convert conversion. Now you just need a 73-80 front end and youll be done lol
dragonball98312 is offline   Reply With Quote
Old 03-15-2016, 09:50 PM   #92
Ford Assassin
No no. If I do any changes to the front end, it would be a '89-'91 headlight/grille/core support swap.
I like the square look vs the rounded off look. To each their own.
Cable
Old 06-10-2016, 06:07 PM   #93
mjbdesigns
Considering attempting this same conversion (4wd to 2wd) and wondered if you may have a cheat sheet on the major components needed to complete the swap? Especially now that you've done yours from what you've learned...
I also worry about having to drill holes to mount stuff up front as I hate to drive down the road sideways....
mjbdesigns is offline   Reply With Quote
Old 08-30-2016, 07:38 AM   #94
jbristo67
resident oilfield trash
jbristo67's Avatar
In
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 11-26-2018, 02:34 AM   #95
Ford Assassin
New turbo setup.....
Cable
Old 06-18-2019, 03:17 PM   #96
Koz1
pm sent
Koz1 is offline   Reply With Quote
