Old 05-21-2012, 10:09 AM   #1
Ford Assassin
Ford Assassin's Avatar
My 4wd to 2wd Conversion
Hey guys, I starting posting some of this in my 5.3/4L80e swap build thread, but figured maybe it'd be easier to find in its own thread for those interested in doing the same thing down the road.
http://67-72chevytrucks.com/vboard/s...d.php?t=489826
Anyway, the truck is a '86 K5 that already has a '73-'75 full convertible conversion and a 5.3/4L80e swap. After completing the swap I went off road a few times and realized that it just isn't my thing anymore. So if I am not going to use a 4x4 for its intended purpose I really don't wanna climb in/out of it for ever and wouldn't mind a little better MPG. Plus 2wd K5's are somewhat rare and never offered after '82.
Here are a few pics of the truck before starting the 2wd conversion:
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 05-21-2012, 10:25 AM   #2
1bad87
1bad87's Avatar
Re: My 4wd to 2wd Conversion
nice setup where did u get the bracket for the old a/c comp
1bad87 is offline   Reply With Quote
Old 05-21-2012, 10:45 AM   #3
Ford Assassin
After I decided to make the push, I started searching for parts, lucky for me I found a guy that bought a 2wd '87 long box just for the body and had no interest in much else (except steering box).
So I cut the whole frame off at the firewall and grabbed the 8.5" 10 bolt (open) with 3.42 gears (will add a Eaton True-Trac later). I also grabbed the rear leaf spring hangers (shorter than 4wd version).
After I got everything home I tore it all down, bagged all the bolts, and pressure washed everything. I knew since it was all apart I was going to 'snowball' and I'd end up rebuilding most of the the front end. Sure enough I bought all new urethane bushings, ball joints, rotors (1.25"), and calipers (reused 2 month old ceramic pads from 4wd).
A buddy also gave me a pair of 56" rear springs (stock K5 and most 1/2 tons are 52") with the center pin offset 4" to keep the wheelbase the same. The 56" springs have thinner leafs and the longer spring should provide a smoother ride, especially on a such a short wheelbase truck like K5's.
Cable
Old 05-21-2012, 10:46 AM   #4
Ford Assassin
Its not the old A/C compressor. Factory had the old radial R4, this is a Sanden 508. I bought the bracket from Kwik Performance (www.kwikperformance.com).
However, if you want to keep you R4 with an LSx, Novak sells the brackets you are looking for. Personally I like to avoid the R4's like the plague, they are junk IMO.
http://www.novak-adapt.com/catalog/a...cation_kit.htm
Cable
Old 05-21-2012, 10:56 AM   #5
Ford Assassin
Then came time to tear into the K5... Sold everything....
Be prepared to use a grinder and a decent stone, because you will be removing a lot of rivets. Rear hangers, rear and front bumpstop brackets, front crossmember, front brake like brackets, etc...
Cable
Old 05-21-2012, 11:16 AM   #6
Ford Assassin
Since I am going to use 56" springs, I needed to move the rear hanger 4" further to the rear. Most truck frames have the holes in the frame pre-drilled since 56" springs were optional, since K5's weren't offered 56" I just measured and welded them in.
More pics......
Cable
Old 05-21-2012, 01:09 PM   #7
trout
wow this is nice info man
Edited by staff
trout is offline   Reply With Quote
Old 05-21-2012, 07:16 PM   #8
Square_78
Square_78's Avatar
Cool project. With the full convert top already done, are you going to keep the newer front end or put on a 73 style front fenders and round eyes? That would be the icing on the cake so to speak.
Square_78 is offline   Reply With Quote
Old 05-21-2012, 07:19 PM   #9
Ford Assassin
Nope, keeping the '86 front end. Might put a phantom grill on it next (headlights behind the grill) or putting a '89-'91 front end on it. Never been a huge fan of the round headlight front end.
Cable
Old 05-21-2012, 07:43 PM   #10
Ford Assassin
Here are my wheels and tires, 245/45/20's on 20x8.5" rims and 275/40/20's on 20x10.5" rims.
Cable
Old 05-21-2012, 08:18 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Cool project.
I see you already swapped the rear hangers.
Some people that do a "flip-kit" in the rear actually use the 4x4 hangers, so the rear won't be so extremely low.
(lower than the front)
I'll be watching this thread.
Keith
Convert to disc brakes.
Old 05-21-2012, 08:31 PM   #12
Ford Assassin
Cool project.
Hopefully the rear won't be too low, I guess time will tell. As much as I hate them, I might install air shocks in the rear as a bandaid if the rear is too low, especially when I tow my camping trailer. Long term plans include going to a behind/below axle mounting air bags and removing all leafs except the top and overload springs.
Cable
Old 05-22-2012, 06:06 AM   #13
outcrydrummer
Do you happen to remember which transfer case that was and do u have a pic of the crossnember. I just converted to a th400 and the transfer i got with it was that one but i dont have the correct crossmember.
outcrydrummer is offline   Reply With Quote
Old 05-22-2012, 09:02 AM   #14
Ford Assassin
Hey guys, in the interest of keeping this thread from getting off track from the 2wd conversion, please PM me or ask questions in my original LSx swap thread.
Thanks!!
Cable
Old 05-22-2012, 02:31 PM   #15
meter swinger
meter swinger's Avatar
Thats gonna be one awesome blazer.
meter swinger is offline   Reply With Quote
Old 05-22-2012, 03:02 PM   #16
Ford Assassin
I installed the 10 bolt this morning and just as I feared, its a tad too low. So it looks like air shocks are going to be a must for the time being.
The wheels/tires pictured are just temp so I dont scratch my Boss 20's...
Cable
Old 05-22-2012, 03:52 PM   #17
Square_78
Square_78's Avatar
That sits perfect in the back! I like it.
Old 05-22-2012, 04:30 PM   #18
HarleyHauler
Subscribed!
HarleyHauler is offline   Reply With Quote
Old 05-22-2012, 08:32 PM   #19
Cue-Ball
Cue-Ball's Avatar
You'd probably be better off using a different shackle to give a little extra height. Air shocks are just going to be money down the drain because the first time you have any weight in the back and hit a big bump they're just going to blow out anyway. Those things don't last long even in lightweight cars...but in a full size Blazer? Forget about it.
Cue-Ball is offline   Reply With Quote
Old 05-22-2012, 08:37 PM   #20
Ford Assassin
I ran a set in an old '73 Pontiac Catalina for YEARS and they never missed a beat and that boat weighed AT LEAST 4400 lbs. Plus I towed often. Even my '91 Roadmaster wagon has factory rear air shocks with an on board compressor and load leveling.
Anyway, I am running the factory shackles, do they make shorter versions to raise the ride height?
Thanks.
Cable
Old 05-22-2012, 10:01 PM   #21
lolife99
lolife99's Avatar
The quick answer is to install your old 4x4 rear hangers.
Re-arching the springs is another option.
Maybe an "air-over-leaf" air bag install?
Keith
Old 05-22-2012, 10:20 PM   #22
Ford Assassin
I welded the 2wd to the frame, I'd rather not un-do that. I'll go back to the axle being under the leafs if need be, but I might just have to go the air bag route earlier than expected.
Cable
Old 05-22-2012, 10:34 PM   #23
Ford Assassin
Another shot leveled out and on jack stands...
Cable
Old 05-23-2012, 01:09 AM   #24
lolife99
lolife99's Avatar
Looks perfect.
Make sure you check the area directly above the rearend's center section.
It will be really close to the bed floor.
(nothing a notch won't fix,...)
Keith
Old 05-25-2012, 07:50 PM   #25
Ford Assassin
5.3 & 4L80e are back in the truck....
Cable
