09-26-2014, 03:15 PM | #101 |
Re: NP 205 Rebuild and Info
You should start your own thread about the issue and PM us the link if you want. You will get more of us looking at it and more suggestions.
We kinda hi-jacked this thread. Just sayin.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-26-2014, 05:02 PM | #102 | |
Thanks for any help and I will try to get pics this weekend. |
10-25-2014, 03:52 PM | #103 |
That's my next project since I also have the T221. Ready for it to byebye after I get new gears the rear and front end. Good details, right on the money
11-28-2014, 01:13 AM | #104 |
Are there supposed to be any o rings or seals on the speedometer output shaft and retaining nut?
My 72 case was leaking bad out of the speedo cable and when I removed the nut and shaft there were remnants of two rubber o rings. PO intall or factory? Part numbers or o ring sizes? Thanks |
11-28-2014, 01:32 AM | #105 | |
Mine to and no idea on part number or size |
09-24-2015, 06:32 PM | #106 |
This was super helpful thanks!
12-28-2015, 05:49 PM | #107 |
This looks like an excellent guide to rebuilding your NP205. The only thing I might do differently is, wait till you get the entire thing back together, then mask off the little stuff, then paint it, thereby protecting everything including the hardware and covers.
01-01-2016, 12:02 AM | #108 |
Great info!! Just a couple of questions:
Are you suppose to apply rtv to any of the gaskets? Does anyone have the correct needle bearing counts for each bearing? |
02-04-2017, 10:56 PM | #109 |
subscribed
02-05-2017, 08:04 PM | #110 |
Delete if not allowed
Not sure if I can post this here but this is the place to buy master kits for the NP205 http://www.quad4x4.com/catalog/#chevy_gmc |
02-05-2017, 11:55 PM | #111 | |
$419.xx bucks for a master gasket / bearing kit for a np205 large bearing. and I have never been a fan of web sites making you click the link to go to another page to see the prices .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-06-2017, 10:27 AM | #112 | |
ORD has rebuild kits for about $200. http://offroaddesign.com/catalog/NP2...e_Rebuild_Kits
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
02-06-2017, 01:47 PM | #113 |
oh ya I know ord . . . I should have stock in them .
and ever since the guy purchased the site linked above he has go crazy in prices and changing the site all around. and ord is were I get lots of my stuff . but even some of there prices are high . some things I get from evilbay . . .
10-18-2018, 12:37 PM | #114 | |
11-08-2018, 11:12 AM | #115 |
Killer write up! Thank you!!!
05-04-2020, 07:43 PM | #116 |
Just curious, how many needle bearings were there on the rear of the front output shaft?
05-04-2020, 07:54 PM | #117 |
depends on if older FULL needle bearing cup or newer style partial with cage .
if older full setup there should be no space left for another bearing needle .
02-15-2021, 04:33 PM | #118 |
Hello all, I just wanted to get a sanity check on what I'm seeing. On the rear output shaft, the rear end where the needle bearings get installed, in I'm seeing vertical stripes. I don't know if this is wear or if they were machined in and are supposed to be there. They look really clean and almost intentional. Also, what helps to complicate things is that I apparently have a weirdo metal drive speedo unit. I removed the snap ring and washer for clarity. I can't find any clear pictures on the internet of what it's supposed to look like. Thanks for your help!
02-15-2021, 07:07 PM | #119 |
Those lines are not supposed to be there
02-15-2021, 08:42 PM | #120 |
I didn’t have any indentations when I replaced my needle bearings. I’ll try to find a picture.
02-15-2021, 08:43 PM | #121 |
Well... I'll be dipped.
02-15-2021, 08:44 PM | #122 |
Guess I'm in the market for a new output shaft
02-16-2021, 11:27 PM | #123 |
If it takes the early metal speedo gear i have a few . Send me a pm .
