Old 06-08-2012, 02:15 PM   #101
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Project Underfunded / next phase - LSx carb'd to LSx efi
Yes...its supposed to stall in the 2200-2300 range. I'll find out soon...hopefully. I'm just waiting for the right time...that's when I got a strong back to come over and help me lift it off the floor and onto the jack, and steady it while under the truck.
I plan to put more power to it (my 4L85e) in the future so it may get some simple upgrades along the way if needed.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-08-2012, 11:30 PM   #102
68GMCCustom
just waiting for some muscle to put it in!
Kurt -
Old 06-09-2012, 04:50 PM   #103
68GMCCustom
ITS IN!!!!!!!!!!!!!!!!!!
Still not all torqued down and buttoned up....but its off the floor and bolted to the block! What a heavy beastie it is!
Kurt -
Old 06-09-2012, 11:44 PM   #104
gringoloco
A guy with a truck
gringoloco's Avatar
Saweet! Now get back to work. Pics or it didn't happen...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-10-2012, 12:42 PM   #105
68GMCCustom
lots still to do................but as I said before, ITS IN!
even cleared w/o going to the tall tunnel cover
Kurt -
Old 06-10-2012, 01:26 PM   #106
mooseknuckles
mooseknuckles's Avatar
looks good man.
mooseknuckles is offline   Reply With Quote
Old 06-10-2012, 06:08 PM   #107
68GMCCustom
actually it looks pretty nasty up under there!
I've got alot of dirty areas because of trans leaks, paint scraped off my clean frame, etc...its been thru a battle or two!
no biggie.....someday when I get everything about how I want it, I'll blow it apart again for paint and interior.
Kurt -
Old 06-10-2012, 10:03 PM   #108
3r!c84
Badass
3r!c84's Avatar
why didnt you go with a car ls style intake. like ls1,ls2 exc..? i know the truck has more volume for torque. but any other benefits of eather or?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-10-2012, 10:21 PM   #109
mcbassin
Still Learning
mcbassin's Avatar
Nice progress Kurt! I looked at those Gm performance trannys the othe day at the power tour. They look bullet proof! I think it is gonna work great in your truck.
mcbassin is offline   Reply With Quote
Old 06-10-2012, 11:43 PM   #110
El Campo
El Campo's Avatar
Transmission looks great! Who did you buy it through if i may ask?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 06-11-2012, 12:47 PM   #111
68GMCCustom
Thanks guys. As far as intake....its what "a trade" provided. My long range plans include more of a carb'd looking setup with a single plane intake, injectors/rails, and 1000cfm 4150 style throttle body.
Picked up the trans from Pace Performance, was several hundred cheaper then Summit. Looks like now though (via ads) that La Fontaine is going after their business?
Kurt -
Old 06-14-2012, 11:20 PM   #112
68GMCCustom
driveshaft is here! Cooler fittings installed (one fitting felt loose going in, hopefully its ok), lines going in tomorrow. Haven't found adapters 1/4 NPSM to 1/4 NPT and has the long tube end for one side...so quick disconnects will be only on the radiator side for now until I find something for the trans end. Has HD 1350 long yoke.
can you see anything different? rear yoke has 1350 caps on shaft...1310's for the pinion end. just swap the rear u-joints when I get me new rear w/1350 pinion.
Kurt -
Old 06-15-2012, 03:39 PM   #113
68GMCCustom
d-shaft in, trans linkage in, trans electronics connected, need to drill some new holes for the new x-member/trans support location and bolt it down. plumbing next...then exhaust and some housekeeping....and its time to hit the key!
Kurt -
Old 06-16-2012, 11:49 PM   #114
68GMCCustom
dang I work slow.
got all the things above done and some that wasn't on the list. I got like 2 pvc hoses to deal with then its time to hit the key. tired...bed now. Oooo wait...shower 1st...the bed.
Kurt -
Old 06-17-2012, 09:55 AM   #115
blfuller123
blfuller123's Avatar
Who did your driveshaft Kurt?
blfuller123 is offline   Reply With Quote
Old 06-17-2012, 01:05 PM   #116
68GMCCustom
Local shop...Collin County Truck Parts off 380. He made a new one for me over a yr ago...so just had him cut it and add new 1350 ends to it and then rebalance it.
Kurt -
Old 06-17-2012, 01:32 PM   #117
85burb
85burb's Avatar
Ok it's Sunday. Connect hoses and light the fires. I'm ready for a video! Looks nice.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 06-17-2012, 09:36 PM   #118
68GMCCustom
OK......finally its in and all together:
handy little mod for my 3ton floor jack turning it into a transmission jack
temporary tray and mount location for ecm/tcm...eventually to be mounted on the firewall or hidden inside when I do Vintage A/C upgrade.
Hughes locking dipstick
new 3/8" / -6 AN hose and hardware for trans cooler
upgraded shaft w/1350 yoke/u-joint up front and 1350/1310 "bastard' setup in rear until I get my new rear...then it will all be 1350.
4L85e in place, Megashifter linkage, -6AN cooler hose/fittings, rear poly mount
the trucks new "EFI" look. I'm sure it'll change before too long.
don't have the pedal thru the wall yet.....but wasn't working?
Kurt -
Old 06-17-2012, 09:41 PM   #119
85burb
85burb's Avatar
Wow your old trans was leaking pretty good buy the look of that pipe.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-17-2012, 09:42 PM   #120
68GMCCustom
oh...........suppose y'all would like to see/hear it run??????????
http://lsxtrucks.com/gallery/albums/...s/MVI_2895.AVI
Kurt -
Old 06-18-2012, 12:37 AM   #121
Kim57
Kim57's Avatar
Looks and sounds real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-29-2012, 11:08 PM   #122
68GMCCustom
Well folks.......just like in the video...the truck was starting and idling but little else. I wasn't posting about it as I was beginning to loose faith with the harness builder, and to some degree the tuner. Well...I'm glad to say we finally resolved it. I had removed parts from our TBSS to swap into the truck for troubleshooting and felt like it was th pedal assembly. I finally removed the Interceptor scan gauge I had in the TBSS and hooked it up to the truck. It confirmed a issue with the pedal via a dtc, which was enough to get my tuner to send another pedal assembly. Plugged it in the evening and it worked! Was able to clear the dtc's also. This was the 1st time I revved it up since going to efi. Will need some learning or possible retune to clear a bog issue...and I'm hoping to be able to iron everything out this weekend and go hit the track!!! Since this trans should be able to hold it....I'll get my 1st full run out of it in the 1/8th. I may have a pinion angle mismatch issue...will need to investigate further tomorrow. How many degrees of angle can you have safely? Like 5* total or could it be higher....like 8*?With both yokes within 1-2* of each other?
I am ready to run this thing hard...just hope it's ready for it tomorrow...or I may be beating on a sick pony
Kurt -
Old 06-30-2012, 12:32 AM   #123
osaltyone
osaltyone's Avatar
Looks and sounds great! What code were you getting with the bad pedal?
osaltyone is offline   Reply With Quote
Old 06-30-2012, 11:28 AM   #124
68GMCCustom
IIRC....it was p2122....or maybe p2212? Can't remember.
Kurt -
Old 07-08-2012, 08:58 PM   #125
68GMCCustom
OK guys....need some help...or maybe I should have just left a carb on it.
Now that my pedal works I took it straight to the gas station as the tank was empty, and then straight back home as it was not only running bad but my power brakes weren't working. I've spent time looking for leaks and even did some hose replacement and still the same issue. It idles like crap, smokes, and has roughly 7" of vacuum.
This booster/vacuum canister setup was unchanged from when it was carb'd, had decent vacuum, and stopped on a dime. Upgraded hoses with no change. I'm beginning to think my bad vacuum is the result of the state of tune...rather then the other way around. Seems to be way rich and I see more timing then I had in it carb'd. Beginning to think I just need to send the ecm back...again.
best vacuum I can get is on idle down after reving and is 15" at best.
canister and pcv routing
Kurt -
